Need things to do
Burrell22
Anybody have a list of mostly money free easy things to do on my tr4? Im bored but wanna do some stuff to clean up/ tune
Gliderman8
Wash it :cheers:
On the serious side, you could set the valves to get it ready for the driving season.... total cost FREE
Geo Hahn
Burrell22 said:
...Im bored but wanna do some stuff...
In my experience driving it will inevitably lead to 'Things to do'.
I suppose if you posted a picture of your engine bay we could pretend it is a ebay listing with a starting bid of $20K and point out all the things that should be done.
Lubing the rear springs is totally free (used oil) and the sort of thing I do when absolutely everything else is caught up.
Burrell22
Burrell22
i dont think there is much to be done, new rear shock aborbers, completely rebuilt front end, washed and waxed, rubber protecant put on all seals, vinyl condit on vinyl, leather is conditioned, full tank of gas, oil changed, new rear end and preload set, radiator painted, every joint greased.
trrdster2000
One thing I see in car shows that is forgotten is the inside of the wheels, it's very time consuming but not a big cost. It's really noticeable on the wire wheels.
Wayne
Burrell22
Burrell22
trrdster2000
How about running those wires on top of the radiator cowl under and across the front valance, much neater and where they need to go.
wayne
Geo Hahn
Nice -- but not w/o some possible projects.
That short hose to the top of the radiator would have been an 'accordion' or 'bellows' style to reduce transmitting engine movement & vibration to the radiator. A solid hose there could present some long-term problems.
I do not see a back-up system for if (when) the bonnet release cable breaks. I just use a simple second cable though there are also lever systems sold. Good insurance.
Switching the horns left & right will get them pointing forward and creating more effective sound.
<span style="font-style: italic">Oops, I said horns... but you have only one (and it should be on the drivers side methinks). The use of two horns creates a high/low discordant sound that is more effective than just getting louder.</span>
Adding relays (if you haven't already) to the headlamps will take a load off the dash switch, make your lights brighter and permit the use of higher power lamps (I use H4s).
Gee, this is fun. There's more but I'll let others speak up too.
BTW -- Your engine must not rock like mine if you can get by with air cleaners that close to the inner wing.
Banjo
I think I saw a speck of dust in the third pic........
you could just trade with me. then you'd have a never ending list of things to do... Oh, wait, you said money-free things.
HerronScott
The nerve of some people having such a nice-looking car. :smile:
Very nice and I'd love to see some outside and interior shots!
Scott
Burrell22
Burrell22
haha i didnt do this to show off :laugh:. im just bored and wanting something to do on it.
ever since the car was built its leaked oil bad, but its been gettin worse. i crawled under it to take a look. its leaking around the gas pump oil pan, rear main seal( of course slingers suck) crankcase tube oil filter adapter, every hole it can.
and ill take some pics of the whole thing and post them in pictures.
this is really my grandfathers car that my dad built, so cleaning falls to me- i keep this thing spotless... haha
mrv8q
Jeez, I thought you were done and was going to offer you your choice of my cars to work on....
BTW, your car looks great!
TR3driver
Great Pumpkin - R.I.P
Well, there you have it. You can work on at least some of those leaks for little or no money. Cut a nice, extra thick fuel pump gasket from the backing for a legal pad with a sharp knife. Pull the crankcase tube out and carve a piece of wood to use to expand the end, then clean the hole and smear with Permatex before reinstalling the tube. Make sure the little support link is in place. Etc.
Russ Austin
Drive IT!
G
JFeher said:
Honestly,
If it were mine I'd be wearing the tires out.
Russ Austin said:
Drive IT!
X3
Wear it out! :driving:
What good is something like that if you don't enjoy it?
Don't worry, I'm sure it'll find something for you to do once you get back home.
If you are really bored and have to have something to do, run a compression test to see if you broke any rings or a piston running it on pump gas.
M
Member 10617
Seriously... I recommend that if you have room in your garage that you find a TR3 or a TR2 and restore it to the high level that you've gotten your '4 to. Drive one and work on the other. That way, you don't have the pressure of having to complete the '2 or '3 in order to enjoy them.
You've got a beautiful car there! Always encouraging to see these cars brought up to and kept in such great shape. For me it's a matter of "historic preservation" as much as car restoration.
L Things I need Austin Healey 6
D Things you NEED to know before an HVDA Conversion Triumph 6
Shealey Need a couple things... anyone? Spridgets 10
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
Madflyer For Sale Triumph GT 6 parting out need something Triumph Classifieds 10
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
tinman58 TR2/3/3A Need super charger!! Triumph 7
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
John Turney Need a Better Demister? Austin Healey 5
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
69MGC MGC Need one MGB/C Splined Hub MG 1
69MGC Wanted Need one MGB/C Splined Hub MG Classifieds 4
Gliderman8 General TR Need clarification on Triumph Competition Preparation Manual TR250 TR5 TR6 Triumph 4
S TR6 Need wisdom on tr6 brake calipers Triumph 6
J MGB Need help identifying these parts MG 6
S TR2/3/3A Need New Battery for TR3A Triumph 9
B MGB-GT Need help with MGB GT rattle MG 0
AngliaGT MGB Need a GT [or Three]? MG 1
T Need an Anti-Tramp Bar? Austin Healey 6
