GT6 GT6/TR6 Engine Painting Procedure...
Flinkly
ok, so i'm getting ready to paint up the exterior of my engine and put it all together. i've been thinking about this some time and can't figure out how to paint the engine apart without ending up with unpainted metal exposed after assembly. the main area i've thought of is the front of the block that the front plate doesn't cover. it looks like the front of the block should be smooth like the top of the block, so that says no paint to me, but rusting? i guess i'd like to hear opinions, i'm probably just making this too hard.
i've already painted the timing cover and oil pan (outside only), both plates and the mounting attachments.
2wrench
Flinkly: I used an engine enamel by POR. What I
liked was it can be applied with a foam brush. This
makes it easy to touch-up or paint in areas later
that couldn't be done so easily if the engine is
sprayed.
hondo402000
in a previous post someone said to heat the block prior to painting, seems that cast iron holds some moisture, heating the block first dries it before you paint
Brosky
I'm hoping that mine gets several hours in the hot sun prior to painting this afternoon.
I'm using Dupli-Color High Temp Ceramic for mine.
F GT6 TR6 dual exhaust manifold on GT6 engine? Triumph 2
2wrench GT6 1973 Triumph GT6 MK3 Engine for a TR6, yes or no? Triumph 10
S GT6 GT6 engine in a TR6 Triumph 3
svtmikey GT6 TR6 engine parts in a GT6 Triumph 9
tr6nitjulius General TR TR6*8 TR4*2 GT6 Spitfire Triumph 2
T GT6 GT6 and TR6 gearboxes interchange? Triumph 6
tr6nitjulius General TR TR6*7 TR3/GT6/Spitfire 1 ea Drivin' 6/27/15 Triumph 2
toysrrus TR6 TR6 & GT6 Flywheel, Clutch question: Triumph 4
tr6nitjulius Spitfire TR3*3 TR4*2 TR6*7 Spit*2 GT6*1 Others*2 Triumph 5
glemon GT6 TR6 GT6 Quoted HP More Triumph Trivia Triumph 1
W GT6 GT6 / TR6 Rotor Options Triumph 2
G GT6 Can I put a GT6 balancer [crank pulley] on a TR6? Triumph 2
T GT6 Toyota caliper swap for GT6 like TR6? Triumph 3
hymodyne GT6 TR6 in a GT6 Triumph 9
WedgeWorks Wedge Ultimate TR6, GT6, Spitfire & TR8! Triumph 11
B GT6 GT6 Oil Cooler Kit for TR6 Application Triumph 3
SCguy GT6 GT6 or TR6 in Nor Cal Anyone interested? Triumph 1
B GT6 Isuzu Trooper Gear reduction starter for TR6/GT6? Triumph 5
GT6_Mark GT6 GT6 TR6 etc Oil Filter By-Pass Valve Pressure Triumph 2
S GT6 GT6 Head on TR6 Block Triumph 1
F GT6 GT6 Clutch Kit advice, as bad as the TR6 kits? Triumph 5
Alan_Myers GT6 Free GT6 body shell, SF Bay Area. TR4 & TR6 Triumph 1
bobh GT6 GT6 Crank in a TR6 Block Triumph 4
michalotti_tr GT6 Engines: TR6 vs GT6 Triumph 14
J GT6 TR6 Transmission w/OD in a GT6? Triumph 9
S GT6 GT6/TR6 rocker arm identification and questions. Triumph 0
S GT6 GT6/TR6 rocker shaft oil problems. Triumph 5
M Spitfire GT6 or TR6 in a Spitfire? Triumph 14
nathandarby67 GT6 Are GT6 oil filters the same as TR6? Triumph 1
D For Sale GT6 Rotoflex Axles: clean, beadblasted, coated with POR15, excellent rubber couplings. Triumph Classifieds 0
C GT6 GT6 fender flares Triumph 0
B GT6 trying to ID my New Car. GT6 Triumph 6
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
Writer2022 GT6 GT6 Stiff Gear Selection Triumph 4
D For Sale Triumph GT6 for sale (possibly one of the worlds finest examples) Triumph Classifieds 2
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
D GT6 9 months later. GT6+ progress Triumph 3
luke44 For Sale ā€˜72 GT6 MKIII For Sale Triumph Classifieds 0
LarryK GT6 Fresh purchased GT6 Triumph 11
O For Sale 1969 GT6+ Mostly rust free. Triumph Classifieds 3
idlehands Wanted WTB GT6+ driver (LHD) window glass and a single rostyle wheel cover Triumph Classifieds 1
R GT6 GT6 Bearing Part Number Request (Front Axle, Inner Bearing)... Triumph 3
idlehands GT6 What gotchas when looking for a GT6+ Triumph 10
idlehands Wanted GT6+ Triumph Classifieds 11
E GT6 Triumph GT6 MKIII rear hatch springs Triumph 2
B Wanted wing windows gt6 Austin Healey Classifieds 0
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
6TTR3A Wanted GT6 MK one engine fan Triumph Classifieds 0
UltimateQuestion GT6 GT6 Mk3 rear wing removal Triumph 3
