Carlbanan56
Hi, I have a potential problem with the intake manifold on my MGB -1975. A plug bolt on the manifold won't fasten correctly. The bolt is loose and when trying to fasten the bolt will spin forever. It seems that the threads inside the manifold are torn (check the attached files). I am guessing this i pretty bad and that the bolt has to be airtight. It looks like the threads deeper down are fine. Could I just get a longer bolt? Is there any other way?
Young and inexperienced :smile:
mezy
longer bolt and a copper washer should do the trick,
the only other alternative is a helicoil, (ptueeee), hate the things, not the best putting a steel thread into alumimium,
but it is a steel bolt afterall. or you could tap it out and put a bigger bolt.
YakkoWarner
That actually looks like its designed for some sort of fitting that has threads further down on the body. Is this a bolt you ever have any intention of removing again in your lifetime (or reinstalling whatever the original fitting was)?
bobhustead
I fear that if you do any drilling or other tooling, other than chasing existing threads, you will be putting metal crumbs into the intake. Its only aluminum crumbs, but still.
Carlbanan56
Carlbanan56
I tried removing the holding plate for the choke and throttle cable and this made it possible for the bolt to reach the new threads. So getting a new bolt that is a few millimeters longer should work.
H BJ8 blew out intake manifold plug Austin Healey 10
K TR2/3/3A Carbon buildup in an intake manifold and on spark plugs....... Triumph 3
M TR2/3/3A Blown Exhaust Manifold Gaskets Triumph 10
K TR2/3/3A Is it possible for an intake manifold gasket leak.... Triumph 12
C LCB header with 1500 single carb inlet manifold Spridgets 1
K TR2/3/3A Manifold gaskets....To use sealer or not? New ones look like fiber,old ones look like metal??? Triumph 3
K TR2/3/3A Thick flat washers for exhaust manifold studs? Triumph 0
A For Sale Mystery brass intake manifold Other British Classifieds 0
K TR2/3/3A Failed intake manifold gasket? Triumph 2
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
V MGB Replace late intake manifold angled breather with early model straight? MG 1
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
3 Exhaust Manifold/Headers BN2 Austin Healey 16
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
tahoe healey Exhaust Manifold Gaskets Austin Healey 5
P MGB 1980 MGB Modified Intake Manifold MG 7
K For Sale Triumph TR3 Intake Manifold Triumph Classifieds 0
Ripper01 For Sale- TR-6 Intake Manifold Triumph Classifieds 0
M WANTED......Cannon Inlet Manifold Triumph Classifieds 0
9 For Sale: Thermocarb - complete setup including special manifold Austin Healey Classifieds 1
Ripper01 SOLD-TR6 Dual Port Exhaust Manifold Triumph Classifieds 6
Ripper01 For Sale TR6 '69-72 Intake Manifold Stanpart V3108 Triumph Classifieds 0
nichola TR6 Water pump to manifold adaptor threads BSPT or BSP or ??? Triumph 17
steveg TR6 Fixing the intake manifold Triumph 8
D Wanted TR6 exhaust manifold w/air rail Triumph Classifieds 2
B AH Spares Fast-Flow Fuel Manifold Austin Healey 2
HealeyRick For Sale Bare 29F Block, Cylinder Head and Manifold Austin Healey Classifieds 2
B AH Spares Ltd. Inlet Manifold No. FUL 340 Austin Healey 2
Michael Oritt Intake manifold question Austin Healey 11
Michael Oritt Manifold Gasket Dressing/Sealant Recommendations Austin Healey 6
pbraun For Sale Weber downdraft Carb & manifold Spridgets Classified 3
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
GeorgeC Intake / exhaust manifold gasket install goop? Spridgets 2
D TR2/3/3A manifold studs..locktite or antiseize Triumph 5
steve00136 MGB Intake manifold alignment MG 4
AUSMHLY Gasket, Inlet Manifold to Exhaust Manifold BJ8 Austin Healey 8
Zitch For Sale TR-4A exhaust manifold Triumph Classifieds 0
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
AUSMHLY Exhaust Manifold Flange Stud Austin Healey 13
J Bj8 intake manifold to heat shield to carb gaskets Austin Healey 4
Lin Intake manifold drain pipes Austin Healey 29
R FFuel overflowing at Intake Manifold Austin Healey 10
BLong63AH Removal of Intake and Exhaust manifold. Austin Healey BJ7 Austin Healey 24
F TR2/3/3A SU 1 3/4 Carb to Manifold Insulating Block; '59 TR3A Triumph 6
AUSMHLY BJ8 Manifold, how many brass nuts? Austin Healey 2
crispy How to Remove the Exhaust Manifold?? [late BJ8] Austin Healey 27
T why would an intake manifold stud have both coarse and fine threads? Spridgets 8
