TR2/3/3A "Hard" Overdrive Engagement - TR3
spineguru
When I switch on my overdrive it immediately kicks in, which is a good thing. However, it engages pretty "hard" (the car sort of jolts), somewhat like a "shift kit" feels. When I switch it off, it very smoothly disengages. Is this hard engagment normal?
SpannerMan
You can just feather the throttle a bit as you engage the OD- it will feel smoother and should be a little easier on the equipment too. Some even dip the clutch when engaging but I don't feel that is necessary. Likewise you can pick the throttle up a shade as you go back from OD to direct. Pete
G
Pete is correct in his description of "how to engage overdrive". Too, the A-type unit has a tendency to "slam" a bit more than the J-type unit when engaging.
A good site to reaffirm this information would be quantumechanics.com where John Esposito explains the correct way to engage overdrive. John could be described an a true expert on Triumph overdrives.
Bill
V
vagt6
Hard engagement is normal, unless it's severe.
Also, be sure to check the oil level frequently. Low oil can cause a wide range of problems in Laycock units.
Enjoy the OD!
TR4nut
I have an A-type in my TR4, it isn't too jarring but I typically am not accelerating when I kick it in. From what I've learned from others, the fluid in the trans can make quite a difference in the performance, so if you don't like what you have, some research on the fluid and a judicious fluid swap may improve things.
hondo402000
I had a 63 volvo P-1800 that had an overdrive, I thought of it as another gear and always clutched when I engaged the OD. Its a lot easier on the OD to clutch and engage the OD. I would much rather replace the clutch than have the OD unit rebuilt, food for thought
TRTEL
Thirty five plus years of overdrive use and rebuilds has convinced me to engage my clutch. Hondo is right it definitely takes a load off the engagement. When you see those grey flakes in the bottom of the brass plug covering the pump screen, they're all from the brake ring and using the clutch will minimize that wear. The thunk or clunk you're getting may be a bit too much clearance between the brake ring and clutch lining.
Tom Lains
TS8651
TS58107
Alan_Myers
Hi Bryan,
TR2/3 and early TR4 use an A-type that's a little stronger shifting than the later TR4/4A/250/early 6.
The reason is a larger accumulator piston. If memory serves, it's 1-3/4" in diameter in the earlier A-type and was reduced to something like 1-3/8" on the later version. This was done... drum roll please... to provide softer engagement! Apparently many Triumph drivers found the rapid and somewhat harsh shift of the earlier A-type a bit disconcerting. The J-type takes it even further and is slower/softer engaging.
Racers really like the earlier version, if they use an overrive. But, one downside is that some of the parts for the earlier version are harder to find.
There are also mods that can be made to all A-type, to make them engage a bit faster. Those mods may not be necessary on the earlier version, but can improve the later one.
Sounds like you've got the early one, which is what would be appropriate to your car.
Don Elliott
In the last 48 years with my TR3A, I have never (well almost never) let up off the gas or depressed the clutch pedal when switching into overdrive. On occasion, I have taken my foot off the gas before I switch and it "clunks" into overdrive. I stronly suggest that this does more mechanical damage to the gearbox and overdrive than a smooth shift. But just after I switch into overdrive, I feather off the gas for a microsecond to ensure that it all engages smoothly.
Just think about it. Triumphs were built for rallies and for racing starting in 1954. Triumph would never have made it a requirement for a rally or race driver to let up off the gas or de-clutch when switching into overdrive.
Don Elliott, Original Owner, 1958 TR3A
https://www.britishcarforum.com/ubbthreads/photopost/showphoto.php/photo/1919/ppuser/4127
sammyb
Hey, at least it works! I finally broke down after three years of fiddling with my OD and took it to some professionals to get it working. (It has never worked since I got the car three years ago.)
S
spineguru
So much for it working! See my latest post "My Overdrive just DIED" /ubbthreads/images/graemlins/cryin.gif
V
vagt6
Your clutch pedal has nothing to do with the electrically initiated Laycock overdrive. Using the clutch to operate your overdrive does absolutely nothing but wear out your clutch.
There's lots of good info on the internet about how to operate a Laycock overdrive. Do a Google search, study the stuff on Quantumechanics.com, and save your clutch! /ubbthreads/images/graemlins/hammer.gif /ubbthreads/images/graemlins/lol.gif
T TR2/3/3A A type overdrive hard engagement Triumph 36
W how hard is it to add overdrive? Triumph 12
L T-Series Hard to start MG 11
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
E Spitfire '69 Spitfire hard top Triumph 2
7 Top, hard Triumph 0
S TR2/3/3A TR3 Hard Starting Triumph 4
KVH TR4/4A Hard Start When Engine Hot Triumph 20
roscoe New / old hard top Austin Healey 16
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
M Wanted TRIUMPH TR3A Hard Top Triumph Classifieds 14
S TR2/3/3A Clutch pushes hard when engine is hot Triumph 4
AUSMHLY 2nd gear should I file it? Do gears have a hard coating? Austin Healey 7
D Wanted Wanted 80Spitfire hard top and seats Triumph Classifieds 0
R 59 Bugeye rib cage tranny hard shift into reverse Spridgets 0
B TR2/3/3A Hard Top Part Triumph 2
B TR2/3/3A TR3 Hard Top Triumph 2
T Wedge TR7 brake hard and flex lines - fittings Triumph 12
Basil Spitfire Hard Top Seal Triumph 5
Madflyer MG B hard top MG Classifieds 0
Sopwith_Camel hard top bracket happy day Spridgets 4
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
K TR2/3/3A Hard start questions.... Triumph 4
BLong63AH BJ7 Hard Fuel Lines Austin Healey 20
Lin Brake hard line question Austin Healey 4
A BN4 Hard Top Austin Healey 23
Healey Nut Good hard top on flea bay Austin Healey 6
W Spitfire Hard Top rubber Triumph 5
K For Sale TR3 Engine Lift Bracket...hard to find! Triumph Classifieds 0
D General TR Hard lessons learned Triumph 4
Rut TR6 Hard top finisher Triumph 1
Rob Glasgow Hard Top Rubber Seal Austin Healey 3
1 MGB 1966 MGB hard shifting into 3rd MG 1
TomMull Wanted TR3 Hard Top Triumph Classifieds 11
RAC68 Top Frame, Hard to Weld Austin Healey 13
RAC68 Hard Brake Line Compound Opinion/Recomendation Austin Healey 8
2billydavies TR2/3/3A runs excellent but starts hard after use Triumph 8
G TR4/4A Distributor Vacuum Manifold Hard Line Triumph 11
D Hard Starting Austin Healey 14
aero3113 3000 with clear hard top?? Austin Healey 11
S This Austin Healey video had me laughing so hard I cried. Austin Healey 5
J For Sale Austin Healey Hard top Austin Healey Classifieds 1
D BJ8 pulls right on hard braking? Austin Healey 4
Patrick67BJ8 Brake Pedal Vary Hard to Push Down and Brakes feel like there's no Booster on my BJ8 Austin Healey 27
R winter hard starting BJ7 Austin Healey 16
B TR2/3/3A Tr3a brakes pull to left on hard braking Triumph 9
aero3113 100 hard top with windshield folded down. Austin Healey 4
S TR2/3/3A Linkage issue? Car stalls when braking hard Triumph 17
cj706643 How hard do you drive your 100? Austin Healey 8
S TR2/3/3A The hard top on Seattle craigslist Triumph 1
