Hey there Guest! If you enjoy BCF and find our forum a useful resource, if you appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please consider supporting with an "optional" low-cost annual subscription.
if it is the earlier style that is metal on metal with the horizontal clamp that just wedges the manifold to the pipe I used muffler tape around the joint before putting the clamp on & it worked great, no leaks.
A stock '66 uses no gasket, just metal on metal. Put it together carefully and be sure to use the bracket that attaches to the transmission (to keep the pipe from swinging and breaking off of the manifold) and you will have many miles of "quiet" driving.
Bill
OK I'll give it a try. I did succeed a couple of years ago but for the past year it loosens up and falls down. It is hard to feel or see if you have the V symmetrically captured the flared cast maniforld and the sheet metal tube/pipe.
948 and 1098 clamps are different so be sure you have the right one. Everything
has to be up to snuff or they can be a real pain. There is a reason they changed that system!!
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
