TR4/4A How to determine if the crank is good before pulling the engine out
tdskip
Hi guys - trying to put a plan together on my '66 with the seized engine that you all have been helping me with.
In doing some research and listening to your coaching it seems that I should determine what sort of condition my crank is in before deciding to replace the engine vs rebuild.
That would seem to suggest dropping the pan and having a look from under the car at the condition of the engine internals, but can I get enough info on the condition of the crank to really make a solid decision as to if I can re-use it vs having to replace it?
I know I can look at the condition of the bearings, but should I try to remove the piston rods and mic the crank too?
Other ideas?
Thanks!
TFB
Other ideas?
Thanks!
The front and rear main caps don't just come off like the rod caps.I would just pull the motor to completely disassemble and check.TOm
bobhustead
You're pulling the engine anyway, so just check the crank after it's out of the block. Can't mic the mains with crank in.
T
tdskip
I guess so Bob, so makes sense. I was trying to quickly determine if I should rebuild vs replace, but it does have to come out in either case.
CJD
+1 on pulling it to check. By the time you pull the caps and rods, you would save time having the engine out and remove the crank to do it.
TR3driver
Great Pumpkin - R.I.P
Having the crankshaft journals ground undersize is a normal service operation. Unless the journals are badly scored or have already been ground to the minimum, or there is a crack; the crank can be reused. But even if you need to replace the crank, that is still no reason to replace the entire engine. They're interchangeable.
A spun main bearing would be cause to replace the block maybe, but very unlikely IMO. Even then the block could be saved (but picking up another one might be cheaper).
D TR2/3/3A How do I determine the cause of a steering problem? Triumph 10
M How to Determine Trim Codes for 99 XJ8 Jaguar 3
I How does one determine car year? Spridgets 3
NardisCNC How Do You Determine Your Car's Value?? Spridgets 7
J how to determine B or T terminal on fuel gauge? Spridgets 12
T ZS throttle shaft - how to determine excess wear Triumph 15
B TR6 71 block & crank Triumph 1
J Wanted WTB Bell Crank Pivot Triumph Classifieds 2
K TR2/3/3A What is the best way to prevent the crank from turning ........ Triumph 27
Michael Oritt Rear Crank Seal Kit Austin Healey 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T MG Midget 1500 crank shaft pulley Spridgets 0
S TR2/3/3A Tightening the crank pulley dog bolt on a tr3 Triumph 7
nichola TR6 Door handle and window crank installation Triumph 0
D TR2/3/3A TR3 throttle linkage bell crank. Triumph 32
R Wanted 3 main crank MG Classifieds 1
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
P TR6 Tight window crank Triumph 9
71TR6 Triumph TR4 Coventry Radiator with crank hole- recently refurbished Triumph Classifieds 0
D TR2/3/3A TR3A Crank Dog Triumph 2
K TR2/3/3A The timing mark on the crank pulley.... Triumph 5
K For Sale Starter Hand Crank Triumph Classifieds 0
jtaylor3 1275 EN40 Crank Spridgets 5
J TR2/3/3A Flywheel-Crank Dowel Alignment Triumph 6
R TR2/3/3A Extension Crank Bolt Attachment Triumph 12
M Wanted TR3 Hand Crank Guide Triumph Classifieds 3
Alfred E. Neuman TR4/4A TR4 fan extension and crank bolt length Triumph 9
D TR2/3/3A Crank handle support Triumph 11
Got_All_4 TR2/3/3A Hand crank misalignment Triumph 9
K For Sale TR3 crank handle Triumph Classifieds 0
M Wanted TR-3 Crank Handle Triumph Classifieds 3
R TR2/3/3A Temperature Gauge for 1954 TR-2 & Hand Crank Triumph 17
Got_All_4 TR2/3/3A TR3 engine hand crank Triumph 14
ckeithjordan Wanted WTB: TR3 Crank Handle Guide Stays Triumph Classifieds 1
D BT7 tri-carb installing my crank Austin Healey 4
R General Tech Crank bearing cap broke...Torque?? Triumph 37
Rut Crank/flywheel dowels Spridgets 3
R TR2/3/3A One more crank pulley question Triumph 7
R TR2/3/3A Crank pulley question Triumph 4
GTP1960 TR2/3/3A Timing cover/crank hub oil seal Question Triumph 4
Boggsy64 MGB Crank doesnt turn freely - new main brgs MG 21
jfarris TR2/3/3A TR3 tining without marks on crank pully Triumph 6
T Replacing the crank pulley/damper Austin Healey 4
R Crank damper alignment Austin Healey 6
R timing gear crank shims Austin Healey 11
R Dennis Welch Rear Crank seal conversion - Gap in back plate Austin Healey 19
R Engine crank shaft nuts Austin Healey 1
B Remove Crank Nut Austin Healey 55
M_Pied_Lourd TR2/3/3A Crank Oil Slinger Orientation Triumph 2
S TR4/4A Water pump and crank nose questions Triumph 7
