TR4/4A How to check TR3/4A Trans for wear?
karls59tr
Bronze
Now that I have the trans on the bench to replace the broken taper pin what is the best way to check out the trans to see if it is in reasonably good condition seeing as how it's been sitting for 20 years? What should I look for when shifting thru the gears? What are the obvious signs of worn synchs etc. ? Any related advice would be most helpful.
TomMull
From my experience, it is very difficult to assess transmission condition on the bench without a teardown. By removing the shift cover, it will be possible to see the gears and wear patterns but normal wear and excessive wear don't look much different to me. The counter shaft and bearings are a major weak area and remain hidden.
I'd put it in the car and drive it. It really isn't that difficult to remove again if you've got a howl or other issue. If it doesn't, you've saved a bunch of money.
Tom
TR3driver
Great Pumpkin - R.I.P
I'm inclined to agree with Tom, but there are a few things you can do with it on the bench.
One is to hook up something to spin it. I use a 1/2" drill motor with a short length of radiator hose clamped to the drill chuck and to the input shaft of the gearbox. Others have mounted a pulley to the output flange and used a belt & washing machine motor to spin it that way. With it spinning, you can go through the synchromesh gears (2-4 on a TR3 box, 1-4 on a TR4-onwards box) and get a crude check on whether the synchros work at all. Not an exhaustive test, but if it flunks you know you've got a problem.
Another is to remove the top cover, push each synchro ring up against its associated gear, and measure the gap between the ring and the "dog teeth" on the gear. Anything less than about .035" indicates a worn synchro ring. (They will still work at .025" but it's best to leave some margin for wear.) Of course, you'll want to have a new gasket for the top cover; but they are reasonably cheap from any of the usual suspects or you can cut one from thin gasket material.
If you are so inclined, it's not terribly difficult to tear the box down enough to remove and inspect the countershaft and thrust washers. This is by far the most fragile part of the gearbox (in terms of excess wear and/or damage being likely) so might be worthwhile if you don't know the box's history. Getting to this point is reasonably straightforward (though you will likely have to kludge something together to get the tail housing off). Check out the gearbox articles on the Buckeye Triumphs and VTR sites. All of the tricky clearance checking and so on only applies if you go further and disassemble the mainshaft.
OTOH if it was working OK when the car was parked 20 years ago, then I wouldn't bother with any of this. I might change the seals if they weren't reasonably fresh when it was parked, but nothing else is likely to deteriorate from long storage.
Lukens For Sale Check out this tr3 project for sale... A real treasure trove Triumph Classifieds 0
P TR2/3/3A TR3 turn signal and horn control wiring check Triumph 4
K TR2/3/3A Re: TR3 Bump stops and check straps. Triumph 18
Tinkerman TR2/3/3A 1960 TR3 A Door Check Assembly Triumph 13
S TR2/3/3A door check straps for tr3 Triumph 1
toysrrus TR2/3/3A "FOR SALE": Check out the Classifieds for a TR3: Triumph 0
K TR2/3/3A TR3 : Check Gen Bolt Adjuster Bar Triumph 9
M TR2/3/3A TR3 Fuel Pump Check Valves Triumph 7
Russ Austin TR2/3/3A Door Check Strap TR3 Triumph 10
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
AngliaGT In Check,VA Today Spotted 2
Rob Glasgow Check Strap Assembly Austin Healey 5
F TR2/3/3A Check strap alignment Triumph 11
T General Tech Once again, check the easy stuff Triumph 2
AngliaGT Got Lucky Today - CHECK THOSE BOLTS! Spridgets 6
S Price check on TR3A valve cover Triumph Classifieds 0
Twit TR4/4A early tr4 check straps Triumph 4
F Check for matching nrs Austin Healey MK2 Austin Healey 3
V TR2/3/3A Vertical link check Triumph 2
R TR4/4A Door check straps Triumph 7
68_sprite Check the August Oprah Magazine Austin Healey 5
M TR2/3/3A TR-3A Compresson check hot vs cold Triumph 5
HighAltitudeTR3 TR2/3/3A Door Check Assembly Triumph 19
S Door Check Strap Austin Healey 5
AngliaGT Why You Should Double - Check Your Parts When You Receive them. Spridgets 2
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
AngliaGT Anyone in Charlotte,NC That Could Check Out a Truck for Me? Other Cars 0
C Rough Idle - What to check? Austin Healey 12
KVH TR4/4A Door Check Straps Triumph 11
S Overdrive Wiring Check Austin Healey 12
Michael Oritt Door check installation Austin Healey 7
warwick-steve Brake drum check and lubrication Austin Healey 9
Rut Sanity check! Spridgets 2
1 Price check on an original 1957 100-6 BN4? Austin Healey 29
Mickey Richaud General Tech Always Check the Fundamentals MG 10
F Check out this new restoration diary - BT7 - very brave! Austin Healey 7
D TR2/3/3A Door check bracket? Triumph 7
C Brake issue on my 1969 XKE - what to check first? Jaguar 14
Martinld123 Compression check 1956 BN2 Austin Healey 7
M BN1 door check replacement Austin Healey 9
R Last minute check before engine install Austin Healey 26
Boink Check out some Sprite shots at the Portland ABFM... Spridgets 1
Rut TR4/4A Get out your check books! Triumph 10
Gerald_Gordon TR4/4A Failure of new door-check strap on an early 1961 TR4 Triumph 6
S How to check Dwell on a MK I 3000? Austin Healey 27
PatGalvin TR2/3/3A vacuum leaks? How to check Triumph 9
jlaird Check Spam folder Spridgets 3
I TR6 Got in a wreck - need some help on who to take it to and what to check Triumph 48
