Lock core removal
bugedd
Its been a while, but I need to replace my combo switch, and I can't recall how to remove the lock cylinder from the switch. Can someone refresh my memory?
dklawson
Combo switch? Do you mean ignition switch?
If that is what you mean, you need the key and the lock out of the dash. Remove the mounting nut from the threads and examine the sides of the switch housing. Look for a hole. Put the key in the lock and turn it slowly while looking in the hole. Eventually you should see a small pin, probably brass. Depress that pin with a bent paperclip or similar and then pull the core out of the lock body using the key.
nomad
Any way to do this without the key? I have some parts switches that would be useable if I could get the lock tumbler out or know what key they take.
Kurt.
RyanBez
Kurt.
It really depends on when that safety feature came into place...the make it so you need the key to prevent people from hot wiring the car...imagine how easy it would be if you just needed to pop the tumbler out and replace it with your own!
I really don't know when they started doing this, but I imagine it has been for a while...
nomad
Well I realize the purpose of the original design but was hoping there was a trick. I imagine a lock smith might be able to use picks or have the few key codes the british used so when I have time and find a smith with time I may just dump a pile of stuff on his bench!
Kurt.
dklawson
Well... if you don't have the key and you are replacing the core anyway... there is always the electric drill.
nomad
True Doug---the easiest would be if someone had the different keys for the various Lucas lock tumblers. As I remember there were not that many.
Kurt.
dklawson
I have never been lucky enough to find the key code numbers on the locks in any of my British cars. However, supposedly if you have those numbers there are locksmiths who can cut you new keys for old locks. I seem to remember one or two sellers on eBay who mentioned they offer the service.
nomad
Yes, I have them saved and have had keys cut as to the code. But, like you, I can't see any numbers on the switch tumblers. Had them cut for boot locks and spare ignition by the number on the existing key. Boot [trunk] lock numbers are stamped on the square of the latch handle inside the trunk.
Kurt.
gprtech
The requirement to have the key to remove the lock cylinder started in the early 1950s. Prior to that, you could remove a nut on the back of the lock and the cylinder would come out.
I can rekey any of the old British car locks. I also have complete "tryout sets" of keys for most of the early codes series, including FP,FA,FS & FR so that I can get the cylinders out or determine the correct codes.
I can give quote on request.
www.key-men.com
gpr@key-men.com
nomad
Agree Bill, everyone needs access to this service. I'm going to be hunting up old switch's!
Kurt.
mikecyc72usa MGB 71 MGB ignition lock core removal MG 3
D Door Lock Tumbler Austin Healey 4
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
T TR6 Steering Wheel Lock Triumph 2
A 100/6 BN4 Door Lock Austin Healey 15
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
V 1969 Sunbeam Alpine coupe glovebox lock removal Sunbeam (Rootes) 0
ActionJackson Spitfire Steering Column Lock Triumph 3
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
Michael Oritt Vapor lock--a foolproof if a bit radical solution... Austin Healey 8
G Glove Box Lock Austin Healey 2
J Steering Box Adjusting Bolt Lock Nut Austin Healey 11
M TR2/3/3A Steering Lock to Lock Measurement Triumph 3
M TR6 Glove box lock. Triumph 4
K TR2/3/3A Steering wheel Lock Nut? Triumph 2
A TR2/3/3A TR3 door handle lock cylinder Triumph 4
red57 Changing Lock Barrels Austin Healey 15
6TTR3A TR6 TR6 Trunk lock set screws Triumph 2
I General TR Ignition lock barrel help Triumph 1
M TR2/3/3A Rocker Shaft Pedestal Lock Washers Triumph 4
P Brakes lock up when rolling forward Austin Healey 4
Got_All_4 TR6 How does this steering lock come off Triumph 9
60BN7 Adjustable Steering Column Won't Lock Austin Healey 9
S Glove Box Lock - BJ8 Austin Healey 3
S TR2/3/3A glove box lock Triumph 27
S TR2/3/3A T handle trunk lock Triumph 14
wangdango BJ8 Glove box lock? Austin Healey 1
T TR2/3/3A vapor lock? Triumph 44
Scotsman TR4/4A Steering Stop Lock on trunnion Triumph 9
toysrrus TR6 "how to un-lock a boot lid"??? Triumph 11
vette Vapor Lock, Out of Gas, Hmm, Ahh, Don't know? Austin Healey 32
Popeye TR4/4A Trunk [boot] lock removal Triumph 12
Steve P. Info: removing anti-theft column lock on later cars Spridgets 0
M TR4/4A Trunk/Boot lock key code?? Triumph 4
Got_All_4 Wedge Glove box lock removal Triumph 7
C BJ8 Rebuilt Engine and Carbs - Vapor Lock and Misfires when hot Austin Healey 7
AUSMHLY Going price for BJ8 glovebox lock Austin Healey 6
R Brake Lock Up Austin Healey 17
S TR2/3/3A Spring pans, trunions, and lock washers Triumph 6
C General TR Lock tab vs Loctite Triumph 5
Tinkerman TR2/3/3A Continuity Check on Tranny Lock out switches Triumph 2
Tinkerman TR2/3/3A Tranny lock out switches Triumph 9
CJD TR2/3/3A Lock Help...you out there JP? Triumph 29
Brinkerhoff General MG Installing Moss lock clips on door lock barrels , newer Midget MG 0
longbridgehealey Bugeye lock barrel and combination switch Spridgets 2
T TR6 Brake caliper lock after some driving Triumph 3
J Where To Find BJ8 Key Door Lock ,Trunk & Glove Box Numbers ??? Austin Healey 3
Tr3aguy MGB MGB glove box lock breakdown or photos MG 4
richberman T-Series MGTD suicide door lock lever orders MG 0
