TR6 Measurement required please.
malbaby
After the distance from the front face of the gearbox bell housing to the centre of the "H" dash support gear lever exit hole.
M_Pied_Lourd
If no one does this before I get home from work I can do this tonight....Would a measurement from the gearbox bell housing to shifter in neutral be ok as I don't have the body on the frame yet.
Cheers
Tush
B TR4/4A Measurement of "IRS" badge Holes Triumph 1
P Hoping someone has this measurement easily available. Austin Healey 3
R Tracking measurement Spridgets 2
M TR2/3/3A Steering Lock to Lock Measurement Triumph 3
Got_All_4 TR6 Differential side hub measurement Triumph 1
J TR2/3/3A Triumph TR3 cam shaft measurement Triumph 2
Jim_Stevens TR2/3/3A Quick measurement needed Triumph 4
R General Tech Cam measurement. Triumph 6
A BJ8 Measurement Austin Healey 7
F TR2/3/3A Front inner wing baffle measurement Triumph 7
bugedd Measurement of windscreen glass Spridgets 7
H BJ8 jet drop measurement Austin Healey 8
Got_All_4 TR2/3/3A Need measurement from front to rear axels something weared happened today Triumph 7
M TR4/4A Help with measurement please. Triumph 5
KVH TR4/4A Piston Size Measurement on Rebuild Triumph 4
M TR4/4A Door glass bayley channel clearance measurement. Triumph 4
I TR6 Bumper measurement needed Triumph 0
M TR2/3/3A Body Measurement differences between pre & post 60,000 TR3s Triumph 4
T Help ! Rear shroud measurement Austin Healey 14
J Measurement for aluminum oil pan Austin Healey 3
A TR2/3/3A Floor pan measurement Triumph 1
Healey Nut Toe In/Out measurement Austin Healey 8
J TR2/3/3A Need a measurement on a steering column please Triumph 2
D Spitfire Spitfire track width measurement request. Triumph 3
BlueMax Need a Measurement? Spridgets 2
Coyote1 Need a quick measurement Triumph 7
I TR6 Need measurement for tr6 kidney pad please Triumph 4
HealeyRick BJ7 Fender Measurement Needed Austin Healey 2
I Measurement Points Spridgets 5
I TR6 TR6 windsheild measurement please Triumph 1
budk1953 Measurement needed..... Spridgets 2
mrv8q TR6 TR6 Carb measurement Triumph 3
healeyboz strange measurement request Spridgets 29
chicken Correct measurement for door gaps [BJ7] Austin Healey 3
GregW Woops! need another measurement Austin Healey 8
GregW Measurement for shut pillar top piece BJ7 or BJ8 Austin Healey 6
64rocksprite RWA owners..I need a measurement Spridgets 20
B Request help with a [BJ7] interior measurement Austin Healey 9
Lin Measurement Help Please Austin Healey 8
A TR6 Need TR6 shift lever measurement Triumph 4
A axle leak and bearing spacer measurement Austin Healey 8
GregW What!? another body measurement? Austin Healey 7
Jack_Long Trim question - need a measurement Spridgets 5
aeronca65t Measurement of 1500 Dipstick? Spridgets 3
aeronca65t Measurement of 1500 Dipstick? Triumph 5
rick_ingram Measurement Requested Spridgets 4
Gray_Cat Bugeye Cockpit Measurement Spridgets 8
Lin Crank pulley measurement Austin Healey 2
A Frame measurement specs Spridgets 2
milemarker60 Hub Snout Measurement? Triumph 2
