TR6 Procar Pro-90 Seats in the TR6
nichola
Bronze
This is the fit of the Procar 80-1400-51 Pro-90, in case anyone was curious. Along with pricing including shipping to San Diego area. See pics below.
nichola
nichola
Bronze
This is a follow-up on these seats after driving the car for six weeks. I am 6' 0" 185 lbs. and these seats fit in the car well but the foam is too thick for my size. I have removed the cover from the seat-back (very easy to do) four times carving more and more foam from the mid-back area and it's getting to where it's more comfortable. As you can see from the photos these seats have much more foam than the original seats. If I could figure a way to mount it on the floor without the sliders, I think that would be much better for seat height but I'm still scratching my head about how I would do that.
I'd say if the driver is 5' 9" or shorter these seats would be great without any modification. But for me the seat as it is delivered puts me too close to the steering wheel (knees and arms bent too much)... so that I can't rotate the steering wheel past my leg on a 90 degree right turn without regripping the steering wheel. I'll keep modifying until they feel just right, but just wanted to issue a buyer beware review for others needing an alternative to original seats.
On the passenger side they're marvelous, no issues at all.
Simmo
I feel your pain. I bought a pair of Suffolk Seats from Moss UK. They cost a heap plus shipping to Australia $3000 +. They look great but the manufacturers said they fit the TR6 bolt pattern. Thats very much untrue! The people at Suffolk wouldnt talk to me, never again. I have had to make tremendous mods to these seats to both make them fit the mounts and get them lower in the car, as you have had to do. My main problem now is that I am 6'2" and my "Tunnel side knee" pushes hard on the support yoke thus making the TR not so much fun to drive.
nichola
nichola
Bronze
Yeah, I'm not fond of feeling like a big kid in a toy car that he's outgrown. But I'm sure I will get mine sorted, and I hope you do as well. It is important to get that seating position correct so you can get the fun back. Good luck with yours.
Lotuswins
Hello,
I too am looking for a substitute seat for my TR4, and am considering these ProCar's. A couple of thoughts to help on the leg room:
1) I've seen where others have notched the wheel well on the drivers side to allow the seat to move rearward further.
2) Moto Lita makes an offset 14 inch steering wheel that looks really nice. I put one on my Healey to help in with ingress and egress as well as my thigh no longer hits the wheel when going from throttle to brake. I'm pleased, but they are pricey ($400).
HTH, Jerry Rude
nichola
nichola
Bronze
Hello,
HTH, Jerry Rude
The price was right for me on those ProCar seats, so I'll continue tweaking the driver seat until it suits me. Right now I'm as low as I can go and still retain the slider mechanism. So I will try to make a stationary mount sitting right on the floor pan, while still utilizing the stock TR6 mounting holes. As for the seat back, I think at this point I will continue carving foam out. I am only removing foam where my back rests against the seat and not around the perimeter, to avoid having to cut and re-stitch the vinyl.
Thank you for that lateral thinking, Jerry. I do get stuck on a solution sometimes, leading to weeks of head scratching. Good luck with your hunt.
jaesteban
Hello! Do you have an update on the ProCar seats? Still happy with them? I am about to buy some for a TR6. I am 5'6"
nichola
nichola
Bronze
You will love them and the price is right! The only issue I had was that at 6' I am a too tall for these without removing foam from the seatback. I'm satisfied for now but may continue to carve a little more from the back and seat when I feel like pulling the driver seat out. You can look at a couple more pics and a description in my website here... > TR6 Interior and Dashboard installation > The Barn <
I should also note that I have the seats mounted as low as possible while still retaining the slider functionality.
jaesteban
WOW! Thank you! They look GREAT! I wonder if the model with headrests would fit as well? Did you use the original sliders or did you get an adapter from ProCar? The rest of the car looks AWESOME as well by the way!
nichola
nichola
Bronze
The seats came with sliders, but you'll need to make brackets to utilize the stock holes in the floor pan. The four holes in the floor pan do not form a rectangle, as the outboard rear hole is forward a bit. Headrest model should fit exactly the same way. I'm not sure I took any photos of the brackets I made, but if I did I will post photos shortly.
nichola
nichola
Bronze
Nope, I didn't take any pics of the brackets that I made. If I remove seat anytime soon, I'll post photos.
Simmo
Since my last post I have had an expert make a provision in the drivers side, rear inside wheel arch, in order to accomodate the seat back. Now the seat can be moved back enough to accomodate a seven foot driver. Covered with a new vinyl arch trim its unoticable and works just fine. Should have done this before I started trying everything else.
nichola
nichola
Bronze
I would love to see a photo of that modification... I thought about it but decided against it.
Lotuswins
simmo, I would really like to see that wheel arch mod, and any dimensions? Maybe just a pic of inside the wheel well? I am currently replacing my driver side floor so its perfect timing.
Thanks, Jerry
Simmo
Thanks, Jerry
Will do. At the moment the car is over in Bathurst and will have to wait till next week, after race week, to pick it up but will send you a pic or two
pdplot
I have the opposite problem. I had to put wooden blocks and spacers under the drivers seat so I could see over the steering wheel. The wheel is still too close, a problem with almost all British cars. My Alfa has the opposite problem - the wheel is quite far away. I like that better.
Simmo
Hi Jerry, I drove the TR6 about 100KM yesterday in relative comfort. Legs streached out and knee not hitting the dash support yoke. I have included a couple of pics, which arent that fantastic, of the inside rear wheel arch. Sorry thats the best I can do but happy to give you any more help you may request. Regards Ian
Lotuswins
Thank you Simmo, that is exactly what I needed. Did your expert weld in a patch or hammer it to its configuration?
thanks again, Jerry
Simmo
thanks again, Jerry
I didnt see him do it and think im pleased i didnt see it but I believe he did it with a damm big hammer but made a fairly tidy job of it. Good luck.
M General Tech Pro restoration Triumph 0
Got_All_4 TR2/3/3A Super pro bushings Triumph 2
T TR6 Go Pro video of a short drive Triumph 3
SkinnedKnuckles Just Curious - Where are the Old Pro's Triumph 28
mountainman Pro & Con's of Pertronix vs Points Triumph 43
Alan_Myers TR2/3/3A Carrillo Pro-A Conrods in TR2/3/4? Triumph 11
aeronca65t No More Pro-Rally!! Other Cars 6
Frank C. Pro and Con of Negative Ground conversion Austin Healey 3
A Pro-Tec lining for my boot MG 7
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 0
roscoe Aftermarket Seats with Headrests Austin Healey 9
J 3000 Rear Seats Austin Healey 6
G Rebuilding Front Seats Austin Healey 4
shadowfever Wanted WTB Spridget seats. Spridgets Classified 0
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
conan69 TR5/TR250 TR250 seats Triumph 1
R For Sale Original AC Ace/Cobra seats. Early 60's, hand made Leveroll by A.W. Chapman, London Other British Classifieds 12
Simmo T-Series TF SEATS. Which are the alternatives MG 5
D Wanted Wanted 80Spitfire hard top and seats Triumph Classifieds 0
M For Sale 73-76 TR6 Seats Triumph Classifieds 0
jfarris TR2/3/3A Venture into the "dark side," Miata seats in a TR3 Triumph 9
H GT6 Basketweave seats Triumph 0
rjc157 TR6 Mazda seats Triumph 3
J Bugeye seats wanted... Spridgets Classified 0
Gearhead Midget seats for sale Spridgets Classified 6
jlaird MGB Agatha II, seats MG 9
F TR6 TR6 Seats Triumph 4
oldbagpipe For Sale '69 TR6/TR250 Seats now available Triumph Classifieds 0
dbenichou289 TR2/3/3A Valve seats Triumph 8
J For Sale For Sale - 2x TR6 seats in red vinyl - Best Offer! Triumph Classifieds 1
M MGB 1967 MGB seats MG 9
T Wanted TR 250 Seats Triumph Classifieds 5
M TR4/4A Do MGF seats fit in TR4 Triumph 0
J For Sale Early 70s TR6 seats in new red vinyl, with new tracks, $500 OBO Triumph Classifieds 0
M TR4/4A Seats for TR4A Triumph 3
L 100/6 replacement front seats Austin Healey 7
J TR6 seat track location on new pans without holes for seats Triumph 2
Magyar For Sale Miata Seats, Tan Leather Spridgets Classified 2
B For Sale Seat Mounting brackets for aftermarket seats Spridgets Classified 0
R Wanted '72 TR6 Seats, Upholstery kit or replacements? Triumph Classifieds 0
F TR6 miata seats Triumph 12
red57 Heated Seats Austin Healey 24
C Recovering Seats Austin Healey 5
warwick-steve What seats do I have? Austin Healey 7
E BJ8 Seats, Exhaust Hanger, Heat Shield Locations in Floor Austin Healey 7
T Smart Car Seats in a Spridget? Spridgets 8
R TR2/3/3A Let's talk seats Triumph 27
B TR6 1970 High Back Seats for TR6 - Side bolste wires squabs neededr Triumph 3
4tecdog Seats with headrests for frogeye Spridgets 23
M Seats reupholstered Austin Healey 3
