Plastic Radiator Leak
AngliaGT
On the '95 Dodge Dakota that I just bought.There's a
leak on the top neck (where the upper radiator hose goes).
I bought a new hose,but what can I use on the neck?
- Doug
Platinum
Epoxo-88. UH-1's were built with it. :thumbsup:
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR6 Frosted rear plastic window Triumph 6
AUSMHLY HD8 damper with Brass or plastic cap? Austin Healey 8
M E-type series 1 plastic dash vents Jaguar 1
T TR2/3/3A Is there any problem in putting TR6 plastic wheel covers & TR6 lug nuts on TR3 wheels Triumph 4
NutmegCT Chrome plastic? Restoration & Tools 11
7 stupid plastic cooling system parts Other Cars 2
R How i restored the plastic and rubber trim on my car Restoration & Tools 3
gbtr6 TR6 Need a plastic dash light plinth Triumph 17
Steve P. six blade plastic fan bolts? Spridgets 6
maxwedge5281 refinish trafficator plastic? Austin Healey 20
KVH General Tech Timing and Valve Tuning--with a plastic fan Triumph 4
J TR6 Starter front plastic cap needed Triumph 4
D Plastic Paint??? Spridgets 9
BoyRacer Top bows - plastic sleeve for socket Austin Healey 0
M Broken off dip stick plastic tube, stuck oil pan, and I think too much... Spridgets 10
60TR3A Should My '63 BJ7's Carburetors Have Brass Caps or Black Plastic? Austin Healey 3
mdionne MIDGET Badge Plastic Inserts and Decals Spridgets 2
T Plastic fans Triumph 11
D How do I clear up a plastic rear hard top window? Restoration & Tools 3
bthompson Plastic fill plugs?! Spridgets 1
PAUL161 Meguiars Plastic cleaner Question MG 2
S cleaning old plastic Triumph 6
V TR6 Top, aftermarket plastic/fiberglass for TR6? Triumph 6
ShawnC_at_Moss MGA New - Plastic Fan for MGA & MGB to 1971 MG 10
T Source for plastic picks / pointed tool? Triumph 31
AngliaGT DM - Lotus Elan S2 Plastic Model Lotus 1
bcbennett TR6 TR6 top cover/plastic snaps Triumph 5
af3683 Cleaning Convertible Top Plastic Windows Triumph 4
T TR4/4A TR4A plastic fan options Triumph 14
Jer plastic cooling fan options for 1275 Spridgets 4
John_Nichols Triumph Surrey Top Window Plastic Reproduction Triumph 3
Hedgehog Plastic conv window foggy Restoration & Tools 3
dklawson Metal vs Plastic Facet Pumps ? Spridgets 2
A Painting plastic [interior] Restoration & Tools 9
Y Plastic Battery boxes Triumph 0
mountainman TR 3 with Plastic Surgery Survey Triumph 13
T Plastic cooling fan for BE - fit question Spridgets 5
S cleaning Bakelite or plastic Triumph 3
CinneaghTR TR4/4A TR4 Plastic Battery Box Liner? Triumph 4
Gundy Brittle plastic..the good n' the bad Other Cars 7
SherpaPilot Slave Cylinder Plastic Pipe Alternative? Triumph 15
Z AH BN1 Plastic VIN Plate Austin Healey 10
Yngbld14 plastic window repair Spridgets 10
RickB Cleaning of plastic windows - just tried McGuire's Spridgets 5
Stewart Moss plastic fan shroud MG 2
G Plastic intake manifolds Triumph 3
M Restoring Plastic Triumph 11
Basil Restoring plastic lens covers? Restoration & Tools 6
JPSmit cleaning plastic - any ideas Spridgets 6
