Magnetic ring in the Gearbox and Overdrive
AUSMHLY
Page 37 of the 3000 MKIII drivers handbook says:
Gearbox and Overdrive (A)
Remove the magnetic ring, filter gauze and clean it.
Where is the magnetic ring?
I removed the large brass oil drain plug to find a red fiber washer around the treads. Resting in the center of that plug was the oil pump strainer.
It seems whom ever rebuilt the overdrive installed 3 black fiber washers under the strainer. The size was just about same as the outside diameter of the strainer. I didn't see those in the break down diagrams. So I took the setup to my Mechanic. He didn't know why they were there and recommended I leave them out.
Thinking out loud. Maybe it was an after market strainer and needed the washers to keep it pressed up to make a seal against the bottom of the oil pump body? Are there any after market screens that are not the right size?
However with the 3 stacked washers under the screen, the center ring of the screen did seem touch the raised center of the brass plug. It seems the 3 black washers covered a lot of the bottom of the screen. That's a lot of screen area that's not doing its job. Anyone run across this?
Anyway, back to the where is the magnetic ring. It is listed in the Moss catalog #866-220. However Moss does not show it in the break down diagram.
MarkA
Yepp, the magnetic ring goes between the screen and the brass plug. BCS carries them and I just recently bought one from them. Someone may have put the washers under the screen to make it seat better if the screen had been flattened out. But then again, the screen may be flattened out a bit because of the washers they put under it!
Anyways, the magnetic ring sits in the plug cavity without touching the filter screen. It just lays down in there.
Mark
AUSMHLY
AUSMHLY
I can always count on you guys. Thank you.
What I find interesting is that the more I work on my car, the more I find the PO did not always do what was required.
We'll see what I find next on my maintenance items. The good news, every time I take a small project on, my car seems to benefit as a safer and better driver. Plus I learn along the way. Which in turn I can share here on the form when the same question comes up again. Been there, done that.
Cheers, Roger
Check to see if any thing in there is magnetic. You may just have them in there. I not they are available or you could get a better one with a stronger magnet from many sources (other than the usual folks) by googling for magnets. A strong one will help ancher those flakes in the brass basket form miss shifts.
Keoke
Hi Roger, origially there was a single ring that was some where between 1/16" - To - 3/32".--Fwiw--Keoke
bob hughes
When I drained my overdrive, and removed the washer from the brass screw on cap/ plug I did not realize what I had in my hand, it appeared to be one washer with lots of paste clinging to it, turned out to be three flexible magnetic washers and they will only go together when each is placed a certain way around - like poles repel - opposites attract
Bob
Keoke
Hi Bob, Yes I have seen them in that configuration too.---Keoke
6TTR3A TR6 Magnetic ring in the early gas cap Triumph 2
A Overdrive Magnetic Ring? Austin Healey 3
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
warwick-steve Magnetic Gearbox Drain Plug Austin Healey 28
HighAltitudeTR3 TR2/3/3A What is non magnetic metal and gets stuck in Pressure Relief Valve? Triumph 48
Geo Hahn Magnetic Drain Plugs Triumph 12
bighly Magnetic sump plugs / tranny plugs Austin Healey 0
sail TR4/4A Piston Ring Question Triumph 6
C For Sale New in box 3:54 ring & pinion Austin Healey Classifieds 4
Jim_Stevens TR2/3/3A Starter/ring gear engagement Triumph 11
K TR2/3/3A The chrome ring around the bakelite horn button? Triumph 4
J TR2/3/3A 87mm piston ring gaps Triumph 15
Jim_Stevens TR2/3/3A Ring gear shot? Triumph 26
B Snap Ring Plier Restoration & Tools 3
S CHROME RING, shift lever grommet ....? Austin Healey 3
T How do I clean sand out of a ring & pinion? Spridgets 2
dbenichou289 TR2/3/3A Headlight outer trim ring Triumph 6
dbenichou289 TR2/3/3A Carb Sealing Ring Triumph 6
DrEntropy MGB Ring Gear Roulette MG 12
S TR2/3/3A glass and ring into new bee hive sockets Triumph 15
JAV 3.5 ring and pinion Austin Healey 18
sundown TR6 Proper ring gaps Triumph 6
TomMull hydraulic fittings "O ring face" Restoration & Tools 6
M TR2/3/3A Another TR3 Piston Ring Gap Question Triumph 1
J TR2/3/3A Hastings Piston Ring End Gap Issue Triumph 16
P Identifying a Ring and Pinion Austin Healey 8
I TR6 Aluminum trim ring band removal Triumph 5
M For Sale bj8 ring and pinion gears 3:55 for sale Austin Healey Classifieds 6
T TR4/4A Attaching headlight trim ring Triumph 6
D BT-7 tri-carb ring gap Austin Healey 10
K TR2/3/3A Ring and Pinion Wear? Triumph 11
bfitz Zenith Stromberg O ring question Other British Cars 8
Sarastro TR4/4A Looks like I need a new ring and pinion... Triumph 30
J TR6 Ring gear repair Triumph 13
KVH General Tech Hastings Oil Ring Triumph 13
histerical Ring and Pinion Spridgets 8
H Wanted Herald headlamp Chrome Rim retaining ring Triumph Classifieds 0
T Question regards headlight ring 'thickness' for bugeye Spridgets 3
G Heater Control Valve AH BJ7 - O-Ring Placement[s] Austin Healey 2
Gliderman8 TR6 Starter not engaging into ring gear Triumph 32
JPSmit Question four - headlight trim ring Spridgets 9
tinman58 General TR Ring Gear @ 6000 rpm's Triumph 6
Marvin Gruber 4 ring vs 5 ring pistons Austin Healey 6
B Ring and pinion question Austin Healey 29
R Overdrive [Type A] brake ring gaskets Austin Healey 1
R TR2/3/3A Overdrive [Type A] Brake Ring Gaskets Triumph 14
C abutment collar retaining ring - 4-speed side shift gearbox Austin Healey 2
R BJ7 Gear reduction starter and starter ring gear orientation Austin Healey 17
T TR4/4A O-ring size on a A-type angle drive speedometer gear Triumph 10
