Installing the windshield frame to cowl seal ?
Ed_K
I am installing a new windshield frame to cowl seal on my 65 BJ8. I was able to get it into the channel all the way except for the last 3 or 4 inches on each side were it starts to make the sharp curves at the ends. Does anyone have a recommended technique for getting it to go in the last few inches on each end ? Thanks in advance for any suggestions.
Keoke
HI EDK,If you have enough material to go around the corners you can take a flat nondamaging tool and press it in to the slot. I use a plastic PPG tool that is shaped like a chisel on one end and has a gentle tappered shape on the other. A little soapy water may help it slide in.---Keoke
Ed_K
Ed_K
Thanks Keoke, I used a screw driver to get the rest done. I'll try warm soapy water and a " helper ". /ubbthreads/images/graemlins/hammer.gif
GregW
Platinum
Another trick is a heat gun. Not too hot, but just enough to get the rubber to flex a little easier.
Some brands go in easily. I returned the Moss one because it just wouldn't go in. They were great about it. The one frome AHSpares slide in nicely and doesn't curl up at the outside bend where it curves.
Ed_K
Ed_K
After spending another two hours with hot soapy water, various rounded off old screw drivers, and my Dad's help. I was still not able to get the new moss seal into the channel on the bottom of the windshield frame for the last 4 inches on ether end. I didn't check the dimensions yet with my dial caliper but the channel " has to be " smaller at both ends. Perhaps when it was shaped at the factory, the channel was deformed ? Per T.H. I'll try one from Austin Healey spares.
... T.H.. did you slide yours in from one of the ends ? I couldn't get mine to slide in more than 1/4 " before it became an immovable object. I was able to push it into the channel using a small rounded off screw driver, ( except for the ends ), an 1/8 of an inch at a time. Sliding one in would be worth double the price of the one I have tried.
Yes, I was able to slide it from the end using soapy water. The flap which fits against the body is a little larger and helped cover some paint flaws (the Moss one is smaller than original so be careful if your car was painted with rubber in place) and sat smooth on the body. Some caution should be used not to stretch it cause it may slide back when hot. I let it sit in the sun for an hour before I mounted it onto the car.
Good luck to you.
tomshobby installing windshield Spridgets 3
Tinkerman TR2/3/3A Installing botton rubber on windshield Triumph 7
K Installing windshield finishers MG 7
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
S Installing a Radiator Fan Austin Healey 9
G Installing New Rocker Shaft Assembly Austin Healey 3
W Need advice on installing new side curtain glass Spridgets 1
Bayless Help please installing bonnet release cable Spridgets 8
M TR6 Installing Retrosound? Triumph 4
S TR2/3/3A Installing the distributor pedestal. Triumph 3
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
A TR6 Installing differential and transmission Triumph 10
Z Installing Toe Board Panels Austin Healey 1
K TR2/3/3A Installing Brake Caliper pistons into the bore? Triumph 21
CJ Burton MGB-GT Installing Seat Covers for 1962 - 1967 MGB GT MG 0
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
B Installing cam bearings 1275, can I do it? Spridgets 1
bighealeysource Installing stainless steel brake hose on BN2 Austin Healey 5
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
steveg TR6 Installing adjustable trailing arm brackets Triumph 7
T Installing Garmin GPS in a BJ7 Austin Healey 19
F Installing AC in my 1960 Healey Austin Healey 14
S TR2/3/3A technique for installing a door Triumph 5
R TR2/3/3A Installing wiring harness in steering column Triumph 59
R TR2/3/3A Installing gas tank Triumph 6
C Installing rubber grommets in firewall? Austin Healey 6
S TR2/3/3A installing a fuse in the red tail lights Triumph 4
S TR2/3/3A installing the wiring harness Triumph 8
R Installing Sprite Luggage Rack Spridgets 9
Lukens TR2/3/3A Installing a throttle. Triumph 2
J Powertune booster for a bj8 , trouble installing Austin Healey 2
B TR2/3/3A Installing dzus fastners in bonnet Triumph 8
D Prepping Floors Before Installing Interior Restoration & Tools 6
drooartz Installing front hubs, tips? Spridgets 15
E TR4/4A Wiring the horn when installing a Moto -Lita steering wheel Triumph 4
K TR2/3/3A Installing Moss wheel spacers? Triumph 5
D BT7 tri-carb installing my crank Austin Healey 4
aero3113 Installing Front rotors to hubs Austin Healey 2
C Advice for installing a 3000 Grille??? Austin Healey 7
B MGB Installing new upper fulcrum bushings MG 5
B MGB Installing upper fulcrum bushings MG 0
S TR4/4A procedure for installing gauges etc Triumph 0
I Tips for installing intake manifold plugs in a stock Bugeye? Spridgets 6
55modified Help installing toggle dip switch on dash for lights. Austin Healey 23
TRMark TR4/4A Installing a new windscreen Triumph 9
55modified Rear anti-roll bar. Is it worth installing on a BN1? Austin Healey 22
T Installing a Lucas 16 ACR alternator on Bugeye Spridgets 10
KVH General Tech Installing the Pistons and Rings Triumph 7
T Need advice for installing a Winner's Circle Panhard rod on a BE Spridgets 4
6 General Tech Installing New Oil Pressure Gauge MG 5
