Hood drain channel
chicken
Hi I did have a post running elsewhere but dont know how to revive it back where its seen.
So here we go, i am getting ready to have a trimmer fit a new hood and i need to fit the hood drain channel, i have found out that the channel should have been fitted prior to the shroud going on but that didnt happen so i am going to retrofit. I gather the drain channel lips behind the rear of the shroud but is it then riveted from the front or does the chrome covering strip go on first and then all 3 are riveted together?
Is the drain channel just painted black or should it be body colour ?
There is also another curved strip i have which im guessing fits over the front of the drain channel and holdas the hood in place ? Is this also riveted onto the drain channel ?
I need to get the bits in place soon ready for the trimmer in January so any pointers would be most welcome.
Thanks
Rob
vette
Hey Rob, what year car are you talking about. I'm sure my BJ7 Convertible top (hood) is fitted differently than the earlier roadsters.
vette
Rob, I just went hunting for some pics but I don't have much from when I fitted the hood. Here are two that show my inside fitment of my BJ7 convertible top. There were some things on my car that I did not bother to restore if they were in good order and the top was one of them. Also I made no attempt to make my interior panels exact copies of originals. I actually don't remember the exact pieces or sequence of fitment except that I remember that it was not as complicated as I suspected. I'm pretty sure that the outside chrome piece went on first because it is secured with small screws horizontally from the inside edge. Then the gray curved piece that is seen on the inside is what holds the top tight to the edge of the drain channel i think. But my memory is foggy here. Hope this helps. Dave.
chicken
chicken
Dave
Thanks for the pics, yes forgot to mention my car is a BJ7.
Do you see the drain channel ? if not then i guess i can just paint it black.
The grey curved piece, is that grey for a reason ? mine is black, as it's seen from inside the car did it ought to be painted body colour or the colour to match the hood, is yours a grey hood ?
Do you remember was the drain just riveted on ?
Thanks
Rob
vette
If you want to make your Healey as close to original as possible then you should buy the book "Austin-Healey 100/100-6/3000 Restoration Guide by Anderson and Moment. In my opinion no other book will do. I have attached a page from the book but If I shrink it I don't think it will be ledgeable. In the one pic you can just barely see the left rear corner of the top frame. I believe that all the top frames were gray and the metal hooped piece we spoke of I believe is to be gray as well. My pieces are unrestored and they are grey. But of course they could have been changed before I got the car but I don't think so. I think I will try to attach another pic of the inside of an erected top in a next post. I believe Anderson & Moment are the best for this type of book. Dave.
vette
Inside Pic.
FWIW, on my--'original' when I bought it 32 years ago--BJ8 all the hood, drain, etc. pieces are painted in a light, bluish gray.
chicken
chicken
Bob, thanks, i think i have found the colour now. I spoke with AH spares who said it is a Cumulus grey ? and have managed to find some paint.
I now just need to repair the drain channel it is full of holes !
Patrick67BJ8
There's a Rustoleum color in a spray can that's an excellent match for the original color.
Top Down Resto
The original channel was hand painted grey, kinda sloppily too on the outside, when the convertible top mounting channel is screwed on you only see the lower part of the channel anyway, but you still see the end sections .
Here's a link to some drain channel pictures that Patrick sent me several years ago when I was putting on a BJ8 top. In the first couple, it looks like the chrome piece is still attached to the channel, as if to indicate they were removed together; so if I understand the question correctly, perhaps they should go back in that way too?
I didn't have to disturb the drain channel, thankfully, beyond verifying it was doing its job, so I cannot comment on its removal or replacement.
https://spcarsplus.com/gallery3/index.php/reMKIII/top_work/drain-channel_by-others if you click on any opened picture, you'll see the high resolution image (and it too can be made original size with an additional click) for the greatest detail.
bob hughes
Chicken
If you are going to retro fit the channel, you may have to release the shroud to gain some clearance to get the channel over the inner wheel arches and into position. It is a good thing that you are using the old channel as new ones invariably need altering to fit.
I have yet to do mine on the BJ7 but I will be removing the wings and shroud to do so.
Best of luck
:cheers:
Bob
chicken
chicken
Bob
I think I can just squeeze it into poistion, do you wknow is it just riveted in place ? I counted 13 holes, I think then the chrome trim surround is screwed on.
How is the metal piece that the rear of the hood is fixed to held in place, rivet or screws ?
Rob
Patrick67BJ8
Bob
Rob
Your right about the above Bob. Good luck on squeezing a drain channel in after the shroud has been installed. You have a 50/50 chance of getting it in without lifting the shroud off. My painter left off the drain channel and was able to squeeze it in but it took about 3 people to do it(my car was just painted). Always check the Factory Parts Book for the types of screws you need when reinstalling parts.
bob hughes
I am not there yet chicken but I think that it is pop riveted in place. Yes the chrome strip is the last to go on.
I screwed the metal piece into the side of the drain channel when I refitted my hood - ( on 2 separate occasions owing to the way I am working - rolling restoration ) because that was how it was when I bought the car, I do think that screws are the way to go from talking to the upholsterer at Rawles Motor Sport. This is also confirmed by looking at the SC Parts catalogue - they say 10 screws. The main trick is to get those clips around the rear moulding in the right place before screwing it to the drain channel.
:cheers:
Bob
Patrick67BJ8
:cheers:
Bob
Don't forget to apply some silicone under the chrome trim piece when installing it. Originally the material used was the same stuff that was used on the chrome strips for the doors(window area).
Patrick67BJ8 Top/Hood/Drain Channel Gray color needed Austin Healey 2
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
S TR2/3/3A 59 TR 3 hood emblem Triumph 2
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
R New Hood for BJ7 Austin Healey 3
KVH General Tech Fitting the Hood (Bonnet) Triumph 7
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
S TR2/3/3A Hood Stick Cover Triumph 3
dripdripdrip TR2/3/3A Best place for tonneau & hood stick covers? Triumph 2
B BJ8 Hood Bow and Seal Austin Healey 5
B Hood Woodwork Austin Healey 2
Papajack TR2/3/3A TR3 Hood and Sidescreen Colors Triumph 6
57 Healey For Sale Original top (hood) frame for BT7 Austin Healey Classifieds 8
R TR6 Stronger hood release? Triumph 4
MGTF1250Dave T-Series Hood Sticks MG 4
TomMull Wanted Herald Hood Frame Triumph Classifieds 9
TomMull Convertible hood frame Other British Cars 3
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
S Forward opening hood / bonnet Spridgets 10
D BJ7 Hood frame mounting plate Austin Healey 7
S TR2/3/3A Tr2 hood Triumph 8
oldbagpipe SOLD!! Early TR4 Short Bubble [Bulge] Bonnet/Hood Triumph Classifieds 5
steveg TR6 Hood release pictures needed Triumph 22
HealeyPassion Hood scope chrome gap fix ... Austin Healey 0
Gliderman8 TR6 It finally HAPPENED... Hood cable broke but HAPPY ending. Triumph 44
D 1962 3000 Hood/Bonnet Grille Austin Healey 5
S Pre-War my hood problem got worse! Triumph 6
S TR2/3/3A The chrome beading is rubbing on the hood Triumph 5
G Wanted WTB TR3 Hood Hardware Triumph Classifieds 0
B TR6 TR6 Hood Release Cable Triumph 7
A TR2/3/3A how do i fix this hood line? Triumph 5
Z For Sale 1956 Austin Healey BN2 Factory hood Austin Healey Classifieds 0
L TR2/3/3A Hood / bonnet plinths Triumph 12
TomMull Wanted Triumph Herald Hood Finishers Triumph Classifieds 3
D TR2/3/3A Fitting the hood. Soft top. Triumph 6
J TR2/3/3A Hood oilcanning Triumph 6
anarchy99 Bonnet / hood fit question... Spridgets 2
anarchy99 Wanted WTB: 64-66 sprite hood in decent shape. Spridgets Classified 2
T Wanted WTB TR2/TR3 Hood/Bonnet Latch Assembly with Prop Rod Triumph Classifieds 0
K TR2/3/3A Location of Hood[Bonnet] Louvres on a TR3A? Triumph 1
L Wanted 100/6 Longbridge hood parts Austin Healey Classifieds 3
L 100/6 Hood parts Austin Healey 11
britlover Wanted TR4 Hood long bubble Triumph Classifieds 0
4tecdog Windscreen rail to hood seal Austin Healey 11
G Fixings for liner assembly hood comparment -BJ7 Austin Healey 7
Keith_M bugeye front tilt hood fastener -- choices Spridgets 9
D TR2/3/3A Under hood Photos Triumph 7
