    BCF is a resource offered at no cost to the Little British Car community. We do not require you to pay to play here. However, if you find BCF a useful resource, appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please support the forum with an "optional" low-cost (less than many car club dues) annual upgrade. There are some benefits to upgrading!
It lives!
Finally got around to connecting the exhaust and firing up the Midget (it has been sitting for a few years).
Didn't want to start at first (seemed to get no spark). I double checked the static timing and it was OK. Firing order OK ... wait! I had the correct order, but was off by one position on the distributor. So it should fire now ... nope! What the heck? Started double checking... Argg when I switch the plug wires around I accidentally pulled the low tension wire off the coil. Now it should fire! Vrooom.
It started and ran iddling at 2000. Oil pressure shot up and the temperature hit 185 in a few minutes then the t-stat opened and the engine came up to operating temperature. Checked for leaks and was going to adjust the carbs, but too many fumes in the garage. I'll let the garage clear out and then set the carbs.
This is the engine that was originally in the Midget, but then was put in the Sprite with the SC, and is now back in the Midget with dual SUs. Eventually, I hope to fuel inject it and turbocharge.
Anyway, after I get the carbs sorted it will be on to bleeding the clutch and checking the brakes. Then testing the transmission and replacing any leaking seals (like the rear end pinion seal)
Mickey Richaud
Fun, ain't it? :thumbsup: :thumbsup:
Congrats!
Mickey
Gundy
Like there was ever any doubt YOU would get that puppy fired.
WTG :cheers:
Trevor Jessie
Well I spent 45 minutes trying to find a vacuum leak causing high idle. Turns out the cold idle screw wasn't turn all the way out on the front carb. I really need to get some new glasses. :frown:
Morris
I wish glasses would fix my problem... I need a new brain. :wink:
drooartz
Well done!
Trevor Jessie
Thanks,
I can not remember which cam is in this engine, but I know it doesn't want to idle well below 1000 rpms like the other one. I'm going to fix a few leaks and try to get the clutch working before it gets too hot in the garage.
I'd post a video, but frankly ... it is just pretty much bog standard at the moment.
I'm kinda of anxious to drive it again. If I drive it for a few weeks, then it will make my Sprite seem FAST again. :wink:
jlaird
Nice Trevor, well done.
Trevor Jessie
Clutch is now working and the brakes pass initial inspection. I'll need to do some road testing, but the transmission seems to be OK. I think I'll go ahead and get it insured as a road-going car and get some new license plates. I'll go ahead and put the bonnet back on and clean it up a bit.
I think I'll rework the Datsun gearshift this evening if it cools off a bit. Then I can clean up the interior. It's not a bad little car I'm not sure why I let it sit so long.
waltesefalcon It Lives! Other Cars 8
dougie The Hemi Healey Lives Austin Healey 1
mrv8q TR6 It lives, [Again] Triumph 2
B TR2/3/3A After a beating, the tunnel still lives Triumph 6
J MGB It Lives! MG 2
T TR2/3/3A TR3 lives after 20+ years Triumph 0
toysrrus Who lives in or near "LUMBERTON, NJ"? Triumph 1
waltesefalcon It lives Triumph 4
frankenstang57 It lives again... Triumph 18
Sopwith_Camel it lives Spridgets 8
6 Pops Bugeye lives Spridgets 16
elvacar Elva Courier - It lives Other British Cars 11
BobbyD Blind Moose Lives.......Finally Triumph 17
H TR2/3/3A My TR3 -- It Lives! Triumph 8
Moseso IT LIVES! Triumph 13
PHerder Tequila Brad's engine stand LIVES!!! Spridgets 0
19_again The Prince lives on MG 14
HAN8L1965 1098 Lives Spridgets 3
Camshaft RIO LIVES! MG 5
Mickey Richaud Wedge THE TR8 LIVES! Triumph 31
Jack_Long It lives! Spridgets 16
Monark192 Vroom Vroom - another one lives! MG 2
tony barnhill Kenny - IT LIVES!! MG 36
rovernut Rover Lives ..Rover Lives.....well almost Rover / Land Rover 8
N It Lives! Triumph 5
B After 31 years it LIVES!!!!!!! Austin Healey 2
G How much snow where your Triumph lives? Triumph 30
LastDeadLast She lives again!!!! Triumph 3
frankenstang57 it lives for now... challenge car Latests Triumph 0
D It LIves!! Bwahahahaha Triumph 14
Randy Forbes It LIVES!! Austin Healey 7
Steve It lives!!! MG 7
A Which one of you lives near Savannah, GA? MG 1
