TR4/4A How did you do your TR4 alternator conversion?
tdskip
I was hoping to only change the crank pulley and have to buy a full kit since I already have the water pump narrow bit.
Also, Moss doesn't seem to be selling the pulley separately unless I missed it.
Where did you source the narrow belt pulley? Tips? Vendors?
Ideas?
Thanks!
JodyFKerr
When I did the conversion on my TR8 I asked at my local NAPA. They had a stash of extra pulleys in the back. Fellow was even kind enough to swap it for me.
TFB
The Moss crank pulley is two parts,the sleeve and pulley,which is sandwitched in rubber to dampen,and the seal sleeve that must be pressed together to form complete hub.It also is slightly smaller diameter and you need to stamp you own timing marks. Pulley is 10x8mm and I think they sell the components separate.I thought the kit and hub was nice,and made for an easy conversion.
I think VB had 1/2(and you want pulleys to match)but no fan eliminator bolt.Moss is for no fan hub.
There is on other company in England,I can look up name if no else posts.
Tom
PeterK
On the Moss page with the pulley kit, click [Info] and a PDF will pop up with individual components of the kit.
They used to have a plain non-dampened pulley but all I see is the dampener so you would also need the hub adapter part.
TR4nut
I think my brain is going, I swear I saw this same topic a week or two ago. For just the pulley, Try Bastuck in Germany - that is the typical non-damped kit supplier. Individual pulley is pn M9aTR4A, cost is 33.43 Euro + shipping. Yes pricey but doable!
T
tdskip
OK - perhaps some progress here.
I managed to dig up this thin pulley.
The outer diameter is pretty much spot on;
The opening for crank attachent is too small however. The top layer here is the correct size opening, the new thin pulley is below;
So - can I machine out the new thin pulley to fit the crank? This would seem to be ideal in that it would let me keep the fan in a node to originality and save a decent chunk of change. Yes/no/ideas?
Thanks!
Darrell_Walker
I'm no machinist, but I'd say it looks doable. But you also need to check the offset of the pulley when you install it on the hub - will it line up in the same plane as the rest of the pulleys?
T
tdskip
Hi Darrell - thanks for the note. Looks right but not positive, the offset appears to match up with the factory one (meaning the center of the groove looks to be the same).
nissanite TR4/4A TR4-A Front grill ... How did you restore yours? Triumph 5
K TR4/4A The TR3 body on the TR4...how did it work out? Triumph 5
A TR4/4A TR4 Tranny -did it come non synchro?? Triumph 15
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
Y MGB How did become such a mess up???? MG 2
dougie Did Big Healey Drivers Go Soft? Austin Healey 8
V MGB Mystery fastener from '66. Did I miss something? MG 6
mezy Heres one i did. Other Cars 9
algot1901 How did people in the 1950's manage to fit in the Prefect???? Other British Cars 16
BoyRacer Did BN2s have adjustable steering wheels? Austin Healey 5
jlaird MGB Don't post like I did 10 years ago. MG 7
AngliaGT MGB What Did You Do on Your MGB Today? MG 6
JPSmit Honey, did you hear that clunk? Other British Cars 0
B TR4/4A What did I do wrong? Triumph 19
Elva164 Finally did another onboard video! Racing 4
Jim_Gruber When did Mini’s get so expensive Spridgets 20
J TR4/4A Did my own carpet Triumph 16
Jim_Gruber So what did I do wrong here with Bugsy. Spridgets 2
Jim_Gruber Did my clutch just bleed itself? Spridgets 11
warwick-steve Where did the smell go? Austin Healey 11
Jim_Gruber Did I find another need for a Whitworth Wrench Set/ Did I screw up intake manifold Spridgets 5
kennypinkerton MGB Things I remember that I did to my MGB... MG 4
TomMull TR2/3/3A Did sombody just get lucky? Triumph 4
PC Morgan fans - how did I miss this? Other British Cars 2
JPSmit Hyundai Stellar - when last did you see one? Other Cars 6
longbridgehealey When did you buy your first LBC, and what was it? Spridgets 46
H 1925 Rolls Phantom I "round door Rolls" in Petersen collection: what did it sell for? Other British Cars 5
H Joan Baez flat floor '61 roadster, what did the Feds sell it for at auction? Jaguar 0
nicko Did you know....... Austin Healey 15
K General Tech Why did MGB's come with oil coolers but Triumph's didn't? Triumph 17
R Where did it go? A who-done-it mystery! Austin Healey 18
Rut TR4/4A I did it again... Triumph 27
PC didn't spot a 911 or a Javelin but did see a station wagon Spotted 1
T TR4/4A Access to a professional sandblasting set up - why the heck did I wait so long... Triumph 4
Editor_Reid FYI re "What Did You Do On Your Austin Healey Today?" Austin Healey 0
CessnaTPA What Did You Do On Your Austin Healey Today? Austin Healey 98
2billydavies TR2/3/3A just removed the pistons/sleeves... can't believe she ran as well as she did! Triumph 6
H Joan Baez flat floor series I e-type roadster: what did the authorities dump it for? Jaguar 0
H Michelotti one off body on an E-type? What year chassis and what shop did the work? Jaguar 0
C The "Lightweight" Jaguar E-Type.....why did they only make six?? Jaguar 2
D Challenger 2.5 did 419 one way at the flats today. Racing 2
Gliderman8 TR6 Did one of you guys lose this? Triumph 10
P General TR What vehicle did this windscreen come from? Triumph 2
tinman58 TR5/TR250 Did I screw up? Triumph 4
glemon General TR What Did You Do to Your Triumph Today? Triumph 119
Moseso TR2/3/3A PeterK, or others -- How did you mount your BMW fan on the TRactor motor? Triumph 3
trrdster2000 Off Topic What did you expect? Triumph 6
58Custom General MG What wheels did I buy? MG 8
R How long did it take to restore your car? Austin Healey 18
Rut How did you come to own a Bugeye? Spridgets 17
