Wanted Need Fuel Gauge for 1959 Bugeye
Tim Hollister
Hello All,
Looking for a Smiths fuel gauge for a 1959 Bugeye Sprite that has been stored in a basment for nearly 25 years. The Smiths number on the face of the gauge is FG2530/31.
Please let me know if you have one I could acquire. Also, any and all leads will be appreciated too as these things seem to have disappeared!
Thanks,
atlaajetmech
I have the gauge you described. It is the same number on the face. I tried to test it and the needle moves up to about 1/8 with either 12V or 6V on the posts. The same if you switch the polarity. Don't know if this means it is good or not. The needle swings freely through entire range if you rotate the instrument in your hand. The case is undamaged
and the chrome ring is bright and shining. It has all the hardware. I can send pictures if you are interested.
Tim Hollister
Tim Hollister
Thank you for replying to my request however I have already come up with a gauge. My bad for not posting that fact. Please accept my apology.
Thanks!
Bayless Need fuel gauge work Restoration & Tools 4
D Does a BJ 8 need a vented fuel cap? Austin Healey 4
DanLewis Weber 40DCOE - Does it need a check valve in the fuel supply line? Spridgets 4
H need troubleshooting help with 100-6 fuel?electrical? Austin Healey 9
A need advice on fuel pump Triumph 12
Ed_K Need an SU fuel pump ? Austin Healey 1
M Tell me I need a fuel tank sending unit Spridgets 21
A Need help diagnosing fuel mix problem Triumph 23
C Need advice on fuel line replacement - midget Spridgets 2
ncbugeye Need immediate help with Bugeye fuel tank Spridgets 10
roofman Facet electric fuel pump - need advice Triumph 15
J I need a picture of installed fuel pump for BJ8. Austin Healey 4
H Need new fuel tank for my 100 Austin Healey 6
D need detailed pics of '75 midget fuel and cooling... MG 6
tr6web TR6 Need advice removing downpipe nuts Triumph 2
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
Madflyer For Sale Triumph GT 6 parting out need something Triumph Classifieds 10
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
tinman58 TR2/3/3A Need super charger!! Triumph 7
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
