Bugeye handbrake cable
ncbugeye
I am trying to adjust my handbrake, which has never really worked since I acquired the car. I have the car jacked up for the fuel pump work described elsewhere.
I completely slacked off the cable, then adjusted the drums to the correct setting and now I find I cannot tighten the cable enough to actually have any effect at all. I used up all of the adjustment at the back end of the cable, and still no effect. Is there some adjustment available at the front end of the cable?
Is it just that the cable is old, tired and stretched, and needs replacing? It looks comparatively new, there is no corrosion and almost no dirt on it.
JPSmit
spritenut
I can tell you that the new cables from 4 letter word suppliers will stretch in a week where it took 50 years to stretch the original.
I have resorted to Ebay and swap meets for NOS cables from England.
The new cable I used on the Holy Sprite stretched a full inch in 1 week.
Apparently the chinese never heard or understood the meaning of tempered steel.
Strand cable MUST be tempered or it will stretch like a rubber band.
Just like the replacement E brake cables.
ncbugeye
ncbugeye
Frank,
Thanks for your insight and for your unmatched depth of experience with these cars we love so much.
I can only conclude that I am dealing with one of the cables you refer to. The PO referred to it as having been "recently" replaced when he sold me the car about 2 1/2 years ago, and it has basically never really worked.
So, do you or anyone else know where a "real" NOS handbrake cable for a Bugeye can be found? Is there a better setup from a later model that can be transplanted?
spritenut
Watch Ebay, I just bought one last night for $9.95 and it is an original made by Catton. They pop up there all the time.
I Bugeye handbrake spring source? Spridgets 1
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
drooartz Replacing Bugeye windshield rubber Spridgets 6
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
drooartz Restoring Penny the Bugeye Spridgets 22
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
5 Sold My 1960 Bugeye Spridgets 10
SNClocks Goings on with our new Bugeye Spridgets 1
F 59 bugeye spring bushing bolt Spridgets 8
Rut 3 point belts in a Bugeye? Spridgets 9
JPSmit gluing a panel on to a bugeye Restoration & Tools 2
I Bugeye oil leak help Spridgets 4
I Bugeye lack of power Spridgets 1
I Bugeye charging issues Spridgets 8
I Bugeye smoking Spridgets 9
I Bugeye valve rebuild suggestions Spridgets 8
jfarris Immaculate 1958 Bugeye Spotted 4
drooartz Leno's Bugeye Spridgets 12
R BUGEYE SOFT TOP FIT Spridgets 2
R Bugeye splined wheels Spridgets 0
T Wanted Bugeye Sprite RHD tonneau cover. Austin Healey Classifieds 0
Jim_Gruber Bugeye Seat Pans needed Spridgets 1
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
Basil For you Bugeye/ Frogeye fans Spridgets 5
B Bugeye Electrical Diagram with additions Spridgets 6
R 59 Bugeye rib cage tranny hard shift into reverse Spridgets 0
