Need Paint Code for Ivory Color
Ray Smith
I need the paint code for the Healey Ivory color.Where can I get a paint sample of this color? Where is a good source for purchasing paint?
Ray
MGACoupe
Ray,
I just had the paint mixed for my Healey at https://www.autocolorlibrary.com/cgi-bin/search/search.pl
"Jimmy Chips" mixed the colors for me in Old English White also known as Ivory and Colorado Red. They offer PPG products and still carry PPG Duracryl acrylic lacquer which is what I am using. Their color matching uses original codes and they will also mix to a piece of your car if you send it to them. They use no offsets, meaning they don't find a modern color that looks like an old color. The way they explained it to me was years ago their was not nearly the number of toners that are in use today. So if a old color is matched to a new color formula the results will not be the same under different lighting conditions. The Colorado red they did for me is spot on the original. Drawback is price - acrylic lacquer in red is $405.00 a gallon - ouch! They have formulas going back to the 1920's and their web site contains more information about paint than most people care about.
Regards,
Ken
John Loftus
I called PPG for my OEW (aka Ivory) codes. I gave them the ICI code: 2379 (from Donald Pikovnik's book) and this is the formula for PPG Concept Acrylic Urethane (DCC)
DMC 936 - 224.4
DMC 918 - 124.7
DMC 904 - 83.1
DMC 902 - 66.5
DMC 929 - 49.9
Used DT 870 Reducer and DU5 Hardener. Looks like OEW to me (although in the photos it looks whiter .. in real life has much more of a warm, creamy color) https://www.loftusdesign.net/restorationweb/
Cheers,
John
dklawson
The roof on my Mini is OEW and coincidentally it's PPG DCC paint. (John... I don't recognize all those numbers... are those the drops of pigment per gallon? ) My OEW is indeed an off-white with a cream appearance. I've never parked the Mini next to a Healey for direct comparison but from memory... I'd say it's close. Most PPG shops will mix up as little as a pint which should cost you about $40. It's a good investment if you're unsure of the color and don't want to buy a gallon.
If you're interested, I may still have the four or five digit PPG code for the paint at home. I can look it up and post it here if you need it.
Keoke
Hi Dough, I do not recognise those numbers either. If I look in my Healey "Body Service Parts List" it simply calls out :Ivory White{Code WT3}-??---Keoke
John Loftus
The paint supply house had no problems with those numbers. It is the formula (offset formula) ... probably the same thing they go through when you give them a five digit code number .. tells them what quantity of each toner is required to make a gallon. They give no guarantees with offset formulas and you should have a small quantity made up first to check the color. It did look good to me and my painter though.
Cheers,
John
Dave Russell
Yoda - R.I.P
The numbers John quoted are the number of parts of various toners used in a tinting base to make the color. The base, while not given is likely a white.
DMC 936 is "blue shade Pthalo yellow"
DMC 918 is "red shade organic yellow"
DMC 904 is "red shade Pthalo blue"
DMC 902 is "carbon black"
DMC 929 is "light red oxide"
Who would ever think this adds up to OEW?
Keoke
No Ray, A pint will just leave you tipsy /ubbthreads/images/graemlins/laugh.gif,you should get two! that way a little will be left over for touch ups if require later.---Keoke
John Loftus
[ QUOTE ]
Doug,
Is the ICI code 2379 that John quoted the same as the PPG code?
Ray
[/ QUOTE ]
No ... that would be far too easy! /ubbthreads/images/graemlins/lol.gif My understanding is PPG aquired ICI in the 90's but the numbers are not the same.
Cheers,
John
dklawson
Ray,
I checked the left-over paint I have and can no longer read what was written on the label. I checked my invoices and all the shop wrote was "ppg-mix". I'll inquire with a couple of friends and see what they have in their records.
dklawson
MY66AH Need the PPG paint code..... Spridgets 6
W Need a paint code - Salvador Blue Triumph 4
K TR6 Need help with Mimosa Yellow Paint Triumph 1
mountainman TR2/3/3A Need Help on Paint Color For TR3 Triumph 11
R Need paint info/ assistance Triumph 13
GreenHornet Need some Green Paint Spridgets 4
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
Madflyer For Sale Triumph GT 6 parting out need something Triumph Classifieds 10
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
tinman58 TR2/3/3A Need super charger!! Triumph 7
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
John Turney Need a Better Demister? Austin Healey 5
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
69MGC MGC Need one MGB/C Splined Hub MG 1
69MGC Wanted Need one MGB/C Splined Hub MG Classifieds 4
Gliderman8 General TR Need clarification on Triumph Competition Preparation Manual TR250 TR5 TR6 Triumph 4
S TR6 Need wisdom on tr6 brake calipers Triumph 6
J MGB Need help identifying these parts MG 6
S TR2/3/3A Need New Battery for TR3A Triumph 9
B MGB-GT Need help with MGB GT rattle MG 0
