General MG Looking at MGs
LNL
I have currently been mulling over purchasing an MG or a TR6, having always loved the look, the lines, the absolute originality of design.Call it a mid-life crisis, bucket list item, or just plain desire but the thought has been with me for a long time.What I wish to know, if you can assist, is what would I be looking for while inspecting one of these fine cars?Do they come with disc brakes, or drums?If drum brakes, is there any 'kit' or the ability to transfer the braking system over to disc?Not sure which models have the overdrive(unless they state it), so that to brings about a want in the car.Some do not come with the wire rims; so would be curious as to what wire rims would be the best for them, as well as what tires would be the preferred make and size to have the performance a vehicle like these deserves.I am also a true Canadian driver, which means all seasons. so winter tires; what would be recommended for these vehicles?As you can tell, I am literally studying what is required, what to look for, what I should be listening for on a test drive, etc.I have looked at a few, and wonder if you could give some information as to the overdrive asked about, and any other help, if it is at all possible.I would be extremely appreciative of your assistance, and thank you. My list, with what info I have, is here:1969 MG/MGC 6 cyl. (Overdrive?)1970 MGB/GT Is this a 6 cylinder? Overdrive?1975 MG/MGB Roadster Is it a 6 Cyl.? Overdrive?1974 MG MGB/GT Cylinders? Overdrive?Most respectively, LNL
Sopwith_Camel
ok thats a long list
I would not recommend wire wheels for winter driving. and yes, I drive mine in the snow I have two sets of rims.
all "B"s and "B-GT"s are 4 Cylinders unless they are the V8 and they will be labeled that way.
the "C" and "C-GT" from 67 to 69 are the 6 cylinder cars. and can be spotted by the extra bulge on the hood.
Over drive is an optional extra but should be mentioned in any ad.
I believe they all came from the factory with front discs and rear drums. which is fine for modern traffic. but rear disc conversion kits are available.
if you can find one with the optional oil cooler that would be good.
Here is a question for the rest of the gang do the 70s Bs have the air injection system that the midgets had?
Mickey Richaud
Good info there, although I'm not sure the oil cooler is a necessity in Toronto. Lots of debate fodder there...
As for the air injection (emission control) system, those began in '68, I believe.
Oh, and welcome to the party, LNL! And good luck with your search.
:cheers:
Mickey
Sopwith_Camel
in that case if you can find one where it has been professionally removed you will get some horses back.
As for the oil cooler. good cooling is always a plus, and you will be driving it on the hotest days of the summer. it was over 30c here and I'm much further north.
There is very little horsepower lost with the emissions equipment used on the MG. Removal of the equipment may provide an increase of 2bhp or so. I doubt one would feel this in the seat.
Sopwith_Camel
was it more on the midget 1275 ? its one less belt to deal with if nothing else.
Sarastro
Seems to me you need to spend some time researching the cars you are interested in. The archives here should be a help, as is a lot of browsing through eBay. You can learn a lot from ads. Also, you can just Google them.
Here's another idea, one I've done a few times: when you've sorted through the options and have found one or two types of cars you like, buy a Haynes manual for each of them. It will cost only about $15-$20 each and you'll get a lot of detailed info on them.
If you're starting without a lot of information, I'd probably suggest a STOCK MGB or TR6. There are plenty of them around, they're not expensive, parts are cheap, and they're modern enough to drive on a freeway or use like a real car. (Unlike my MG TD, for example.) You'll have fun with them. Watch out for rust, avoid heavily modified cars, especially engine swaps. Remember that cosmetic restoration is at least as expensive as mechanical, so make sure the car looks decent, not just runs well. Forget about "mileage" (which is meaningless in a 50-year-old car, which probably has had three engines, five transmissions, two speedometers, and eighteen brake jobs), and focus on condition. Approach it as you would any other type of used car--a couple hundred bucks for a pre-purchase inspection is worth it, if you are unsure of your ability to evaluate a car yourself.
Sopwith_Camel
yes Rust is you main enemy. buy the best chassis you can, take a magnet with you and check the sills/rockers.
doing a brake job or a new exhaust is easy, cutting out and replacing the door bottoms are a big job.
and make sure doors shut well convertibles can sag in the middle.
read up on wikipida, hemmings , mg enthusiast magazine about the cars your interested in.
JPSmit
Congrats and welcome! an MG or a Triumph is a bold move for Toronto - not just for the rust but for the heat and ground clearance.
That said, there are lots of choices out there. One of the best things you can do is join a club locally - not just for expertise but, because they typically have the more realistically priced cars for sale. (I find Canadians typically have an over inflated sense of what these things are worth)
MG Car CLub: https://www.mgtoronto.com/
Toronto Triumph Club: https://www.torontotriumph.com/
British Saloon Car Club of Canada: https://www.bsccoc.ca/ (one of the biggest and widest clubs)
Also, British Car Day is on the 20th of this month in Oakville - https://www.torontotriumph.com/BCD/ - the largest one day British Car Show in North America. It is worth attending, partly because lots of cars will be for sale, partly because there will be lots of options and especially because there will be lots of advice.
I might also invite you to consider two other options. 1. buy an MG or Triumph and get a winter beater - these British cars rust badly at the best of times and will be a struggle to keep warm. Beaters don`t cost a lot and will save the `nice`car. Also, there are a number of other saloon options out there - Austin/ Morris/ Vauxhall etc. that are all hardtops, not a sexy but good solid options for year round use.
BTW where abouts are you in the city? I am in Etobicoke
L
LNL
Appreciate all of this from all of you.
It is a big help, and it makes my shopping for one of these so much easier!
Thanks to all of you who have replied.
Glad I joined.
LNL
Sopwith_Camel
I think JPSmit has a great point go to the british car day. and ask owners if you can sit in the cars that you are considering.
yes rust is a major issue for these as a winter car.
but on the really cold days the metal door latches will freeze up solid. so you will be off the road. its a safety feature.
sim looking for 2 valve spring kippers for a 948 Spridgets 3
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
jfarris Looking for service options for a 2016 Lexus NX300h in Tyson's Corner VA Other Cars 0
E TR6 looking for info on doing a T5 swap Triumph 5
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
BJ8Healeys Location of VIN tag, 1964 Sprite HAN8L43421 (I know it's stamped on the frame. Looking for the tag.) Spridgets 8
T Looking for "BillMs rear transmission mount" Spridgets 2
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
V Wanted Looking for SU HIF4 Linkages. MG Classifieds 0
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
JPSmit A fairly specific looking bolt Spridgets 10
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
T Looking for recommendations re using a Seacan for vehicle storage Spridgets 7
BJ8Healeys Looking for BJ8 VIN HBJ8L40768 Austin Healey 0
M Wanted Looking for genuine Austin-Healey bonnet badge Austin Healey Classifieds 1
M Looking for Lucas parts catalogue British Motor Corp 13
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
idlehands GT6 What gotchas when looking for a GT6+ Triumph 10
BillyB62 TR2/3/3A Looking for the Owner of a TR3 Triumph 5
Got_All_4 Wedge Looking at a Local TR8 For Sale Little Ruff Triumph 1
roscoe The future is looking up Austin Healey 4
DrEntropy Looking thru old pix Other Cars 8
T 1972 MGB GT for sale in San Francisco, looking for a good home MG Classifieds 1
vping T-Series Looking for TD Part # MG 3
T Wanted Looking for a solid [but doesn't have to be perfect] 100-6 Austin Healey Classifieds 17
F GT6 Looking to sell - in progress restoration Triumph 19
Lin Looking for a part Spridgets 1
Lin MGB MGB and MGC - looking for a part MG 1
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
Y Wanted Looking for running 3.5L MK V engine Jaguar Classifieds 0
steveg TR6 Newbie looking for hopup guidance Triumph 15
Guido36 Looking for upholsterer recommendation for Healey 100 in Southern California Austin Healey 5
SherpaPilot TR6 Looking For Opinions on Seat Covers Triumph 9
S Wanted Looking for a new/used crankshaft for a 100-4 Austin Healey Classifieds 0
R TR6 Looking for Oil Filler Cap TR4/TR6 Triumph 7
pbraun Looking for 64 or 65 Mokes British Motor Corp 0
T Looking for a temporary cup holder - but my heart is pure Spridgets 9
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
catfood Looking for suggestions - ignition issue Austin Healey 6
W Looking for engine rebuilding 100-6 Austin Healey 12
C Looking for SoCal restoration shop Austin Healey 4
