I am finally putting my 1955 BN1 back together! With the body work and paint behind me it's time to test my memory on how it goes back together! I will need lots of help.
Two things: What is a good adhesive to use on the front shroud? I remember a post, but could not find it in a search. I want something that if I had to take the shroud off, I could without damage. The original stuff was hard enough to get off.
Second. I have read posts about leaf springs as to replace or use ones that came off the car. It appears to me that alot of people bought new ones only to put the old ones back on! No leafs are broken, I bought new bushings that I am going to take to the local spring shop to put in. Are there any measurements to take with me to the shop as to check the correct arch? I remember someone saying that there are distance measurements in the repair manual??
Thank you in advance,
Tod
Tod
