During my snow and cold bound musings, I was reading my Haynes manual regarding the gearbox. The manual reccomends that the gearbox fluid not be drained unless it's being overhauled and indicates the gearoil, (90wt. I presume),should be "topped off" being careful not to overfill.
I understand the overfill concern.
I am 3rd owner and have not pulled the plug to the gearbox in the three seasons we've been running.
Given the position of the plug I would have to think the only way to check the level is perhaps to use one's finger. Not the most accurate method I can conceive. I'm also concerned about the age and viscosity of the gearoil since I've driven the the TR4a probably 1000 miles by now.
I know I have a clutch slave cylinder to replace, and should do the same with the master, so yes I have noticed a little more difficulty shifting at the end of last season. No noises of any concern and I'm sure the clutch slave will smooth things considerably.
I have been respectfully neglectful to this area of maintenance and would appreciate any and all thought's on the matter.
Oh by the way. I found the clutch slave cylinder I want. Rimmer Bros. Girling part. $114.00 American + shipping. I wonder is it worth the extra cost in a resto mod.
