MGC Lucas alternator/regulator
Jim Arsenault
I am currently working on a 68 MGC and am having no luck getting the new alternator and regulator to work. I installed a new wiring harness in the car and they lead to get rid of the Ford alternator that someone added at some point in the cars history. This lead me to suggest to the owner that it would be a good point to get the original alternator and regulator which he did find. After installed them I noticed that the ignition light illuminated with the key off and went out when the key is switched on. When I test the voltage at the “ind” terminal it reads battery voltage. Am I suppose to get zero voltage and continuity to ground at the “ind” terminal and then when the alternator starts making power it turns the “ind” terminal to battery voltage to create a balance at the ignition light? I’ve had the alternator to a shop to have it tested to see if it’s charging and they said it was although when the car is running it isn’t charging. Any help or tips would be appropriated. I’ve also been givin a used regulator to try and it made no difference although the guy who gave it to me didn’t know if it was any good.
Thanks, Jim
Platinum
Platinum
Thanks for that, Tom. I have that PDF someplace here but couldn't find it quickly. :thumbsup:
B TR6 Swapped Lucas to GM alternator Triumph 9
B Delayed charging Lucas alternator Triumph 1
S Stag Lucas 18ACR alternator conversion Triumph 5
T Installing a Lucas 16 ACR alternator on Bugeye Spridgets 10
M TR2/3/3A Moss Lucas elektrik alternator install? Triumph 5
J Moss / Lucas Alternator Conversion..... Spridgets 17
drooartz Lucas alternator ID Spridgets 7
B Lucas alternator question Triumph 14
C Lucas 2-wire alternator??? Triumph 1
NardisCNC Lucas Alternator Upgrade / Replacement ???? Spridgets 49
angelfj1 LUCAS 15AC Alternator - Need Diode Bridge Triumph 3
angelfj1 LUCAS ALTERNATOR AUTOPSY Triumph 1
jjbunn Need help to ID a Lucas Alternator Triumph 5
RobT Lucas Alternator Question Triumph 10
Brosky Excellent source for Lucas alternator repair Triumph 0
Alan_Myers Lucas alternator? Triumph 2
djk Lucas alternator conversion Spridgets 2
J For Sale Lucas 75150A Wiper Motor Other British Classifieds 0
M Replacement of Lucas HA12 with Lucas SA12 Coil Austin Healey 6
L TRW-Lucas Brand Master Cylinders Austin Healey 2
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
MGTF1250Dave T-Series Lucas Generator MG 1
T Lucas Flasher Unit Austin Healey 5
D Lucas Low-Tension Leads Austin Healey 1
Popeye General TR Connecting to Lucas switch grub screws? Triumph 5
Rob Glasgow Wanted Headlight Lucas Austin Healey Classifieds 4
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
B Wanted Lucas wing mirror Other British Classifieds 1
AngliaGT For Sale Lucas Headlight - used MG Classifieds 0
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
M Looking for Lucas parts catalogue British Motor Corp 13
AUSMHLY Lucas Generator C42 End Caps Austin Healey 3
Lin Lucas coil question Austin Healey 8
red57 Lucas 1748 horns Austin Healey 19
B TR2/3/3A Lucas, SU, and the rest Triumph 3
K TR2/3/3A Who owns the "Lucas " brand name? Triumph 7
K TR2/3/3A Do Lucas distributor points still have the" Lucas logo" on them.... Triumph 4
K TR2/3/3A What vehicle is this Lucas voltage stabilizer from? Triumph 8
F How do I get rid of "Lucas"? FORUM Navigation Questions 2
T Which Lucas dynamo does a BJ7 have? A C45?? Austin Healey 6
F T-Series Lucas m133 headlamp? MG 2
S BJ8 Ignition Switch - Lucas Part Number? Austin Healey 4
S Intermotor or Lucas Sport Coil ? Austin Healey 14
C General Tech Lucas Fog Lamps Triumph 2
K TR2/3/3A What is the little white fiber thing for that comes in the Lucas points box? Triumph 2
R LUCAS 17L Batteries for Healey 100s Austin Healey 3
C TR6 More fun with Lucas Triumph 5
S TR2/3/3A Rebuilding Dr2 Lucas wiper motor Triumph 16
AUSMHLY Led headlight conversion kit with Lucas headlight bucket Austin Healey 37
