    BCF is a resource offered at no cost to the Little British Car community. We do not require you to pay to play here. However, if you find BCF a useful resource, appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please support the forum with an "optional" low-cost (less than many car club dues) annual upgrade. There are some benefits to upgrading!
TR2/3/3A Odometer gears for the early pot metal speedometer
sp53
Odometer gears for the early pot metal speedometer, does anyone know where to purchase them? I did scrounge some out of an old speedo, but one side of the gear is striped. However, I did flip them around and I will try them, but the gear has seen better days. I think I remember Art actually making some a while back. In addition, what would be a fitting grease to use on the shaft? I was thinking some of that synthetic grease for brake installation.
bnw
Speaking of speedometers... anyone have a spare trip reset knob and shaft for my 57 they care to part with??
CJD
Good luck. I've been looking for 14 months without luck. The last one that turned up on EBay brought $49. I am considering making my own from pictures...
martx-5
... I think I remember Art actually making some a while back...
Yes, I did make a couple awhile back. I bought some nylon gears from McMaster-Carr that were the same diameter and same number of teeth as the original fiber gears. I had to drill the hole larger, file the depth of the teeth deeper and maybe something else I forgot, but they did press on and are still working.
S
sp53
You guys are killing me. I was hoping there was a source for the gears. I made a reset for a tin can model, but it was a few years back and then sold the car (big mistake) forgot how much love and work I put into it. When you guy remove the guts from a pot metal can, do you take the glass off then the needle and face then then undo trip rod, or reach in through the light socket and undo the cotter key from the trip rod and pull the guts out with the face and needle on like you might do on a tach?
titanic
I made a few on my lathe from delrin rod.If my memory is correct, they are 20 teeth. The teeth were cut by grinding a tool to fit the tooth profile and dragging the tool against the blank like a shaper. There was a 40 tooth gear on the spindle that was used to index the cut. Crude, but it worked.
I contacted a vendor that specializes in producing speedometer gears and I think the minimum volume necessary to justifying make the dies (for injection molding or extruding) was at least 1,000 pieces.
Berry
CJD
Is this the reset shaft?
Berry
Close, but that's not it. The TR2/3 reset knob has a tube soldered to a spring, soldered to a knurled knob. The spring is usually covered with a plastic sleeve so it is not visible. The whole thing is a bit longer than the knob in your picture...
I have gone through 6 speedos this last year...from Ebay, from Marv, from my junk pile...and all the reset knobs are missing. The shaft inside the speedo breaks and the knob falls out and goes to the wind!
titanic
I was just curious about the part in the photo. It appears to be a reset shaft, but I do remember that the one on my TR3A (quite a few years ago) did have a knurled brass knob on the end. If someone would care to post a dimensioned sketch, it would be pretty easy to make a workable one.
Berry
6TTR3A
Here's some pics from my files. Doesn't answer all questions.
Frank
S
sp53
This one I am working on right now I cannot seem to get the needle off. Any ideas/ THEY JUST PULL OFF CORRECT?
CJD
If you can hold the aluminum disc with a finger and then twist the needle, it usually loosens it. But, yes, it does just pull off.
S
sp53
Got it John the twist is what did it. I have actually got them apart without removing the face and needle by undoing the cotter key on the trip control through the light socket hole, but I do not recommend it because getting the cotter in and out with those surgical tools from a doctor’s office is too much. I got that idea by calling and talking to one of those gauge repair guys in California, but I think he was messing with me now that I look back at it.
Lukens TR2/3/3A Jaeger speedo gears for the odometer. Free Triumph 2
B General MG Does odometer record when flat towing. MG 5
Donald1107 TR2/3/3A TR3 Odometer Triumph 12
BoyRacer Odometer Reset Rod Austin Healey 4
J TR2/3/3A Speedometer Bounce with Odometer Gear Movement - Benchtop Calibration Triumph 3
R Issue with odometer after repair Austin Healey 1
K TR2/3/3A Dismantling Speedometer...getting the odometer pin past the case??? Triumph 2
K TR2/3/3A Odometer trip meter? Triumph 4
Darwin TR6 odometer reset cable Triumph 2
T TR2/3/3A Odometer resets for TR2-4A Triumph 7
R odometer off by 25%, spedometer correct Spridgets 5
HEALEYJAG Ebay warning: Odometer fraud Jaguar 5
AndreL TR6 TR6 odometer cable Triumph 3
P Odometer Finger Prints inside glass Triumph 9
Boink Odometer repair? Spridgets 10
G Odometer repair MG 45
HAN8L1965 65 Odometer Mileage Setter Spridgets 1
R inaccurate odometer issue Spridgets 9
T odometer bj7 Austin Healey 10
RynoBoy74tr6 Speedo, Odometer,Trip counter problems.... Triumph 6
hondo402000 odometer stuck at 99999 Triumph 7
John_Mc Speedometer/odometer questions Triumph 9
mrsprite Broken odometer? Spridgets 10
regularman Ok, odometer play time. Spridgets 48
regularman Odometer error is pretty big Spridgets 22
TR4 Jaeger Odometer Reset Arm Triumph 4
B Odometer failure Triumph 12
jlaird Help, BMW 218ti odometer light Other Cars 14
Slider748 TR6 Need help on fixing TR6 odometer Triumph 5
PAUL161 T-Series TD/TF speedometer gears. MG 3
AUSMHLY 2nd gear should I file it? Do gears have a hard coating? Austin Healey 7
Hamish Racing General Tech Close Ratio Gears Triumph 2
PAUL161 MGB Early B Banjo Rear Gears MG 2
EWD TR6 74 TR6 - Transmission / Shifting gears Triumph 5
B TR4/4A New valve gears/timing Triumph 21
B Differences between BN2 and BN4 speedometer gears?? Austin Healey 7
KVH General Tech Grinding Gears in Shift From 1st to 2nd Triumph 13
C TR2/3/3A Gears grinding on first startup..... Triumph 14
M For Sale bj8 ring and pinion gears 3:55 for sale Austin Healey Classifieds 6
C MGB Should I lubricate the cog gears MG 2
M Wanted wanted gears Austin Healey Classifieds 0
M TR2/3/3A Tr 3A Planetary Gears Triumph 2
pan Austin-Healey 100 BN1 Gears Austin Healey 5
rjc157 3.54 crown and pinion gears Austin Healey 2
TulsaFred Timing Gears dot to dot Spridgets 9
pkmh BJ8 Tranny Issue - Slightly hitting gears when shifting Austin Healey 13
R TR6 Cannot engage gears Triumph 7
N lube starter gears? Triumph 6
BN6_2197 Gears do not engage after gearbox O/D refurbishment Austin Healey 27
