Front Shroud Differences: 3000 vs. BJ8
maxwedge5281
I have damaged the front shroud on my BN6 beyond reasonable repair. I have found a decent BJ8 shroud. My question to the forum is, what if any differences are there in interchanging the two shrouds? I realize that the parking/turn signal light openings are different, but I can live with that, I think. However, the windshield area and windshield post attachment might be different as well as the shroud extension for the dash. Hopefully there would be little to no difference, but I suspect that I might have to compromise and use part of my shroud with the BJ8 shroud. My damaged shroud is okay from probably one half of the bonnet opening to the rear where the shroud attaches to the dash. Any help is appreciated.
John Turney
You're correct, the shroud is different in the windshield area. The defroster vents are about 6" forward (I recall) in the convertible shroud. A club member of ours found his had been pieced there and had two sets of defroster vents.
vette
MaxWedge, I have a BJ7 that has dual lighting like a BJ8. I investigated that arrangement years ago when I bought the car and was told that it was delivered to Germany and had an early Euro lighting arrangement. When I restored the car I found no evidence that the shrouds had ever been changed. So I go with that explaination. My point in saying this is that when I restored the car there was no wiring harness that would match the electrical configuration in the car. I either had to buy a BJ7 or earlier harness that had provisions for the turnsignal/brake relay or buy a BJ8 harness that would match the lighting layout and no relay but then did not match the dashboard configuration. For better or worse I opted to by a BJ7 harness and modify it so as to not need the turnsignal/brake relay. It was quite a hassle. In your case since you have the relay I believe the only thing that you will need to do is separate the turnsignal and running light wires at the front of the car and attach them to separate sockets. (the back of my car also is wired like a BJ8 which increased the complexity of adapting an early harness.)
Patrick67BJ8
Depending upon which BJ8 shroud you have the size of the park & turn signal lights are larger on the BJ8 and as said, the windshield area too is different. Try to find an early shroud. They’re around.
healeyblue
Too bad it isn't the rear shroud you needed. I have a perfect rear shroud hanging in the shop. My old front shroud is good on the rear half also but the front is toast. I also have the German delivered BJ7 as Vette but they are the small sized lights like the early BJ8's but also has the same windshield problem you are facing as it is different than the roadster version.
Jim
maxwedge5281
maxwedge5281
thanks for the responses. i was able to source a correct shroud in what appears to be good condition from a forum member.
maxwedge5281 Wanted wtb....bn6,3000 front shroud Austin Healey Classifieds 10
Jake BN1 Front Shroud Badge - What is original? Austin Healey 4
Marvin Gruber Front shroud piece needed Austin Healey 16
Healey Nut Front shroud badge Austin Healey 66
BoyRacer front shroud templates for 3000 Austin Healey 4
B Fitting grille surround to front shroud - BJ7 - any advice? Austin Healey 21
B Painting underside of front and rear shroud - Original prep and color? Austin Healey 3
5 Mk1 vs Mk2 front shroud difference Austin Healey 6
E relief map of lower front shroud 61 bt7 tricarb Austin Healey 0
germanmichel BT7 shroud connecting at front frame rail plates Austin Healey 6
T Front Shroud Qustions Austin Healey 8
T 1955 BN1 front shroud Austin Healey 3
T Austin Healey front shroud FORUM Navigation Questions 1
H front shroud-pls clarrify holes for me thanks Austin Healey 9
O front shroud work in Northwest Austin Healey 5
H Wheight front shroud Austin Healey 3000+transport Austin Healey 18
richberman Pictures of BN4 front shroud/chassis joint Austin Healey 5
J Healey BJ8 Front Shroud Phase1 / Phase2 ? Austin Healey 7
Y Restoring a 58 100 six front shroud Austin Healey 1
T Front Shroud Adhesive Austin Healey 10
T 100 Front Shroud Attachment Austin Healey 0
J front shroud to fender welt Austin Healey 4
C Front apron to shroud clearance Austin Healey 21
B Front Shroud 1974 Spridgets 10
Bob Claffie Front shroud asm Austin Healey 5
timbn2 Front Shroud for 100 Austin Healey 2
AUSMHLY Rain channel screws, front shroud Austin Healey 1
AUSMHLY Front Shroud replacement Austin Healey 28
S Front shroud and fenders Austin Healey 12
N BJ8 front Shroud Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
