Midget EFI pics
Morris
Hey guys,
Sorry these have been a long time coming...
tosoutherncars
Interesting! So the whole CD150 is only there as a throttle body? Would it not be easier to use a 'standard' TB with roughly the same opening size as the stock manifold, perhaps even one with a Throttle Position Sensor (Mustang, etc?) Or does your FI system (MS&S?) not require a TPS?
Hehe... that's too many acronyms at once!
Glen_B
Answering for Morris, the Megasquirt system needs inputs from:
1: Intake air temperature
2. Intake air pressure
3. Coolant temperature
4. O2 sensor.
5. Throttle postion sensor
Glen
Morris
Morris
The CD 150 (minus the dashpot) is just the throttle body. You can run it with or without a TPS. I have a TPS mount that I got from sidedrafttbi.com. But the version of MS I am running can also calculate acceleration enrichments from sudden drops in MAP so I know longer use the TPS.
Another throttle body could be used, and would probably improve air flow. But using another throttle body would not achieve my goals. Also, technically, it is against US law to modify or remove pollution equipment. My system allows all original pollution equipment to remain in place.
I realize everybody hates the CD150, and few 1500 owners would be sad to see it go. But, like many LBC enthusiasts, I think the SU is a thing of beauty. So I developed a system that could be easily adapted to almost any sidedraft carb.
Ulf
Awesome Morris, tell more about how this is going and what the benefits are in your experience.
This looks like something I would like to do to my Midget if it was not too much fixing, and since you state that simplicity in installation is your main goal I am all ears on this project.
racingenglishcars
That goes for me too. Though I'm sure I could do it all myself, I would appreciate all info I could get from a previous installation.
The difference being that yours is a 8 port head and I'm stuck with 5 ports. When the time comes, I will probably use a single-point injection and remove the double 1.5 carbs.
Morris
Morris
Right now everything is stalled while I do some remodeling work on my house. When things start to move on the project again, I will keep you posted.
The benefits so far, easy starts in cold weather, immediately drivable (no warm up needed), big decrease in emissions (in theory) and slight increase in fuel economy and performance.
I am happy to help anyone wishing to inject her/his car. /bcforum/images/%%GRAEMLIN_URL%%/smile.gif Lemme know what you want to know and I will do my best to tell you.
L Turbocharged, efi MG MIDGET. VROOM, whoosh, psssss Spridgets 19
Morris Midget EFI: Opinions wanted Spridgets 15
Morris Midget EFI fuel pressure problem Spridgets 10
R MG Midget beginner (1978) Spridgets 1
D Trying to get back working on the 1974 Midget Spridgets 11
C For Sale Selling MG Midget MG Classifieds 2
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
K 68 midget. No horn, headlights, turn signals Spridgets 9
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
K 1968 Midget Steering wheel Spridgets 1
K General MG 1968 Midget Questions MG 1
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
M Midget steering column Spridgets 3
B General MG 77 MIDGET Gas tank sending unit MG 1
shadowfever Midget seat nuts and bolts Spridgets 2
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
shadowfever Moss Motors MG Midget seat covers Spridgets 6
B 1977 Midget - Sandglow Paint Restoration & Tools 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
B For Sale '69 Midget MG Classifieds 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
D I have doubled the value of my MG Midget. Spridgets 2
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
A 78 MIDGET BUMPERLESS Spridgets 4
A 78 MG MIDGET EMMISIONS REMOVAL Spridgets 1
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
A General MG 78 MG MIDGET ALTERNATOR SMOKES MG 5
D MG Midget 1275 rear oil seal. Spridgets 0
D Engine Colour for a 74 Midget. Spridgets 8
B 1977 Midget Bra Spridgets 9
B Midget Differential Capacity Spridgets 5
B For Sale Replacement Panels BE/Midget Spridgets Classified 0
G Best fuel option for a 72 Midget Spridgets 5
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
NutmegCT General MG MG Midget on Route 66 MG 3
D Back on the Midget after a vacation and work break. Spridgets 48
AngliaGT RB Midget - Finally tracked it Down! Spotted 3
AngliaGT For Sale MGB /Midget Wooden Shift Knob MG Classifieds 0
J Midget front shocks Spridgets 4
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
M MG Midget decoding Spridgets 1
JPSmit 60 years - Mg Midget Spridgets 0
M 1972 Midget Seat Belt Replacement Spridgets 4
D MG Midget in distress. Spridgets 155
D Is it a 1965 or a 1966 MG Midget? Spridgets 2
