Need Tips on Replacing Rear Suspension Bushings
vping
Bronze
I am going to replace all of the rear suspension bushings with urethane. I have new shackles and front & rear leaf spring bushings which I purchased with a new whole car kit. I also have new urethane U-bolt bushings.
Questions are:
Do I need to replace the Ubolts?
What is the best approach to replacing all said bushings in the rear?
Steve_S
If the U-bolt nuts aren't rusted on then there's no reason to replace the U-bolts. If they are rusted, they will probably break as you try to remove them.
You will need a large press to remove and install the front eye bushings. I use a local machine shop for this and they hate doing it. The job is really a pain because it's difficult to hold the bushing straight and to not damage it on the way in.
The rest of the bushings are a piece of cake.
vping
vping
Bronze
Fudge. I was hoping to keep this in house. No chance huh?
Stewart
If the urathane bushings are 2 piece you should have no problem with a home install. However you will need to have the old bushings pressed out. It shouldnt take a machine shop more than 5 min to get both out.
vping
vping
Bronze
Which means the spring has to be completely out of the car?
I think it is a one piece. If I have an arbor press, can I do it myself. My shop has a small one that I can use for this.
SAustin
Vince,
I helped a oouple of friends this past summer rebuild their suspensions. Both guys had the complete urethane set to go in including the leaf-spring front bushings.
When it came down to it, we burned them out. Didn't even mark the driveway (and it was my driveway!). Just used a propane torch to get them going. As they broke apart, we just poked out the rubber. Gave the eyes a good cleaning and the new bushes went right in.
Cheers
Simon
Steve_S
If the front eye bushings are 2-piece then they will go in easily. If they are one-piece, they will require a LOT of pressure and care must be taken to protect the lip.
BoyRacer Need Tips on getting wiring harness through firewall Austin Healey 4
TEM666666 Sprite MK1 Door liner rubber mat installation.. Need tips and recommendations. Spridgets 22
C Need tips for recovering my BE dash Spridgets 3
tr6web TR6 Need advice removing downpipe nuts Triumph 4
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
Madflyer For Sale Triumph GT 6 parting out need something Triumph Classifieds 10
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
tinman58 TR2/3/3A Need super charger!! Triumph 7
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
John Turney Need a Better Demister? Austin Healey 5
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
69MGC MGC Need one MGB/C Splined Hub MG 1
69MGC Wanted Need one MGB/C Splined Hub MG Classifieds 4
Gliderman8 General TR Need clarification on Triumph Competition Preparation Manual TR250 TR5 TR6 Triumph 4
S TR6 Need wisdom on tr6 brake calipers Triumph 6
J MGB Need help identifying these parts MG 6
S TR2/3/3A Need New Battery for TR3A Triumph 9
B MGB-GT Need help with MGB GT rattle MG 0
AngliaGT MGB Need a GT [or Three]? MG 1
