It's hot as Hades here in Irving at the VTR....
G
Guys, I'm dying here. It got up to 110 yesterday here in the Dallas area. The hotel for the headquarters for the VTR nationals is quite nice, but 9 bottles of water per day (over $20, where is Walmart when I need them)and I am still dehydrating. The good news is most of the rest of you are suffering this same heat wave.
The convention is a bit unorganized but ok. Not a huge turnout (less than 200 cars) but I am impressed that there is a core group of diehards that do these things every year and have driven in from California to the East Coast. Met this guy from Cal (Herman somethingorother), nice guy, that is 71, drove his pristine 250 in all the way and still looking chipper. This guy has forgotten more about Triumphs than I will ever know. Needless to say, I am constantly picking his brain!
I will try the Autocross tomorrow, hope I don't blow that rear seal completely and screw up my clutch. That 9 hour drive home is bad enough without limping home.
Wish me well. That is , that I survive the heat. They don't give ribbons for coming in last in races, but I will be a winner anyway...
Like is good.
Rock on.
Bill
jerrybny
Re: It's hot as Hades here in Irving at the VTR...
Well at least its a dry heat Bill. /ubbthreads/images/graemlins/wink.gif Have fun and good luck
Mickey Richaud
Thanks for the report, Bill. And I feel for ya in the heat. Stay out of it as much as you can.
Mickey
bobh
Herman is probably Herman van den Akker. He's the person who designed and developed the Toyota Supra transmission conversion. He has a TR250.
jsneddon
gsalt57tr3
Doesn't Herman also own a TVR?
trboost
Bill,
You should absolutly pick Hermans brain. He is one of the nicest guys on the planet. He & his wife, Helena make this journey like you & I go to the corner store (although you seem to get around). He is amazing in his dedication to the TR crowd. He is the inventor of the Toyota trany conversion, Blind Moose shock conversion & other TR dedicated products. Herman also does machine work for many of the vintage racers in his area. A retired airplane mechanic, he is talented. He loves to talk TR and make friends. Enjoy him , he's a dying breed.
Have a great time and thanks for the updates for the crowd that couldn't make it.
Bob_Muzio
Herman also has a TR6, is a retired machinist/tool maker and a great friend. He's driven his TR250 from LA to Portland, Maine for a VTR convention, several TRF Summer parties, the pacific northwest for events and more. Quite dedicated to the hobby. Tell him that Bob says "Hi"
Bob Muzio
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
Overdrive45 Stalling at Traffic Lights in Hot Weather Austin Healey 20
F Hot Ignition Coil Austin Healey 6
T TR6 Perfectly tuned TR6 wont start when hot. Triumph 11
T General Tech Running hot Triumph 8
KVH TR4/4A Hard Start When Engine Hot Triumph 20
TR3MT TR2/3/3A Hot Gear Shift Lever Triumph 12
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
D Lumpy Idle When Hot Austin Healey 2
K TR2/3/3A Thermostat for hot summer driving? Triumph 1
S TR2/3/3A Clutch pushes hard when engine is hot Triumph 4
7 General TR Hot rod Triumph 0
K TR2/3/3A Oil pressure at Hot idle? Triumph 3
R General TR Emergency hot wire - because you never know whats next Triumph 2
K TR2/3/3A Hot day coolant overflow issue.... Triumph 1
F TR6 Pegged out hot while cold Triumph 7
sparkydave Trouble running hot Spridgets 10
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
K TR2/3/3A Front brake rotors hot to the touch...... Triumph 6
T 1993 xj v12 red hot catalytic converter Jaguar 6
M TR2/3/3A TR-3A Compresson check hot vs cold Triumph 5
Bob_Spidell Running hot/Overheating Austin Healey 44
G TR4/4A Flasher Unit...VERY hot Triumph 10
Got_All_4 General TR Anybody Hear or Use This Hot Spark System? Triumph 10
pkmh How hot can it [temperature gauge] get? Austin Healey 4
dougie DD300 Runing Hot Austin Healey 6
R TR2/3/3A TR 3A running hot at high rpm Triumph 12
glemon Hot Shot Other Cars 5
D Been waiting for a hot day run Austin Healey 4
HighAltitudeTR3 TR2/3/3A Running a little hot... Triumph 14
J TR4/4A Too hot to drive a convertible Triumph 14
T Bj7 Overdrive slipping when hot Austin Healey 11
P 100M overdrive disengages on hot engine/transmission Austin Healey 9
F TR2/3/3A Starts Cold, Not Hot Triumph 12
M TR2/3/3A Why is my coil so hot? Triumph 6
D TR4/4A how hot does the timimg chain cover get? Triumph 15
F TR6 sticky valve when hot Triumph 4
Lutz Kramer Hot cams and advanced ignition Austin Healey 57
HealeyRick Hot Volvo Other Cars 0
simpzimmer Spitfire Won't suck gas when hot. Triumph 7
steveg Healey hot weather driving observations Austin Healey 2
bugedd Hot legs and hood top bow Spridgets 15
Geo Hahn TR4/4A Stumble off Idle with Hot Engine on Hot Days Triumph 4
N Jet Hot??? Spridgets 13
T TR2/3/3A Thermostats in Hot Summers and Moderate Winters Triumph 10
S Hot tip: seal for fuel tank sender Austin Healey 9
aeronca65t General TR Kastner Cup video walkthrough of hot pits Triumph 1
