Rear Differential Rebuild
Norton47
I am pulling my TR6 differential to get rid of the clunk and hopefully some of the whining. (maybe that's just me). I am going out of town for work and wanted to have it rebuilt while I was away.
What vendors have people had good luck with out there in Triumph Land.
Thanks
DougF
TRF. It would be pretty expensive to ship cross country. You would need a long work project to have it done for when you get home.
If you aren't set on getting your original unit back, you can order a rebuilt one and send yours in as a core.
TR4
A rebuilt Diff? What does one of those cost? Just curious. My TR4 could use one in the near future.
PeterK
TR4 is different because you would have to ship the entire rear housing (freight) and axles to set it up. Rebuilds are usually around $800 +-.
The TR6 breakes down to just the pumpkin, much easier to ship (UPS) but still very heavy.
kodanja
I just replaced my TR6 differential.
John at Quantum did the job complete for just under 350$
w/o ring gear replaced:
N
Norton47
How does it sound, did you notice a reduction in rear end noise?
kodanja
yes a big time noise reduction in the rear end.
Now I can hear all kinds of other noises! /bcforum/images/%%GRAEMLIN_URL%%/sick.gif
thats Tractor Orange Paint!
N
Norton47
Tractor orange would make it Allis Chalmers tractor where I grew up.
I have also found a local to Seattle rebuilder that comes highly recommended. Nice thing about that is he is local if it still howls.
Same general pricing. He will inspect and then provide an estimate. Some where between 300 and 1000.
I will probably use him.
Thanks
T Rear/Differential "Clunk" Austin Healey 2
R For Sale TR6 REAR DIFFERENTIAL Triumph Classifieds 3
J TR6 Differential / Rear Axle Triumph 1
edkap2002 TR6 differential mounts, rear springs and shocks Triumph 1
J For Sale Triumph TR3 rear differential and rear brake assembly - Northern Illinois Triumph Classifieds 1
Lin Rear differential drain plug leak Austin Healey 16
P MGB Noisy Rear Axle / Differential MG 1
D TR2/3/3A rear shelf differential dome Triumph 9
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
Got_All_4 TR2/3/3A Tr3 rear differential seal Triumph 7
KVH General TR Rear Differential Seal Triumph 7
C TR2/3/3A Rear differential Triumph 29
A Rear Differential Concern??? Triumph 11
T Spitfire Spitfire differential rear bushings Triumph 5
KVH TR4/4A TR4A IRS Front and Rear Differential Bridge Pins Triumph 6
J Rear Axle/Differential Gear Oil Spridgets 13
zschicago Replace rear differential gasket? Austin Healey 12
R MGB MGB Tube Type rear differential MG 0
R use redline mt-90 in 1275 rear differential? Spridgets 3
N Differential and rear suspension Austin Healey 113
I rear axle to differential flange bolt grade? Triumph 8
KVH Rear Differential Overflow Valve Triumph 3
Lin Rear Differential bearings Austin Healey 2
C TR2/3/3A Broken TR3 rear differential Triumph 9
G Rear Differential - Pinion Gear? Austin Healey 3
jerrybny Differential/Rear Axle Gaiter question Triumph 6
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
60BN7 Rear Wheel Opening Austin Healey 9
