    BCF is a resource offered at no cost to the Little British Car community. We do not require you to pay to play here. However, if you find BCF a useful resource, appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please support the forum with an "optional" low-cost (less than many car club dues) annual upgrade. There are some benefits to upgrading!
Mk 1 Frogeye Vacuum Advance
ARennie
I am trying to sort out a 1959 Frogeye Sprite (948cc) owned by my Fiancee. This vehicle was originally owned by her mother and has been subjected to a 'commercial' restoration which leaves a bit to be desired. One of the issues I am trying to resolve is the vacuum advance. When I first got the vehicle going it was missing at about 3500 rpm and I soon found that the manifold end of the vacuum advance tube was not connected to anything!! I have hunted high and low around the twin SU carbs and the inlet manifold but there seems to be no tapping or tube for this to connect into. I have obtained the original BMC workshop and parts manuals and they shed no light on the issue. The workshop manual simply says disconnect the vacuum tube! The parts manual shows the tube with a connecting nipple but does not show where it connects into. The exploded view of the Carburettors and the inlet manifold also shed no light on the mystery! The manifold appears correct the only possible hint that there is is that the parts manual refers to two SU carb bodies a 1 and a 1a but does not say what the difference is. It could be that during restoration two of the same have been used. As it is the vacuum tube is copper and comes from the distributor around the back of the tappet cover where there is a small copper chamber like an accumulator in line, it then continues and ends just by the aft of the two SU carbs.
Can anyone tell me where the connection should be? The ideal would be a photograph. If I need to purchase the correct parts I am happy to. It has been suggested that I just drill and tap into the manifold and insert a connection, I do not feel that this is an option even though I have no doubt it would work. I would rather get the vehicle back as close to original spec as possible, it has had one owner since new and that must be somewhat unusual.
I would think the engine should run fine without the vacuum advance (just poorer fuel economy).
jlaird
You should find the vacum advance port on the front carb, rear side kind of close to the manifold.
Check the rear carb as well, maybe some PDO got them on backwards.
jvandyke
Here it is an an HS2, not that would apply much to a Bugeye. I asked over the weekend as I wondered if this were ported or manifold and I guess it varies, so just tapping the intake for a source of manifold vacuum may not be best solution. The vacuum line to the dizzy may not be vac advance but a vac retard or something.
Brian_James
If the bowls on your carbs don't look like the ones in jvandyke's picture and instead have a nut at the top for the fuel line connection and brass damper nuts they are HS1 not HS2. In that case the port for the advance is where Jack says it is. It is on the right side of the front carb and slightly underneath. Very hard to see with the carbs in place, but you might be able to find it with your finger.
Brian
A
ARennie
Thanks everyone. This is really a great help. I cannot get my hands on the vehicle till next weekend but will report back once I do.
Thanks again
Alick
Sarastro
H1: front carb, right side, just behind the flange that connects to the manifold. There should be a little brass tube pointing down at a 45-degree angle.
If it's not there, it may have fallen out. It happens. (For example, to mine!) Or, since you have copper vacuum line, maybe it uses a fitting instead of the tube. You might have to take off the carburetor to see it clearly.
A Mk1 'Frogeye' Sprite Vacuum advance connections Austin Healey 2
N For Sale Austin Healey Frogeye Sprite Spridgets Classified 0
AngliaGT Came Across This Frogeye article Spridgets 2
Basil For you Bugeye/ Frogeye fans Spridgets 5
Boink Sir Paul's latest video... with Frogeye! Spridgets 6
4tecdog Seats with headrests for frogeye Spridgets 23
5 For Everyone that has a BUGEYE OR FROGEYE Spridgets 3
4tecdog Frogeye Windscreen Spridgets 3
M Oldest Surviving Frogeye Bodyshell? Spridgets 9
HealeyRick Teens Killed in Frogeye! Spridgets 14
M FrogEye tyres Spridgets 11
A New Frogeye project - the road may be bumpy Spridgets 11
HealeyRick Hong Kong Frogeye Spridgets 0
M Heritage Motor Certificate for Frogeye / Bugeye Sprites ? Spridgets 4
5 The Title BUGEYE or FROGEYE for that matter Spridgets 15
5 Bugeye and Frogeye Spridgets 3
F 1958 Frogeye with fuel problems Spridgets 9
Gundy Little Frogeye w/ apologizes to the Beach Boys Spridgets 5
Mychael Ideas for a parcel shelf in a Frogeye Spridgets 8
HealeyRick That Olympic Frogeye Spridgets 4
Mychael Progress Latest on the Frogeye. Spridgets 1
HealeyRick Olympic Frogeye Spridgets 10
Boink Teaching my boy to drive the Frogeye... Spridgets 8
T Anyone fancy a V8 Frogeye? Spridgets 11
Gundy Frogeye go-cart? Spridgets 12
T Build log: 2 Brothers and a '59 Frogeye Spridgets 14
P FROGEYE on the Velocity Channel Spridgets 4
Frankenhealey Optional rear seat for a Frogeye? Spridgets 10
weewillie frogeye Spotted 0
D frogeye starting problem Austin Healey 2
Chatis Winterising the Frogeye Spridgets 15
glemon My Brother got an original, one owner Frogeye Spridgets 12
Hairyone frogeye hardtop Spridgets 10
toysrrus "FROGEYE" parts "FOR SALE" in the "CLASSIFIEDS": Spridgets 6
toysrrus Re: "Frogeye" Radiator ID Question: Spridgets 7
aeronca65t Bugeye [Frogeye] Differences Spridgets 3
BugEyeBear Unique BugEye [FrogEye] Hardtop on eBay-UK Spridgets 0
F Frogeye clutch problem Spridgets 10
F frogeye clutch Austin Healey 2
john_j New? Frogeye? Spridgets 2
Ohiobugeye Morris 948 Going into a 59 Frogeye Sprite Spridgets 5
B frogeye/bugeye turbodiesel engine conversion Spridgets 6
Chatis 1960 Frogeye - What do others do? Spridgets 9
aeronca65t Frogeye/Bugeye Toy Spridgets 5
Sopwith_Camel MGA booster Vacuum MG 8
S TR2/3/3A Distributor vacuum advance hook up to the inner plate Triumph 9
S TR2/3/3A Vacuum Advance Union Size Triumph 1
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
drooartz MGB Question on timing and vacuum MG 11
B Vacuum at Idle Austin Healey 9
