MGB MGB Dash conversion, older to newer
AndyH
I have a 1970 "pillow" dash, it's in fairly poor shape, and a lot of the instruments are not functioning. I managed to pick up a 1977 dash and radio console with all the instruments in them for next to nothing. Would this conversion be a headache? It looks like the bolts are all in the right place, but what about the wiring? Should I sell them and go for a 72-76 instead? I do want a glovebox and I hate the pillow.
tony barnhill
Great Pumpkin - R.I.P
Re: Dash conversion, older to newer
Think you'll have to do some wiring rearrangements - also, don't remember if your oil pressure/water guages are the same type....&, I'm not sure if the scuttle is the same on your '70 & the '77 - if different, the dash might not line up...also, trying to remember whether the steering column support/cowl are different.
PAUL161
The support bar which holds the tabs for the lower dash fasteners and extends from one side to the other is different. You will have to replace the whole cross bar with a newer, later model bar or align up and replace all the metal tabs. Otherwise the dash will not bolt up. Not as easy as you might think. If I were you, I'd sell it and get a 72 dash instead. It'll probably bolt right up. You'll have to convert to a mechanical oil pressure line which is a no brainer. I personally would not try to convert it over to a late model dash. A lot of work, if you do it right. JMHO. PJ
PS, here's a photo of the lower bar I'm refering to.
Platinum
Okay Paul, now I'm intrigued: what does the two different colors of the tags signify?
...or was it just that you ran out of one or the other...
PAUL161
Pretty aint they! Ha! The wife picked them up for me somewhere. I just didn't have it in my heart to use the pink ones.
PAUL161
Andy, It looks like the car has the original steering wheel. If you change the wheel, whatever you do, save the center logo button where the horn push is on later cars. As far as I know, that plastic center button was only made in 1970 and a good one is rare. Also, if you intend to remove the engine smog equipment, pack it all away in a box and keep it. Someone, someday, might want to restore the engine back to factory original. Were loosing a lot of these critical parts to the junk yards and we have to start saving them. JMHO. PJ
A MGB MGB dash painted MG 13
B MGB 79 MGB electrical - dash MG 5
B MGB 1978 MGB 2 wires hanging under the dash to the .. MG 4
Lynn Kirkpatrick MGB MGB Dash Replacement MG 3
B MGB Replacing MGB dash MG 7
D 1968 mgb dash replacement Restoration & Tools 1
Lynn Kirkpatrick MGB MGB dash MG 3
B MGB Its time for another pic. Dash shot on 72 MGB MG 2
D MGB MGB Dash Temperature Control Knob MG 3
R MGB Steel Dash MGB Glovebox Insert MG 7
G MGB Installing steel dash into early 70's MGB MG 9
T MGB New Dash for 74 MGB MG 17
R6MGS MGB MGB Dash Pad MG 8
Paul Slice MGB VB MGB Dash Pad kit MG 4
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 7
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
A Wanted 1970 MGB - Emissions Parts MG Classifieds 3
C MGB Re strapping a MGB seat bottom MG 2
Simmo MGB Re Engined MGB MG 4
Carlbanan56 MGB MGB rear break rebuild MG 6
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
Carlbanan56 MGB Mgb turn signals MG 17
J MGB 1970 MGB Steering Lubrication MG 1
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
L SOLD!! For Sale MGB Hardtop MG Classifieds 3
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
I MGB Purchase of 1972 MGB Roadster MG 3
C MGB-GT MGB-GT Front Ride Height MG 0
J MGB Advice for new MGB owner? MG 16
D Wanted Wanted: Chicklet Headrests for MGB/C! MG Classifieds 0
Editor_Reid MGB Anders Clausager's "MGB" book MG 4
J MGB 1966 MGB won't start MG 1
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Erica MGB Carburetion and MGB fuel economy. MG 0
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
R MGB side chrome installation MG 4
C MGB MGB MG 5
3798j Off Topic MGB at the Drive in Bank MG 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Rut MGB 62-67 upper MGB steering shaft MG 3
VeeCee MGB 1974 MGB Roof Installation MG 0
J MGB Just bought a 1966 MGB MG 50
T MGB MGB hoses MG 6
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
