tomshobby
Reached a milestone with my ‘74 project today. Everything is finally finished underneath and the only thing I will have to get under the car again for will be to fasten the seat rails.
Some of the things done under there are all new brakes including shoes, rebuilt calipers, pads, new rotors, brake lines, master cylinder, wheel cylinders, clutch master, clutch slave, clutch line, fuel tank, fuel level sending unit, new fuel lines, new fuel pump, auxiliary emergency pump, wiring with selector switch for pumps, rear spring bushings, rear axle seals and bearings new u-joints, front and rear shocks from Peter at World Wide, new tie rod ends, rebuilt front suspension, new front wheel ball bearings, new exhaust, and nylon axle straps. Can't believe how good it feels to get this far!
