fuel pumps for webers
trfourtune
MadMarx
I use the Mitzuba fuel pump. Never failed and don't need a regulator. It does supply 120 L/h.
Chris
T
trfourtune
Chris,
these are dirt cheap in north america. The site has a price but we can get them cheaper at napa etc.
Rob
DNK
Interesting about the regulator.I was planning on buying that pump and running it with the filter king reg. Now I only am running twin SU's with a mod motor. My question is .Will $PSI and all that volume overwhelm the carbs if I don't run the filter king? Any ideas?
WidespreadPanic
do you have to use an aftermarket fuel pump if you convert to Weber carbs (32/36 DGV's to be specific) or can you use the stock fuel pump?
DNK
No you don't have to. In fact I think a couple of members are running triple carbs with the stock.
tr8todd
I have three of those same pumps sitting on a shelf in my garage. Two came on a TR8 race car I bought and one was on a BMW 2002 with twin 40 DCOEs I had. They seemed to work very well. I also have several Facet pumps that I don't like. Both race cars now run a Barry Grant fuel pump with a regulator. Expensive, but they work great.
DNK
Mad Max- I think Mr. Panic has a street machine and probably would do fine. Unless everything else is hot too then all bets are off!
kodanja
MadMarx said:
I had misfire on high revs with the standard pump.
<span style='font-size: 14pt'><span style="color: #000099">I have 32/36 DGV's on my 6, with a standard fuel pump and it works FLAWLESS !!</span></span>
Lionheart
I did some more reading about the Carter gp4070 fuel pump...seems like many people are fond of it.
Summit Racing carries it for $69.95...also available from Summit through their Amazon outlet for the same price.
While I was on Amazon, I was surprised to find that a search for Triumph Spitfire returned a LOT of items.
Since I am installing a DCOE on my 1500, I ordered the pump. Now I reckon I'll need to make a cover plate for my mech pump.
Len
Bugeye58
Len, you can either make a cover plate, or just leave the stock mechanical pump in place. I found the cover plate to be a convenient spot to add an addditional crankcase breather.
Jeff
Twosheds
I read somewhere, it might have been in More B.S. About TRs, that, if you're going to bypass the mechanical pump, you should remove it. I think the reasoning was that the mechanical pump needs the fuel flowing through it for cooling, and, without it, will fry.
Besides, it's easy to make a cover plate out of scrap aluminum. Or whatever you have lying around.
mctriumph TR2/3/3A Brand new fuel pumps Triumph 8
PAUL161 T-Series Fuel Pumps MG 5
T Rebuild kit for fuel pumps 1955 to 1964 Spridgets 1
S TR2/3/3A Not all tr3 fuel pumps are built the same Triumph 5
bugedd Two fuel pumps Spridgets 4
K TR2/3/3A Fuel pumps and Neg/Pos ground? Triumph 6
drooartz MGB-GT Facet vs SU fuel pumps MG 18
K TR2/3/3A More on Fuel Pumps..... Triumph 6
oxford fuel pumps Austin Healey 3
coj Alternative fuel pumps Austin Healey 19
coj fuel pumps AH 3000 BT Austin Healey 9
M TR2/3/3A fuel pumps from Turkey Triumph 5
5 Modern [Burlen] SU fuel pumps Austin Healey 7
G Where you 6 guys putting fuel pumps? Triumph 10
H QH brand fuel pumps MG 2
T More on mechanical fuel pumps Triumph 32
Michael Oritt Who repairs SU fuel pumps? Austin Healey 7
livinginthepast Work, missed events, bad fuel pumps, radiator, etc Spridgets 1
T What do you think about these fuel pumps? Triumph 5
M Do 1098 motors have fuel pumps ? Spridgets 8
T AC Electric fuel pumps - time for some schooling.. Triumph 10
T fuel pumps and shocks Spridgets 12
sparkydave Facet fuel pumps reliable? Spridgets 23
Jim_Gruber Mr. Gasket Fuel Pumps Spridgets 9
Luke_Healey Non stock fuel pumps? Spridgets 5
C MG fuel pumps. MG 16
L Electric fuel pumps Lotus 10
T Spitfire Spitfire fuel pumps Triumph 6
philman fuel pumps for '76 B MG 3
John Moore Spridget 1275 SU Fuel Pumps Spridgets 11
ronzet Fuel pumps, generators, and leaking SUs MG 10
mrv8q Fun w/ Fuel Pumps Triumph 8
Brit_Brother How often do you check your SU fuel pumps ? Austin Healey 25
71tr fuel pumps Triumph 15
R SU Fuel pumps Austin Healey 3
B Fuel Pumps Austin Healey 2
R Alternative Fuel Pumps for a 420 Jaguar 10
S TR2/3/3A Tr3 fuel pumps in the mountains. Triumph 11
RichC SU Fuel Pumps: diagnosing? MG 9
WALTER mechanical fuel pumps Spridgets 12
bighly Whack that pump [ Fuel Pumps ] Austin Healey 3
J electric fuel pumps Austin Healey 9
F Fuel pumps Spridgets 6
AndreL TR6 Conversion to electric fuel pump Triumph 14
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
A TR6 How many fuel filters-TR6 Triumph 25
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
