Laycock Pressure plate E-bay
71tr
As rare as these seem to be the UK ebay website has them quite often.
AlanT
The Laycock cover is nice but for that kind of money I would want a Laycock driven plate to go along with it.
Alan T
S For Sale 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUNDLE Austin Healey Classifieds 1
KVH General TR Type A Laycock Overdrive Questions Triumph 8
H TR2/3/3A Manual for the Laycock de Normanville Overdrive Unit Triumph 14
steveg Indirect interest xpost: Laycock moved to El Cajon, CA Austin Healey 5
M Laycock Type A Triumph 8
R laycock j-type o/d documentation [manuals, etc] Triumph 9
boxofparts MGB MGB Laycock Type D overdrive 3 syncro MG 8
YankeeTR Some interesting info on Laycock de Normanville OD Triumph 11
rovernut Laycock Overdrive Torubles MG 2
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
J MGB Tire pressure for 1980 MGB MG 14
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
G High Oil Pressure Austin Healey 2
M Overdrive Pressure Test Austin Healey 2
PAUL161 T-Series MGA pressure plate verses MGTF pressure plate? MG 6
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
A MGB Oil pressure MG 9
K TR2/3/3A Oil pressure readings Triumph 10
6 E-Type brake light pressure switch location Jaguar 5
J Oil Pressure Relief Valve Austin Healey 3
L Oil Pressure Gauge Austin Healey 5
LAW75 Oil Pressure Austin Healey 4
D TR2/3/3A oil pressure line venting? Triumph 4
S TR2/3/3A pressure relief understanding Triumph 9
AUSMHLY BJ8 Overdrive Pressure Loss Austin Healey 11
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
K TR2/3/3A TR6 Gearbox in a TR3.....Use a TR6 clutch disc and pressure plate or Triumph 7
R Bugeye oil pressure line Spridgets 9
K TR2/3/3A Oil pressure readings Triumph 3
K TR2/3/3A Oil pressure at Hot idle? Triumph 3
S TR6 Oil Pressure Light Triumph 2
BobHaskell SU Fuel Pump Pressure Austin Healey 1
Hamish Racing TR2/3/3A Low oil pressure warning Triumph 0
K TR2/3/3A Tire pressure and ride comfort? Triumph 9
Kurtis No oil pressure Spridgets 5
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
V Braking Oil Pressure Austin Healey 16
N Suspected disaster - but it went well. Oil pressure restored. Austin Healey 1
K TR2/3/3A Optimum Tire pressure for a TR3 daily driver? Triumph 5
B TR2/3/3A Bubbling in brake reservoir. No pressure in lines Triumph 5
S TR2/3/3A Oil pressure gauge removal Triumph 11
SherpaPilot TR6 Brake Pressure Problem Triumph 8
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
