Grey Windshield Pillar Seal
HealeyRick
Anyone have a source for the original grey windshield pillar seal material that was used on BJ7s and BJ8s? All the usual sources, including MacGregor, only have the black stuff. I have a recollection of reading there was an American seal company that sold it (at pretty ridiculous prices) but I've searched here and on the Team Net archives and can't seem to find it.
RestoreThemAll
From their main page, on the right you'll see a rare and hard to find parts cat. There's navigation on the left side of the cat. If you don't see it call them. They've always come through for me with new and used parts.
https://www.britishcarspecialists.com/
vette
Rick, your saying this here stuff isn't it? See pic. this came from MacGregor. He told me this stuff was the real McCoy. Dave.
Patrick67BJ8
I remember buying the seals from the Dealers and they were gray and a weave pattern and NOT fuzzy. Try and find a source for Chrysler 300 windlace(memory check-might be 500 windlace), but it had a weave pattern to it. Trim shops carried it.
HealeyRick
HealeyRick
It's hard to tell from the picture whether it's the grey stuff or the black stuff. I'll get in touch.
Dave, if yours is fuzzy, it's not correct. The correct stuff is a windlace pattern like that on the top edges, except the seal itself is larger. You can see the correct material (although not the right size) at the bottom of this picture.
Patrick67BJ8
Check this out.
https://www.forwardlook.net/forums/forums/thread-view.asp?tid=38078
Editor_Reid
Platinum
Macgregor's stuff was called "Bristleflex." It was fuzzy. I never understood why he didn't make it match the original item. I didn't know he'd stopped making it, but maybe it was because it wasn't that original and so interest in it was not high. It always fell into the "better than nothing" category for me, and no more than that.
Patrick67BJ8
the BJ7 & BJ8 cars use a lot of convertible top/window seal material compared to the earlier Healey's so it would make sense to have the correct stuff. IMO, The amount of money spent on restorations would warrant a higher cost seals to "make it right" if pricing is the issue in manufacturing.
RAC68
Hi All and Happy Hollidays,
I just looked up the BCS price for the BJ7/8 windshield weather/windlace and at $129.99 per 25" piece per side, I will find another way even though not concourse. Patrick had a thought and using pinch-on windlace in combination with a separate but attached weather strip, could provide one possible alternative. As far as using the same approach on the BJ8 top, I had long ago replaced the light-gray/off-white vinyl covering on the wood surrounding the side windows with black vinyl to make less-obvious the shrinking of the top (purchased from Sears Outlet and installed in 1971or 2) still in great condition. Replacing the light gray material covered window weather stripping with another color or even vinyl covered pieces would not be that dramatic.
Although I would like to remain as correct as possible, the price and availability of "Original-type" is starting to pass the limits of my practicality. Purchasing my Healey new was not an act of practicality at the time and over the years there were many practical changes I have made to make driving more reliable and pleasurable. Although all changes made, except for the 14 installed in-line fuses covering all critical circuits and devices, can be easily and, for the most part, inexpensively reversed (having retained all original parts), a small number of anticipated changes, like this, are starting to grow in and I am interested in planning for the eventuality before its time.
Just some thoughts on plans for the future,
Ray(64BJ8P1)
vette
Ray(64BJ8P1)
:iagree:
The words " two pieces" scares me. If the products are anything like the junk I got from Moss. I ended up just throwing it out. That's when I was directed to MacGregor.
Patrick67BJ8
Ray(64BJ8P1)
The Chrysler 300 stuff I got was made like most windlacing and not two piece. It lasted over 30 years. There's a 300 series Chrysler car, but not to be confused with the wind lacing I'm referring to. Best to email for samples. I think the price for the stuff from BCS is incorrect for one side. It wasn't that long ago that I purchased it. A place in Dallas, TX, Earl Owen, was where I purchased mine, 300 stuff. I'm going by memory here, it might have been 500 windlacing.
RAC68
Hi Patrick,
Maybe I am incorrect in my perception but I thought the Windlace you suggested did not come with a seal incorporated and was only the peace to push onto the edge of a piece of metal for finishing. If my perception is correct, a sealing rubber piece would need to be fitted/attached to the windlace in some manor to complete the functional requirement. That is the 2-piece approach I was referring would need to be figured out.
You may be correct about the BCS price incorrectly stated in their catalogue and would call to verify before taking a more complex approach. However, their catalogue posted price is $129.99 per 25" piece and I would expect has been set by scarcity and market demand.
Ray(64BJ8P1)
Ray(64BJ8P1)
Patrick67BJ8
Hi Patrick,
Ray(64BJ8P1)
Ray(64BJ8P1)
I did more research and it looks like the part number is UG 500 and only comes in black. It is Uni-Grip style. Saw info on Keystone Grand Prarie. This type has the "bulb" with it. I'm sure they will send you a sample.
do8erman
good morning rick. Check out the photos of the brg healey bj8 which mike gassman restored they are on his web site . In particular the one of the windscreen pillar seal and I doubt you will find anything closer. An exceptionally nice guy who may sell you some if he has it in stock. Good luck Chris
Top Down Resto
Clarke Spares was supposed to be making the correct profile bulb stitched as correct to the crimp on with correct style weave lacing. I talked with him a few years ago, it was down to actually making a machine that would sew the two together ( remember the crimp on or push on is a metal skeleton). He send me samples of the bulb and material /skeleton. It seems very do able if and when he makes the sewing mechanism.
patiently waiting,
Carroll
M TR4/4A Carpet....Black or Charcoal Grey? Triumph 9
DerekJ Two early BN1s in Healey Grey for sale. Austin Healey 4
toysrrus Series III Rdstr. Top Bows [Grey] & Vinyl [Blk] Top For Sale. Jaguar 4
T TR2/3/3A Pictures of Silver or Grey TR3's Triumph 14
angelfj1 Project Up-date - The Grey Lady's body is painted Triumph 17
1 100-4 Gunmetal Grey Color Austin Healey 2
MadRiver Grey streaks in the oil!! Triumph 6
LuckyLuke Rare Austin Healey Grey Color Austin Healey 2
P TR4/4A Birch Grey TR4A .... yes or no ? Triumph 19
Johnny Colorado Grey?? Austin Healey 19
K clouds of grey smoke MG 9
J SOLD!! Triumph TR 2 TR 3 windshield stanchion mounting plates Triumph Classifieds 3
D TR2/3/3A Windshield glass doesn't fit Triumph 6
P Post-War Other Herald Windshield: Is it the same as.... Triumph 2
D TR2/3/3A Windshield assembly question Triumph 6
drooartz Replacing Bugeye windshield rubber Spridgets 6
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
ModifiedBJ7 BJ7 Windshield Surround Rubber Seal Austin Healey 2
T TR2/3/3A TR3A Windshield Question Triumph 4
Popeye General TR Old imperfect windshield - keep it toss? Triumph 3
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
K TR2/3/3A Removing TR3 windshield stanchions Triumph 4
P Austin A40 Devon windshield. British Motor Corp 2
K TR2/3/3A The Harley Davidson side mirror that mounts to the TR3 windshield stanchion? Triumph 11
R TR2/3/3A Windshield Wiper System Triumph 2
P Cracked windshield Other Cars 0
B TR4/4A Windshield Capping Strip Triumph 5
D TR2/3/3A Windshield frame fitting. Triumph 2
M TR6 Windshield Trim TR6 Triumph 14
Sopwith_Camel mk2 windshield wiper nozzles Jaguar 4
Michael Oritt 100 Windshield seal Austin Healey 0
S Bugeye Windshield Seal Austin Healey 1
BoyRacer Windshield Wiper Wheelbox Austin Healey 4
EWD TR6 74 TR6 - Rear and windshield frame color Triumph 2
B Windshield glass, where to buy Restoration & Tools 4
S TR2/3/3A Cutting the finish end on the windshield top rubber Triumph 4
C MGB 1966 MGB windshield glass MG 4
M General MG Midget MK1 windshield replacement MG 2
B MGA Windshield glass MG 11
R TR2/3/3A Fitting windshield Triumph 3
steveg Rebuilding roadster windshield Austin Healey 24
B TR2/3/3A Windshield Wiper mount rubber Triumph 3
Z TR2/3/3A Windshield Aftermarket Triumph 22
B Longbridge 100-6 Windshield Posts - Body Color or Silver? Austin Healey 16
D TR2/3/3A Windshield difficulties Triumph 24
Rut Cut down windshield Spridgets 22
R Windshield Washer Pump Repair Austin Healey 9
M BJ8 Windshield Austin Healey 10
G For Sale Morgan Folding Windshield Posts, Original 1960s-70s “Small Quadrant” Style, $600 Other British Classifieds 0
A TR2/3/3A Need Helping finding windshield bracket! Triumph 5
