TR6 Handbrake Warning lamp?
Gliderman8
Regarding the brake warning lamp on the dash.... It is supposed to light up to warn you of a hydraulic failure in the brake system.
I seem to remember a switch that mounted on the handbrake lever that would also turn the brake lamp on when the handbrake was up but I don't see anything listed on the schematics (unless I missed it).
Was there ever a switch used to let you know if the handbrake is "on"?
Gliderman8
Gliderman8
Not in the 73's Elliot, but the 76's had such
Thanks Ken. Of course I can install a switch on the handbrake and run a wire to the brake lamp.
Gliderman8
Gliderman8
Elliot--
Adding a switch is not to big a deal. And it's not hard to improve on the one that came on the 76s:
Ed
Thanks Ed... I had a look at your website. Instead of a micro switch, I'm planning on using a small mercury switch attached to the handbrake.
Gliderman8
Gliderman8
Elliot, please post pictures of your design using the small mercury switch. Thanks!
Bob
Once I get it installed I will post some pics.
ed_h
Depending on how the hand brake is adjusted, there might only be a 20 or so degree change in angle between brake applied and brake released. This should be plenty for a properly mounted tilt switch, but it will also have to account for slope of the grade. Acceleration and deceleration forces might also be a minor consideration.
Totally doable, though, I think.
Yes, post pics of the final design.
Ed
Gliderman8 TR6 Handbrake warning lamp switch build Triumph 14
K Any ideas for a Handbrake Warning Light??? Triumph 11
B Replacing the Handbrake Cable Austin Healey 8
charlie74 TR6 handbrake adjustment tool Restoration & Tools 0
EWD TR6 74 TR6 - Handbrake handle reinstall Triumph 2
T Handbrake button Austin Healey 0
CJD TR2/3/3A Handbrake Handle Triumph 15
PeterK General TR Need a handbrake button and rod TR4a-TR6 Triumph 5
warwick-steve Brake shoes won't move back after releasing handbrake Austin Healey 8
K TR2/3/3A The "compensator bar" on the Handbrake...#53 in Moss diagram Triumph 5
S TR4/4A Handbrake cable rubber boot at clevis pin end Triumph 1
C TR2/3/3A Handbrake Adjustment Triumph 2
69MGC MGC MGC Handbrake Compensting Lever MG 1
M Handbrake 2 Spridgets 13
M Handbrake Spridgets 6
F Frustration trying to adjust handbrake on Austin Healey BT7 Austin Healey 9
GTP1960 TR2/3/3A Handbrake adjustment Triumph 11
Tinkerman TR2/3/3A Problems with new rubber handbrake boot. Triumph 6
Rob Glasgow Handbrake handle repair Austin Healey 1
Foura TR4/4A TR4A Handbrake Triumph 6
Tinkerman TR2/3/3A Handbrake lever rubber seal installation Triumph 3
T TR4/4A Handbrake bracket Triumph 3
Brinkerhoff MGA MGA Twin Cam handbrake parts MG 3
Lbp TR2/3/3A Handbrake Mystery [at least to me!] Triumph 5
bighealeysource Anyone remove their handbrake assembly on BN2,etc Austin Healey 9
af3683 TR2/3/3A TR3B Rear Handbrake Cables Triumph 8
BillyB62 TR2/3/3A TR3A Handbrake spring? Triumph 2
T TR2/3/3A Help on handbrake boot for TR3 Triumph 2
G MGB Handbrake MGB MG 13
B TR2/3/3A TR3B Handbrake bolt seized Triumph 5
DrEntropy Unsolved handbrake issue. Other Cars 27
af3683 TR2/3/3A TR3B Handbrake Cable Replacement Triumph 13
M Handbrake Button Austin Healey 1
W handbrake adjust Austin Healey 2
I Bugeye handbrake spring source? Spridgets 1
bighealeysource adjusting the handbrake on BN6 Austin Healey 1
boxfullofyertoys Looking for a handbrake Spridgets 1
Cottontop Not Healey, but speaking of Handbrake Turns Austin Healey 2
Randy Forbes Fly-off handbrake... Austin Healey 18
Jim_Newman Handbrake lever Austin Healey 5
A Handbrake cable installation - right or wrong Austin Healey 11
TimK Handbrake Bracket fastening Austin Healey 7
Tinkerman TR2/3/3A TR3A Handbrake Assembly Woes Triumph 6
Tinkerman TR2/3/3A TR3A Handbrake Help Needed Triumph 9
ncbugeye Bugeye handbrake cable Spridgets 4
Mark_Barton TR4/4A TR4 Handbrake - Cable Support Triumph 5
J Handbrake cable length? Austin Healey 1
T %*!##! Handbrake part two Triumph 35
1 Handbrake adjustment Spridgets 3
1 BE handbrake removal help......... Spridgets 14
