Need a name
mightymidget
Well I got my $500.00 Midget running tonight, at first gas was pooring down carb. took top off cleaned put back together and that stopped. But when I got the motor running it was all over the place, won't idle, dead spot off idle, etc..
Anyway suggestions, it is a weber, been sitting for years, carburators really are beyond my understanding. Hap who is close is way behind etc... anyone near South Carolina that I can send carb to that will treat me right, should I uy a new Carb (weber) or should I Buy some used/rebuilt SUs.
I have two old sets but they are off 1098 engines
Billm
Use the SU's from the 1098's- you will be surprised at what they will do!
BillM
Platinum
:iagree:
G
My DGV finally gave up the ghost and I had to buy a new one. My booster venturi was loose and I tried, but couldn't get it straight. Try the other carbs you have.
I'm confused by the thread title, did you mean "need a hand"?
M
mightymidget
No the title is right, I needed a "name" of someone to send my carb to to have rebuilt, if I cann't figure it out myself
jlaird
Hap is a nice name, he does carbs, SUs for sure.
lesingepsycho
My $.02-- If you're going to spend the dough, get the SUs. The weber (DGV) is pretty average at best on these cars. The SUs, though more intimidating to some people, are far superior. However, if you've ever tackled the job of rebuilding a set yourself, your understanding of how these carbs work goes way up. Also, you then know the theory behind the function and tuning and you can far more easily tune these carbs for a better result. It's all about getting them matched up which isn't nearly as hard as everyone seems to think.
By the way, you'll esentially never get rid of that off idle hesitation with the DGV.
JACK
G
JACK
I finally got rid of mine by buying a new carb.
Brian_James
If the HS2s you have are not worn out at the throttle shaft, they are not impossible to rebuild yourself. There are plenty of resources on the web and I think there are even youtube videos showing the process (John Twist?). The kits are not cheap (~$125 from moss), but it can be done. There are some really good step by step procedures for getting them tuned once they are on the car (something you would have to do even if you sent them out).
https://www.nicoclub.com/archives/2-write-ups-on-tuning-su-carbs.html
Do one at a time. If you have more than one set, take one of the junkier ones apart first. I think any of the sprite midget workshop manuals have a procedure for rebuilding carbs.
Brian
Brian_James
lesingepsycho said:
...you can far more easily tune these carbs for a better result. It's all about getting them matched up which isn't nearly as hard as everyone seems to think.
Jack is right. Tuning is a matter of adjust, check, adjust, check, repeat 20 times.
Brian
RickB
This is one of the reasons I want to find a set of HS4's for my Nissan 1500.
The downdraft carb on it is crap, apparently they are nice when new but mine is very far from new.
Now I have a cylinder head and intake for a set of SU's I am itching to get it put together. First things first of course, going to work on brakes at tomorrow's NODoody gathering.
regularman
Weber, dead spot right off idle. You can drill an extra hole in the area that handles the mid range air. I used to have link to a site where a guy had pictures but that was before my computer needed a rebuild. Most of the time if its got the jets that came with the kit and nobody has changed them then it has to do with someone putting too open an air filter or to open an exhaust on it. These things get temperamental because the DGV (or Holley5200) was designed for a bigger engine and on a 1275 the air flow is really low at idle and right off. It ends up getting lean right before the shot of gas hits it from the force pump. Shut the air down a little and see how it does. You can get rid of that dead spot. Problem is that fiddling with jets and jet kits gets expensive and that is not the problem usually. I don't know anything about SUs, Hap is the man on that. With the dgv its a lot like a motorcycle carbs (which I have worked on a lot). To troubleshoot the problem is not about rpm its about throttle position and what part of the carb is being used at that point.
livinginthepast
Rebuild the SUs. I had ZERO experience and simply followed the directions in one of my manuals. The only thing I couldn't do was install the oversized throttle shafts.
That said, I needed a lot of help getting them tuned, but the point is that you CAN do the rebuild yourself. It was actually very easy. Just be careful to do it in a clean area. Yes, the parts need to remain clean, but if you drop one of the tiny washer/cup things, they will, like magic, disappear into thin air. Ask me how I know.
M
mightymidget
I am going the cheap route, buy some carb cleaner,and try just cleaning the Weber....takeing plenty of photos during removing parts
JPSmit
I had my SU's rebuilt professionally. figured I didn't need to know everything. That being said, they are very easy and simple carbs. Here is an article on reaming the throttle shaft. It should be an easy DIY. And, if you dis-assemble and re-assemble an SU carb enough times, eventually you will have two carbs.
https://www.chicagolandmgclub.com/techtips/general/545.html
lbc_newbie
I'm with EVERYONE who is advising you to rebuild your SUs. I went through heck trying to figure out why my Weber would not rev above 2500 RPM. I finally took the coaching and dumped it. I spent a pretty penny to have my SUs rebuilt and do not regret a single dime that I spent. Take the wise counsel from these guys and get rid of the Weber.....
You can get around $150 from some other unsuspecting buyer that will offset the cost of fixing your SUs. That's with the manifold.
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
Madflyer For Sale Triumph GT 6 parting out need something Triumph Classifieds 10
tinman58 TR2/3/3A Need super charger!! Triumph 7
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
John Turney Need a Better Demister? Austin Healey 5
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
69MGC MGC Need one MGB/C Splined Hub MG 1
69MGC Wanted Need one MGB/C Splined Hub MG Classifieds 4
Gliderman8 General TR Need clarification on Triumph Competition Preparation Manual TR250 TR5 TR6 Triumph 4
S TR6 Need wisdom on tr6 brake calipers Triumph 6
J MGB Need help identifying these parts MG 6
S TR2/3/3A Need New Battery for TR3A Triumph 9
B MGB-GT Need help with MGB GT rattle MG 0
AngliaGT MGB Need a GT [or Three]? MG 1
T Need an Anti-Tramp Bar? Austin Healey 6
K TR2/3/3A Help! No start! Need input from you guys. Triumph 9
T Wedge TR7 engine, need help identifying part. Triumph 5
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
