abutment collar retaining ring - 4-speed side shift gearbox
chuck1006
Hi,
The OD type mainshaft I found didn't come with the abutment collar retaining ring. Any ideas where to locate one? I see it N/A in Moss and not listed in Victoria British.
Thanks
Chuck
Agrandshort TR2/3/3A Revolving collar Triumph 1
newmexTR3 TR2/3/3A TR3 Shock tower spring collar Triumph 7
R General TR Spring collar flange thickness options Triumph 2
K TR2/3/3A Steering box install again...the collar with the pinch bolt? Triumph 9
B BJ8 vent window collar fused on Austin Healey 7
CJD TR2/3/3A Wire Wheel Locating Collar 108942 Triumph 15
19_again GT6 new shorter springs and shock collar fit GT6+ Triumph 10
1 Stuck oil seal collar MG 4
KLUTZ Hub re-install question... Grease collar position MG 7
F Lower valve collar...necessary? Triumph 1
F Looking for aluminum valve collar set... Triumph 10
F Valve collar replacement fiasco...need to vent Triumph 16
mrv8q TR6 74 TR6 mystery collar Triumph 0
J TR4/4A TR4A seat retaining clip Triumph 5
K TR2/3/3A Brake caliper brake pad retaining plate bolt hole? Triumph 16
Martinld123 Grease Retaining Cup Not Tight Fit Austin Healey 2
H Wanted Herald headlamp Chrome Rim retaining ring Triumph Classifieds 0
C How to attach escutcheon retaining plate to the escutcheon? Austin Healey 2
D Another question 1967 BJ8 top installation,metal retaining strip Austin Healey 1
S Problem removing front wheel bearing retaining nut Austin Healey 9
S Correct way to remove grease retaining cup from front hub? Austin Healey 7
D Drum retaining screws Spridgets 11
H Side marker lens retaining screw Triumph 6
F Looking for the retaining clip/brace... Triumph 1
angelfj1 Check your hub retaining studs Triumph 5
mgedit Side Screen Retaining Bracket Triumph 13
AH100M 100/4 Spiral Bevel axle hub retaining nut Austin Healey 1
sjuengst Hub extension retaining nuts Austin Healey 10
G Oil Filler Cap-Retaining Wire Austin Healey 11
S BJ8 Glove Box Door Retaining Bolt Austin Healey 5
Tinkerman Rear tranny flange retaining nut removal. HELP!!! Triumph 8
eschneider fuel pump lever pivot pin retaining shims? Triumph 3
B Condenser retaining screw Spridgets 5
E HELP!!! Can't get the retaining ring back on! Spridgets 18
jjbunn Soft top retaining bar Triumph 8
ronzet Tach and Speed-o-meter retaining brackets.... MG 15
Atrus Shifter boot retaining "ring" Spridgets 17
D Ideas for removing retaining ring? MG 3
MGretired Rear wheel cylinder retaining clip MG 9
bash Brake pad retaining pins Triumph 1
