Radio Blanking Plate
L
LarryO
Have any of you bought and installed one of the blanking plates for the "radio hole" in your console? I'm tired of looking at the hole and have decided I don't want to install a radio...I wouldn't be able to hear it anyway. I just use my pocket MP3 player and ear buds...or a full headset.
The plate offered by Victoria British looks nice, but does it really fit? At the bottom edge of the hole on my 74, there is only about a 1/8 inch or less flat surface before the angle of the surface changes. I don't want to buy one if it won't fit.
Thanks.
Tom
Larry, wouldn't a 74 have face level vents in that hole?
Also if you want a different look you could always put some supplemental guages in the hole (see attached photo) I have the dimensions for the blank of this if it is of interest btw, had it cut from steel, and painted in wrinkle finish and the clamps for the guages also keep the plate in place.
regards
Excellent job on the dash there.
tony barnhill
Great Pumpkin - R.I.P
I've got one in the dash of my '67 GT - looks great - nice fit
lawguy
While use of earbuds or earphones while driving may be legal, personally, I don't think it's a positive practice.
Just my 2 cents.
69MGC
Driving with headphones or earbuds in California is a traffic violation. Don't know if the laws are the same in Tenn. but you should check.
I'm installing Miata seats that have the speakers in the headrests in my next MGB project, so hearing the radio shouldn't be a problem.
Bret
I have one of those removable security type radio face plates on my B’s Kenwood stereo.
Now normally I don't remove it because it looks kind of ugly without anything there (better than a hole I guess) but it’s only intended as a theft deterrent and not cosmetic.
Anyway I've thought about getting one of the MG plates and shaving it off to fit in place of the removable plate for show & shines. Might be kind of cool looking. Anyone tried this?
Bret
Nunyas
I've not tried that sort of thing with removeable face plate radios, but I HAVE done it with removeable radios. I have an older removeable Apline CD player. In my last car I saved the blanking plate and stuck it in the hole that the radio left behind when it was removed. Worked well for that type for radio. It would probably work just as good for a removable face plate radio too. However, the only thing that might make it look odd on a removeable face plate radio depends on how the radio was installed. If the radio is counter sunk to make the face plate flush with the dash, then it ought to look nice with the blanking plate on. If the radio sticks out at all (like most installs I've seen) then the blanking plate might look a little odd, because it might not sit flush with the dash like it should.
I still have the radio, and I'm planning on doing the same thing in the B when I get the gramlins removed.
Bret
Well it might work ok with mine because it has a dark gray face plate & fram. Fram sticks out about a 1/4" so it might not look that bad. Just don't know if I want to hack up a perfictly good MG blanking plate to find out. /ubbthreads/images/graemlins/wink.gif
Anyway here's a pick of my setup.
Nunyas
could work out ok, with careful planning and execution. I definitely wouldn't use an "original" blanking plate to do it with. One of the reproductions ought to be suitable though.
Platinum
Buy two: One fer practice.
Izzat yer goat ropin' footgear there Bret? /ubbthreads/images/graemlins/devilgrin.gif
Bret
[ QUOTE ]
[/ QUOTE ]
Saw that did ya. /ubbthreads/images/graemlins/rolleyes.gif Like that country song says; “I was country when, country wasn’t cool”. /ubbthreads/images/graemlins/cool.gif
Tom
Attached is apdf of the blanking plate for a MGB MGC, I believe it is the same size whether or not it's centre console or dashboard.
The two here were for use when putting in 50mm (that's 2" to you folks) guages but the outside dims would work just as well for a radio adaptor plate.
I also have this drawing as a DXF (CAD format) file which any competent profile cutting shop could use to cutit out of plate/sheet material.
It saves butchering an original plate...
regards
Tom
  • 180830-BlankTemplates.pdf
Bugeye58
[ QUOTE ]
regards
Tom
[/ QUOTE ]
Tom, 50.8 mm would be 2" to us folks. 50mm would be 1.9685"
Jeff /ubbthreads/images/graemlins/devilgrin.gif /ubbthreads/images/graemlins/grin.gif
Platinum
Pickin' nits, there, Jeff.
Thanks.
Platinum
Showoff. /ubbthreads/images/graemlins/devilgrin.gif
Tom
Jeff
Touche'
in my capacity as a Draftsman I would agree 1"=25.4mm
so 2" = 50.8mm
but......
In my capacity as an MG owner the Smiths guages I got for the dashes in my cars are listed as 50mm or 2" (the holes are 52mm).
btw what I forgot to mention before is that when printed fullsize (check the dimensions after printing) the pdfs are fullsize templates so you don't have to convert these pagan figures /ubbthreads/images/graemlins/tongue.gif
btw Steve what you doin' with a right hook man? that's a bit outta it's place ain't it? /ubbthreads/images/graemlins/driving.gif
regards
Platinum
"PAGAN"?!?! heh...
What's life without a little FUDGE now and again?! /ubbthreads/images/graemlins/jester.gif
B Hidden cd player/radio behind blanking plate? Austin Healey 23
AUSMHLY Radio blanking plate Austin Healey 8
DNK Radio Blanking piecs Triumph 6
L More on Radio Blanking Plates and Ear Buds MG 6
zoohow radio and console mount Restoration & Tools 1
EWD For Sale ‘74 TR6 original radio Triumph Classifieds 0
J TR2/3/3A TRIUMPH Radio? Triumph 13
S Radio Antenna Spridgets 5
D Removing Old Radio Austin Healey 4
T TR2/3/3A Question on old radio from my TR3 Triumph 9
Got_All_4 TR5/TR250 Pros and Cons to Wiring The Radio Direct Triumph 6
E Alpine radio for a US Model Db7 Volante Other British Classifieds 0
Hangtown Healey Barbie Clock-Radio Austin Healey 9
M General MG OEM Radio wiring help MG 4
pkmh Radio Knob Design For A 67 BJ8 Austin Healey 16
red57 Positive ground radio Austin Healey 17
S Wanted Original Style Positive Ground Radio Austin Healey Classifieds 0
T how to have music/radio when driving Spridgets 33
7 Strange A/C - radio problem Other Cars 7
Jim McCauley TR6 TR6 Radio recommendation Triumph 4
M Fitting a modern radio Austin Healey 9
BoyRacer Ideas needed for under dash radio mount, cup holders, glove box Austin Healey 39
1 MGB '66 MGB radio measurements MG 3
6 Spridget Radio/Speaker Case Spridgets 4
G Wanted Triumph TR4 [63] Period correct radio Triumph Classifieds 2
Tim Tucker TR4/4A BENDIX Radio Model: 5SMTR manual? Triumph 2
T Wanted Wanted: BE Sprite Original Motorola Radio Spridgets Classified 8
F TR2/3/3A radio mounting plate Triumph 4
H Vintage Radio Austin Healey 9
Zitch TR4/4A Original Radio knobs Triumph 12
M S1 e type radio console Jaguar 2
wangdango BJ8 radio delete plate? Austin Healey 2
Got_All_4 TR2/3/3A TR3 radio console Triumph 30
Marvin Gruber Becker Mexico radio Austin Healey 7
kennypinkerton MGB Radio console removal question MG 4
D Radio! Other Cars 0
Zitch General TR WTB - Triumph AM radio. Triumph 11
roysimpsonjr TR4/4A Will an 8 inch wide radio fit? Triumph 3
Scotsman General TR Radio Triumph 4
M TR2/3/3A Phone charger & Radio can I put these in my car??? Triumph 7
K TR4/4A Stock Triumph Radio Troubleshooting? Triumph 4
G original radio 1961 e series jaguar Jaguar 3
TulsaFred Bugeye radio in-dash Spridgets 10
B orginal BMC radio Austin Healey 9
Mink TR4/4A Radio plate/dash support orientation Triumph 6
C TR2/3/3A Triumph radio installation date code Triumph 7
Gliderman8 TR6 Stereo radio? Triumph 4
R TR4/4A Assembling the interior - dash support and radio plate screw holes don't match up Triumph 4
catfood 100/4 Radio consule Austin Healey 2
S Radio / Speakers Spridgets 12
