Hood Resto Preparation
T
TRDejaVu
Anyone know of a good acid dip place in the Chester County, PA area? Or even around Philadelphia.
T
TRDejaVu
The silence is deafening, so I will take that as a "No".
Platinum
Sorry, Ian. Last time I was in the area was 1974. Have you a way to check with a local hot-rod club? That's as close as I can get to "helpful".
KVH
I'm doing the same thing with an old body panel. Don't you have to first "blast" it with some nutshell formula? Have you sanded it?
tony barnhill
Great Pumpkin - R.I.P
Aircraft chemical stripper that you can buy is pretty easy to use - paint it on with a brush, wait, strip paint, repeat as necessary, wrinse with a metal etch, prime.
GregW
I’ll second Tony on the aircraft stripper. I believe Marhyde makes some, sold in the auto store chains. Wear chemical resistant gloves and apply in a well-ventilated space. It’s good to have a spritz bottle of water handy in case any of the stripper gets on you. There will be a burning sensation.
Darwin
Bronze
Marhyde also makes a spray-on stripper that works a lot better, faster, and easier, in my opinion. A little spendy but it cut stuff that can type strippers didn't touch.
T
TRDejaVu
I am looking for something to eat the rust where you can't get to it; inside box channels etc. Presumably you can then dip it to reprotect the hidden areas and then get to work repairing whatever holes have been created by the now missing rust. Or am I wrong?
Exotexs
the last time I used paint stripper I got dizzy, then nauseous, and it lasted for 2 days, even though I did it outside, plenty ventilation. There must be some very poisonous chemicals in those strippers.
I ended up sanding the old fashioned way, since the stripper melted the old paint, (what a mess) but did not touch the original black primer. I gave the can of remaining stripper to the maintenance man in my complex, he refused it. I took it to Home Depot, where I bought it, they refused it. I finally called a Hazardous Materials number and they told me where to dispose of the darned thing.
Never again.
Ex
Scott_Hower
If you willing to drive up the Blue Route (aka 476/NE extension), try Redi-Strip in Allentown PA.
476 North to Allentown/US22 Exit
Follow signs to US 78/22 East (stay right past toll)
RT 78 and 22 split, keep right on 22East
Exit at Fullerton Ave; turn RIGHT/South at light.
Entrance is ~2 miles on LEFT before the little concrete bridge - church on right side.
It is an old industrial complex under the big bridge at Union Blvd ; it is tricky to find the entrance.
Been using them for years.
Redi Strip of Allentown
1 W Allen St # 5
Allentown, PA 18102
(610) 437-7878
I've also used PowderCraft in Exton, PA which is probably much closer to you. Never had anything stripped/blasted from them, just powdercoating. Happy customer.
https://www.thomasnet.com/eastern-pennsylvania/stripping-services-metal-4874-1.html
T
TRDejaVu
Thanks Scott,
Exton is a couple of miles from me and Allentown about 1 hour away. I will call Redi Strip when I get a chance.
Scott_Hower
Ian - looks like Red-Strip has changed their name to Quick-Strip.
And if you decide to use them, stop by for a chat and a cold beer, you pretty have to drive past my house to get there :smile:
PowderCraft did all the tins in my engine bay and they look outstanding 5 years on. I picked my stuff up on a slow day and they gave me a tour of their shop. Not a pretty building/site, but they seem to know their stuff. They were baking a Lotus 7 frame the day I visited.
zahnej
Look for a soda blaster in your area. This will take off the paint and the rust and will not harm or deform the metal in any way. After using other methods I can't recommend this process enough.
Go to Google - type in soda blast and your state or area - you should get a hit.
T
TRDejaVu
But how does soda blasting get at the hidden areas; inside the stiffeners etc?
zahnej
Soda blasting is similiar to sandblasting except the media is different. If you dont think you can get in with a sand blaster then you also can't get in with soda.
JPSmit
The reason I chose not to go with dip was because the acid would strip thise hidden areas but I wouldn't be able to repaint them. I'm not just thinking stiffeners but inside of sills etc. The dipping company did not seem to have any facility to dip the car in primer/ sealer so I took a pass on it all and went with media blasting - should have done soda though /bcforum/images/%%GRAEMLIN_URL%%/cryin.gif
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
S TR2/3/3A 59 TR 3 hood emblem Triumph 2
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
R New Hood for BJ7 Austin Healey 3
KVH General Tech Fitting the Hood (Bonnet) Triumph 7
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
S TR2/3/3A Hood Stick Cover Triumph 3
dripdripdrip TR2/3/3A Best place for tonneau & hood stick covers? Triumph 2
B BJ8 Hood Bow and Seal Austin Healey 5
B Hood Woodwork Austin Healey 2
Papajack TR2/3/3A TR3 Hood and Sidescreen Colors Triumph 6
57 Healey For Sale Original top (hood) frame for BT7 Austin Healey Classifieds 8
R TR6 Stronger hood release? Triumph 4
MGTF1250Dave T-Series Hood Sticks MG 4
TomMull Wanted Herald Hood Frame Triumph Classifieds 9
TomMull Convertible hood frame Other British Cars 3
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
S Forward opening hood / bonnet Spridgets 10
D BJ7 Hood frame mounting plate Austin Healey 7
S TR2/3/3A Tr2 hood Triumph 8
oldbagpipe SOLD!! Early TR4 Short Bubble [Bulge] Bonnet/Hood Triumph Classifieds 5
steveg TR6 Hood release pictures needed Triumph 22
HealeyPassion Hood scope chrome gap fix ... Austin Healey 0
Gliderman8 TR6 It finally HAPPENED... Hood cable broke but HAPPY ending. Triumph 44
D 1962 3000 Hood/Bonnet Grille Austin Healey 5
S Pre-War my hood problem got worse! Triumph 6
S TR2/3/3A The chrome beading is rubbing on the hood Triumph 5
G Wanted WTB TR3 Hood Hardware Triumph Classifieds 0
B TR6 TR6 Hood Release Cable Triumph 7
A TR2/3/3A how do i fix this hood line? Triumph 5
Z For Sale 1956 Austin Healey BN2 Factory hood Austin Healey Classifieds 0
L TR2/3/3A Hood / bonnet plinths Triumph 12
TomMull Wanted Triumph Herald Hood Finishers Triumph Classifieds 3
D TR2/3/3A Fitting the hood. Soft top. Triumph 6
J TR2/3/3A Hood oilcanning Triumph 6
anarchy99 Bonnet / hood fit question... Spridgets 2
anarchy99 Wanted WTB: 64-66 sprite hood in decent shape. Spridgets Classified 2
T Wanted WTB TR2/TR3 Hood/Bonnet Latch Assembly with Prop Rod Triumph Classifieds 0
K TR2/3/3A Location of Hood[Bonnet] Louvres on a TR3A? Triumph 1
L Wanted 100/6 Longbridge hood parts Austin Healey Classifieds 3
L 100/6 Hood parts Austin Healey 11
britlover Wanted TR4 Hood long bubble Triumph Classifieds 0
4tecdog Windscreen rail to hood seal Austin Healey 11
G Fixings for liner assembly hood comparment -BJ7 Austin Healey 7
Keith_M bugeye front tilt hood fastener -- choices Spridgets 9
D TR2/3/3A Under hood Photos Triumph 7
4tecdog Modify frog hood frame Spridgets 12
