Performance coil
bdcvg
So I spent 2 hours reading all the post on the Pertronix ignition, which I will install soon. I have a brand new standard Lucas coil, is a performance coil really needed?
John Turney
Not really. Only if you're looking for the last couple of percentage of performance.
Gearhead_Garage
If you bought a standard Pertronix igniter (not the Igniter II), it was designed to work with 1.5 - 3 ohm standard coils. Use your new standard coil and all will be well.
People often swap for a "performance coil" without considering that the other components were not designed to work with the lower impedance. The result can be shortened component life.
B
bdcvg
Yep, just the standard Pertronix. The quality of condensers and rotors is so iffy , I figured run the pertronix have the other parts as back-up. Plus the Pertronix was only $70 shipped.
Also, there are known quality issues with Lucas 'performance' coils.
John Turney
The Pertronix will help with the condenser issue (as well as worn distributor shafts) but you will still need a rotor. The premium rotor from Moss, as well as others, is required instead of the standard rotors.
B
bdcvg
I have 3 rotors that are all the same part# the metal arm is a different length on 1 of them. There is no justice.
Keoke
Just make sure none of them use a rivet to attach the brass arm to the phenolic body.
If they do!!:
!] Drill out the rivet and fill the void with JB Weld.
'OR
'2] Get a new type rotor sans the rivet.
B
bdcvg
If they do!!:
'OR
So is this procedure for all rotors or just with a Pertronix?
steveg
Re the rotors: Jeff at Advanced sells the good ones (which he makes) 2 for $15; Moss has them at $7.95 each. At those prices it doesn't make sense to fix the riveted rotors - after all the rotor can be a single-point-of-failure.
Alan_Myers "Performance" coil springs Triumph 3
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
K TR2/3/3A Moss Improved performance camshaft 851-051...... Triumph 0
C Abingdon Performance Ltd. MG Classifieds 0
90dog Classic Car Performance Reviews Austin Healey 5
B TR4/4A Performance cam Triumph 24
R For Sale TR6 Parts huge collection and Engine/Performance Parts Triumph Classifieds 0
Michael Oritt Towards better brake performance.... Austin Healey 28
M Leaky Fuel Pump and Weak Performance Spridgets 14
Lin Advance Performance Technology [APT] - Great customer service Austin Healey 1
M TR2/3/3A Brake System Performance Expectations Triumph 27
Bob_Spidell Rebuild Performance Suggestions Sought Austin Healey 8
K TR4/4A Performance Cam=Broken Rings??? Triumph 9
Rut TR4/4A Performance engine rebuild Triumph 3
B Poor Performance Austin Healey 20
sim High performance DCOE carbs 40 or 45 Spridgets 5
J General TR Let's Talk Timing a TR2/3/4 for Performance. Triumph 6
N TR4/4A performance cam Triumph 5
J US Performance parts Austin Healey 9
NardisCNC Performance alternator questions.....?? Spridgets 14
Hap Waldrop VTO Performance Wheels, Spring Sale Spridgets 13
Hap Waldrop VTO Performance Wheels, Spring Sale MG 1
Hap Waldrop VTO Performance Wheels, Spring Sale Triumph 9
I Effect of bad valves on engine performance? Triumph 9
CZ_Dave Performance Experiment, Will it work? MG 11
I TR6 TR6 performance help Triumph 10
S E-Type 4.2 Series II Performance Exhaust Jaguar 1
B 85 jag XJ6 improve it's performance ? Jaguar 4
JPSmit Performance World Car Show Spotted 10
rick_ingram MG2011 - Autocross School/Performance Driving Scho MG 0
steveHealey3000 Originality versus performance Austin Healey 38
Don_Racine We're Spridget Performance Specialists! Spridgets 3
JPSmit Performance World Car Show Other Cars 1
Hap Waldrop Performance Challenger alloy wheel MG 0
NardisCNC 1st Time Overhaul / Performance questions?? - 1275 Spridgets 17
M MGC MGC Performance Exhaust System MG 11
lbc_newbie Rebuilding 1275 for a little performance... Spridgets 8
Tabcon Performance upgrade plans and an SU question. Triumph 8
W Monza Performance Muffler Spridgets 65
B 1275 performance books Spridgets 7
Dadandson Stock Cam VS Performance Cam Spridgets 1
B performance increase from triple strombergs?? Triumph 33
tweety pulling catalytic conv... better performance? Spridgets 3
C Performance Modifications Triumph 3
kodanja Cold weather Effecting Performance? +- Triumph 35
John_Mc Wedge Wedge performance questions Triumph 17
RickB Dynolicious performance meter for iPhone MG 0
Gray_Cat Spridget Performance Parts Spridgets 3
bluemiata90 Wedge TR8 PERFORMANCE INCREASE Triumph 17
Number_6 TR2/3/3A TR3 Performance cam from BPNW Triumph 6
