Method to remove Bondo
Popeye
Bronze
I am starting to take inventory of my TR4A... This past Sunday afternoon I followed Banjo's advice on removing Bondo: Apply a propane torch to the stuff until little bubbles form. Then it scrapes right off with a putty knife.
Works like a charm. FYI.
Caveat: Probably best to do this in a well-ventilated area...
martx-5
That's the method I employed on my TR3. It's very effective but, yes, it's pretty noxious when it starts to burn. /ubbthreads/images/graemlins/hammer.gif
71tr
Man, I hit mine with a high rpm sander and the dust flew! Not the cleanest method but effective.
71TR6 TR2/3/3A Slight tweak to Martx-5's dogleg covering method Triumph 9
M BJ7 back panel fixing method Austin Healey 5
T TR2/3/3A What is best tool, and best method, for widening gaps on TR3A grille? Triumph 21
K TR2/3/3A Clutch bleed using"gravity bleed" method? Triumph 4
glemon New Painting Method Restoration & Tools 2
doc50 Best Method to weld sheet metal repair panels in... Triumph 10
K Saving a clutch disc.....old school method? Triumph 11
H removing steering wheel...method? Austin Healey 9
KLUTZ Easiest method for connecting Emerg. brake cable MG 5
J Balancing Wire Wheels - Old Method? Triumph 3
bigjones Timing by the vacuum method Spridgets 4
K Method of breaking stuck clutch disc free? Triumph 10
MGBGT_noob The great welding method controversy MG 12
chicken Best method for getting the two tone line right on Austin Healey 4
A Steering box - Pitman arm removal method work? Austin Healey 10
jjbunn PDWA Seal Bolt Removal Method Triumph 12
G BFH method of steering wheel removal MG 4
T Third gear installation best method Spridgets 10
B FAST & EASY CAR DRY METHOD Restoration & Tools 2
P "Head Method" for trunk use Sunbeam (Rootes) 3
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
CARSINC How to remove factory contact cement? Spridgets 9
K TR2/3/3A " do not remove the fan as it is essential for establishing crankshaft balance" Triumph 9
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
newmexTR3 TR2/3/3A How to remove thrust washer from lower wishbone & trunion Triumph 7
jfarris TR2/3/3A Rear Shock and link remove and replace Triumph 1
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
drooartz Hose from water pump to head, remove water pump? Spridgets 12
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
tahoe healey Nano Magic scratch remove Austin Healey 2
F I can’t remove Wire wheels from new hubs - help Austin Healey 43
Basil 7 Ways to remove stripped screws Restoration & Tools 2
C How to remove entire dash panel on BN6? Austin Healey 4
crispy How to Remove the Exhaust Manifold?? [late BJ8] Austin Healey 27
hondo402000 TR6 TR6 Windscreen remove and now windows dont fit Triumph 3
edkap2002 TR6 fuel line compression fittings....how to remove Triumph 3
C MGB How do you remove "speed nuts"? MG 9
T TR4/4A Replacing rear pinion seal - remove driveshaft? Triumph 21
55modified Should I remove driver's side fender to work on footbox on my BN1? Austin Healey 14
R Remove engine/transmission advice needed Austin Healey 4
abarth69 Should I remove this section Spridgets 8
K TR2/3/3A What is best way to remove old nylon/rubber bush 525-020 from steering box shaft? Triumph 5
D TR2/3/3A wooodruff keys... how to remove Triumph 25
B remove BJ8 dash ? Austin Healey 1
Steve1970 TR6 Can I remove the shim on the rear gearbox mount [J-type OD] Triumph 11
4tecdog Access to remove Ariel Austin Healey 15
L Best Polish to remove surface scratches Austin Healey 12
T TR4/4A Does the water pump need to come off to remove the cylinder head? Triumph 5
C TR4/4A Best way to remove transmission fill port? Triumph 8
