TR2/3/3A Odometer trip meter?
karls59tr
Bronze
When I pull down the trip meter knob and attempt to turn it I get a slight movement of the four digits moving altogether and then it jams. Can the back of the speedo be taken off and the mechanism freed up and lightly lubricated? I don't want to risk taking everything apart. Thought there might be a simple fix?
charleyf
The unit comes part from the front not the back. Take the chrome ring and glass off the front. And you will need to remove the extension part of the trip meter to get the unit to drop out the front. You should be able to see the gears inside and hopefully what is causing the problem. But there is not much lubication in there that I have seen.
c
Charley
CJD
The trip odo is a series of number wheels with friction discs between them. As the grease dries out, movement tends to jam...much as you are describing. You could try using a degreaser on the wheels after you get to them by opening the case...but the number tapes could easily be discolored if you are not careful. It would be best to dis-assemble the wheels to clean and re-lube them, but that is a rather large job.
If you don't want to tackle it, Nisonger or others will rebuild and calibrate the speedo...at a rather stiff price.
Check out post #66 for an idea of what you're up against:
https://www.britishcarforum.com/bcf/showthread.php?94885-Instrument-Faces/page2
TR3driver
Great Pumpkin - R.I.P
Try pushing up on it rather than pulling down.
RynoBoy74tr6 Speedo, Odometer,Trip counter problems.... Triumph 6
B General MG Does odometer record when flat towing. MG 5
Donald1107 TR2/3/3A TR3 Odometer Triumph 12
BoyRacer Odometer Reset Rod Austin Healey 4
J TR2/3/3A Speedometer Bounce with Odometer Gear Movement - Benchtop Calibration Triumph 3
R Issue with odometer after repair Austin Healey 1
K TR2/3/3A Dismantling Speedometer...getting the odometer pin past the case??? Triumph 2
Darwin TR6 odometer reset cable Triumph 2
T TR2/3/3A Odometer resets for TR2-4A Triumph 7
S TR2/3/3A Odometer gears for the early pot metal speedometer Triumph 27
R odometer off by 25%, spedometer correct Spridgets 5
HEALEYJAG Ebay warning: Odometer fraud Jaguar 5
AndreL TR6 TR6 odometer cable Triumph 3
Lukens TR2/3/3A Jaeger speedo gears for the odometer. Free Triumph 2
P Odometer Finger Prints inside glass Triumph 9
Boink Odometer repair? Spridgets 10
G Odometer repair MG 45
HAN8L1965 65 Odometer Mileage Setter Spridgets 1
R inaccurate odometer issue Spridgets 9
T odometer bj7 Austin Healey 10
hondo402000 odometer stuck at 99999 Triumph 7
John_Mc Speedometer/odometer questions Triumph 9
mrsprite Broken odometer? Spridgets 10
regularman Ok, odometer play time. Spridgets 48
regularman Odometer error is pretty big Spridgets 22
TR4 Jaeger Odometer Reset Arm Triumph 4
B Odometer failure Triumph 12
jlaird Help, BMW 218ti odometer light Other Cars 14
Slider748 TR6 Need help on fixing TR6 odometer Triumph 5
Hamish Racing TR2/3/3A Road trip video - car info Triumph 0
Hamish Racing TR2/3/3A Trip out Triumph 3
Nugget Texas 200 mile road trip success Spridgets 13
AngliaGT Some Cars I Spotted on My West Virginia Trip Spotted 4
dougie A Quick Trip Around Oulton Park.... Austin Healey 3
jlaird MGB Took my weekly trip MG 2
M Trip of a thousand miles Jaguar 5
T TR2/3/3A TRip report 2019 Triumph 4
DrEntropy MGB Road trip! MG 25
AngliaGT Saw a Few Along the Trip Spotted 4
Rut TR4/4A Road trip Triumph 15
Mickey Richaud General MG Road Trip Report MG 6
T TR2/3/3A Another TRip Triumph 17
AngliaGT From my Montana Trip Spotted 5
V Le Mans Classic 2016 Early TVR Road trip Adventure TVR 6
drooartz 400 mile road trip in the 4-door Spridget Spridgets 11
Rut Neat trip, good friends! Spridgets 2
R General TR Long Distance Trip Repair Kit Triumph 20
HealeyRick A Road Trip to LeMans Austin Healey 5
Bob Claffie MGB The first trip [long] MG 3
U General TR Road Trip Video Triumph 2
