RAC68
I need your IDEAS.
We have discussed sagging or lopsided rear car views and the primary solution offered was to replace or re-arch the springs … with the hopes they will settle evenly. This fix seems to be the only one because the Healey’s leafs are attached to the bottom of the axel housing and flexes above the frame. Although this suspension configuration provides a low center of gravity, the usual placement of spacers between the leaf and housing will lower the body rather than bring it up.
So, is there a way to even the body by adjusting suspension attachments?
As you can see from the pictures, the left side of my car is slightly lower than the right and, since I am not in the car, not produced by my body weight (but probably emphasized when I am). The interchange of Leaf Springs created no difference in measurements.
Although side-to-side measurement differences are something many would not bother with, they do represent a situation that a little adjustment could easily correct on most other cars. Let me be clear, I am not that concerned about the 3/8" side-to-side difference in my car but using it as an example in order to find a method I and others can use to deal with this type of problem. However, in my case, I like the look of the higher right side and would like to raise the left to match it.
So, how can we tweak the suspension to correct this type of condition? Since adding a spacer under the spring/housing attachment will not work (mentioned above) and tight-clearance eliminates the reduction of shackle length, would moving the leaf’s inboard attachment point downward do the trick? If so, what removable add-on can we create to allow us to us to easily adjust this contact point?
Ideas?
Ray (64BJ8P1)
Ideas?
Ray (64BJ8P1)
