TR4/4A Rear jump seat
shoopal
I'm now getting to put the interior together and I'm a bit stumped as to what the jump seat area is supposed to look like. Right now you can see the fuel tank and the seat part above the rear axle is bare metal. I assume there is some kind of backboard covering the tank but what comes next? A picture would be great but a description will do
Much appreciated.
Al Shoop
TR3driver
Great Pumpkin - R.I.P
It's just a board, covered with padding and vinyl. Sorry I don't have a pic, but here's the drawing from the parts catalogue
charleyf
The backing piece is available from TRF and possibly Moss as a separate item. You should be able to get it to match your interior colors if your interior is stock colors. When finishing the interior of a TR4 with the surrey top( hardtop),one has to use the TR4A rear piece.
The seat bottom was optional . I have rarely seen one. But I do have one that has been recovered in a wild multicolored material.
Charley
S
shoopal
Thanks all. From Randall's drawing, it looks like Peter is right. $200 is a bit pricey for me at the moment but I'll put it on my watch list and see if it comes down.
Al Shoop
charleyf
Al,
Are you looking for the back board ( #60) or the seat bottom (#61)?
Charley
S
shoopal
Hey Charley
Once I knew what I was looking for, I found the backboard in the pile of carpets and trim pieces that I must have bought in 1998 when I started the restoration but before I quit. Filthy but fortunately no mold or mouse damage. A little cleaning vinyl conditioner will bring it back up, I hope. (tips on this much appreciated)
The seat bottom would be nice but it has to match the rest which is dark blue with white piping.
Thanks for your interest. I'll have pictures soon.
J For Sale Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 0
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
B Rear Brake Cylinders Austin Healey 4
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
apbos New long term project. Sprite powered rear engined race car. Spridgets 9
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
K TR2/3/3A Rear tire pressure when there is an anti roll bar at the front of the car? Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
jfarris For Sale TR3 Rear Sway Bar Triumph Classifieds 0
J 3000 Rear Seats Austin Healey 6
KVH General TR Rear Brake Shoe Orientation Triumph 12
Popeye TR4/4A Rear fender attachment: wing to lamp housing clip? Triumph 7
KVH General Tech Rear Brakes and Solid Axle Triumph 2
P Rear Springs Austin Healey 2
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
KVH General Tech Jacking Up The Rear of TR4 Triumph 5
J Rear Main Seal Kit Austin Healey 1
af3683 TR2/3/3A TR-2 / TR-3 Rear Bumper Wrap Around Fender Guards Identification Triumph 0
Patrick67BJ8 BJ8 Factory Hardtop Rear Window Austin Healey 6
T Looking for "BillMs rear transmission mount" Spridgets 2
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
Ed Foster T-Series MG-TD leaf rear leaf spring. MG 0
drooartz Bugeye jack points to remove rear axle Spridgets 18
bighealeysource Burning Smell from Left Rear Wheel Austin Healey 14
R BJ7 Rear Axle Maintenance Austin Healey 5
J Wanted MGA Coupe rear window glass center section MG Classifieds 0
D MG Midget 1275 rear oil seal. Spridgets 0
