Missionary in need of a Defender Guru
Banjo
Yey all you Land Rover lovers.
My Brother is a full time missionary in Ghana Africa. His daily workhorse is a 1997 Defender 110 that has the 300 TDI engine. It was once RHD, and has been converted to LHD as per Ghanaian law. He tries to care for it as best he can, but it takes a beating on the terrible roads around where he is, and it was the victim of some shoddy workmanship before he got it.. I'm trying to find someone with a lot more knowledge of these beasties than I have. He asks me for help occasionally, and I am not much help due to my limited exposure to Land rovers, and diesels.
His goal is to do a complete mechanical refresh and keep the rover on the road instead of buying a used Mitsubishi Ute that has been hacked by the local "Fitters" as they call mechanics in Ghana.
His current battle is a lot of black smoke after a head replacement, and now a turbo that has way to much runout in the shaft causing oil consumptuion and blue smoke sometimes.
The turbo is on order, but the black smoke is something else, unless it's also related to the turbo issue.
He's also looking into a new wiring harness to fix the butchered one from the conversion.
Anyone that could be a contact for parts and info would be great.
thanks,
Banjo
Wolfy
A 1997 Defender would have the 300 tdi engine which is considered the best engine of all because its the last true hobby engine LR did and has no electronics. I did many thousands of miles on one with zero problems, just make sure you change the cambelt as per the book.
Try removing the EGR valve and then blank it off with a flat plate, they tend to run better and cleaner without it.
Best parts availability is the UK, the usual suspects are Paddocks, Rimmer Bros, Dunsfold etc.
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
Madflyer For Sale Triumph GT 6 parting out need something Triumph Classifieds 10
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
tinman58 TR2/3/3A Need super charger!! Triumph 7
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
John Turney Need a Better Demister? Austin Healey 5
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
69MGC MGC Need one MGB/C Splined Hub MG 1
69MGC Wanted Need one MGB/C Splined Hub MG Classifieds 4
Gliderman8 General TR Need clarification on Triumph Competition Preparation Manual TR250 TR5 TR6 Triumph 4
S TR6 Need wisdom on tr6 brake calipers Triumph 6
J MGB Need help identifying these parts MG 6
S TR2/3/3A Need New Battery for TR3A Triumph 9
B MGB-GT Need help with MGB GT rattle MG 0
AngliaGT MGB Need a GT [or Three]? MG 1
T Need an Anti-Tramp Bar? Austin Healey 6
K TR2/3/3A Help! No start! Need input from you guys. Triumph 9
T Wedge TR7 engine, need help identifying part. Triumph 5
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
