How to remove dead animal smell from interior
bluemiata90
I don't know if this is the place to post this message, but here goes. I'm looking into purchasing an MGB and the owner stored(deposited) the car in a garage for 5 years and never looked at it. A raccoon got inside the interior and died in there about 6 months ago. Needless to say the odor is sickening. Does anyone know how to get this odor of the interior without replaceing the seats and carpet. Is there any kind of powder or spray that will remove the smell.
help
scott
A
aerog
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by bluemiata90:
help
scott
<hr></blockquote>
You might try the liquid "nature's miracle". It's used for removing pet odor (the kinds that just won't go away, ahem). I don't know of any other kind.
You might also call your local ServiceMaster and ask them for advice. They usually get called out to de-odor and clean airplanes (from airsickness, etc), and other odd cleanup cases.
One word of warning: once you get involved with spraying anything in an MG be really careful to dry it out completely. I know you mentioned "not" replacing the interior, but in the long run a brand new interior might be the best way out - they're available in a variety of colors and qualities.
mts3
Member
If the car has the original style carpet (not glued in), you can just remove the individual pieces and clean them.
Carpet sets can be had for under $200; it may just be best to replace it anyway.
Like someone already said, anything that you have to spray will involve water (bad) to rinse.
doug noll
Member
Scott
I had good luck by using the following method after a certain idiot left town with fish bait
in the locked trunk of a luxury company car over
a hot, long, 4th of July weekend.
Find a way to encapsulate the car. I'd suggest
a large plastic painting cover from your local
hardware store. (cheap and easy) Buy at least two
large cans of Lysol spray and some strapping
tape (you know, the kind with the plastic strands
in it). After closing up the car with the cover,
use the tape to hold open the valve of the Lysol
can, and throw 'er in. Let the Lysol do its work
for at least 12 hours, and toss in the next can.
After that, evaluate the situation, and if you
detect an improvement(you should), determine if
mother nature and fresh air will do the rest of the job, or you should use some more Lysol. The
method entailed here is way cheaper than new car-
peting and upholstery, and may well get you through the summer, or even longer.
Good luck, and Cheers,
Doug Noll
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
CARSINC How to remove factory contact cement? Spridgets 9
K TR2/3/3A " do not remove the fan as it is essential for establishing crankshaft balance" Triumph 9
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
newmexTR3 TR2/3/3A How to remove thrust washer from lower wishbone & trunion Triumph 7
jfarris TR2/3/3A Rear Shock and link remove and replace Triumph 1
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
drooartz Hose from water pump to head, remove water pump? Spridgets 12
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
tahoe healey Nano Magic scratch remove Austin Healey 2
F I can’t remove Wire wheels from new hubs - help Austin Healey 43
Basil 7 Ways to remove stripped screws Restoration & Tools 2
C How to remove entire dash panel on BN6? Austin Healey 4
crispy How to Remove the Exhaust Manifold?? [late BJ8] Austin Healey 27
hondo402000 TR6 TR6 Windscreen remove and now windows dont fit Triumph 3
edkap2002 TR6 fuel line compression fittings....how to remove Triumph 3
C MGB How do you remove "speed nuts"? MG 9
T TR4/4A Replacing rear pinion seal - remove driveshaft? Triumph 21
55modified Should I remove driver's side fender to work on footbox on my BN1? Austin Healey 14
R Remove engine/transmission advice needed Austin Healey 4
abarth69 Should I remove this section Spridgets 8
K TR2/3/3A What is best way to remove old nylon/rubber bush 525-020 from steering box shaft? Triumph 5
D TR2/3/3A wooodruff keys... how to remove Triumph 25
B remove BJ8 dash ? Austin Healey 1
Steve1970 TR6 Can I remove the shim on the rear gearbox mount [J-type OD] Triumph 11
4tecdog Access to remove Ariel Austin Healey 15
L Best Polish to remove surface scratches Austin Healey 12
T TR4/4A Does the water pump need to come off to remove the cylinder head? Triumph 5
C TR4/4A Best way to remove transmission fill port? Triumph 8
P How to remove the lever control? Austin Healey 9
Martinld123 Drain Pipe Rear Main Bearing Cap BN2, remove? Austin Healey 2
D BJ 8 How to remove chrome trim strip from door tops Austin Healey 7
S TR2/3/3A remove protective covering off floor pans Triumph 6
bighealeysource Best way to remove dried polishing compound Austin Healey 10
AngliaGT Easiest Way to Remove/Replace Rear Axle Seals/Etc.? Spridgets 9
NutmegCT How to remove old weather stripping Restoration & Tools 8
J TR2/3/3A What is the best way to remove and replace carb shaft bushings. Triumph 4
Got_All_4 General TR How can I remove the finish on this center console for my 7 Triumph 9
B Remove Crank Nut Austin Healey 55
R Can't remove rear flexible brake hose Spridgets 5
C Any tips on how to remove frozen pistons from drum brake Wheel Cylinders??? Austin Healey 11
S TR2/3/3A remove a clutch fork Triumph 1
maxwedge5281 remove 100-6 grill emblem Austin Healey 1
J TR2/3/3A Remove old dash vinyl. Triumph 2
drooartz MGB-GT Any gotchas when remove/replace rear axle? MG 4
Boggsy64 MGB Advice - Remove the seats MG 8
C How to remove temp sensor at block? Austin Healey 16
S Correct way to remove grease retaining cup from front hub? Austin Healey 7
Lukens TR2/3/3A Before I remove my steering box... Triumph 10
