Front End Shake at Higher Speeds
chuck1006
1959 100-6 BN6. Rebuilt front end and new wheel bearings. Shocks seem good w/ added shock package that came with it. Steel wheels (not wire) that have been balanced with new tires. I think it may be the steering. When jacked up the wheels they do not seem to pull in or out or side to side. The steering wheel is a standard approx 16" OD. With the tires on the ground the steering wheel travels about 2.25 inches from side to side before the wheels turn. Is this excessive? If so, where do I go to get the steering box rebuilt? Anything else to check? Someone earlier advised to raise front end after supporting front shock braces with 2" boards to keep the wheels as on ground to check out. I haven't done that yet since I think the steering box may be the problem.
Thanks for any advice
Keoke
Hi Chuck, that is way too much play in the steering.But you did not say if you had attempted to adjust the slop out of the steering box.I would give that a try before I condemed the box.---Keoke
C
chuck1006
[ QUOTE ]
[/ QUOTE ]
Thanks Keoke,
Do you have instructions as to how to adjust the slop out?
Chuck
Keoke
Chuck ,Loading Austin Healey -Please wait /ubbthreads/images/graemlins/smile.gif. On the top of the
steering box is an adjustment screw.Securing this screw is a lock nut.Either put jack stands under the spring plates on each side of the car or put 2"spacers under the top wish bone{Shock Arms}to maintain the wheels in their normal loaded position while the car is jacked up.Now free the lock nut and turn the adjustable one down a little at the time. Check the backlash at the steering wheel as you go, when you think the backlash is about right oh say 1" or a little less.Tighten the lock nut back down.Now move the steering wheel from lock-to-lock there should be no appreciable tightness except a very small amount as the wheel passes over it's center position.I hope this solves your problem.---Keoke
C
chuck1006
Thanks again Keoke,
I adjusted the steering as you advised. It is much better now but maybe a little tight. I took tires/wheels back for a balancing check and the drums in to be turned, The drums were very good with little to take off. One of the wheels needed balancing (they said it was enough off to cause vibration). I guess I should have checked that first. I took my Healey for a test today on the freeway and it didn't shudder. I estimate I was going about 60+ but since my speedometer isn't correct (next post) I can only guess. Thanks again for all your advice.
Cheers, /ubbthreads/images/graemlins/smile.gif
Chuck
craigshealey3000 Front End Shake Austin Healey 31
BillyB62 TR2/3/3A TR3 front end shake Triumph 24
Dave Russell Front End Shake at Higher Speeds Austin Healey 5
C BN6 Front end shake at high speeds Austin Healey 7
G MGB '71 MGB Front End Rebuild MG 2
X Front End Alignment Austin Healey 14
B Bent frame rails near BE front end Spridgets 2
B 2013 Nissan Frontier front end mystery Other Cars 7
K TR2/3/3A Front wheel bearing adjust and end float?? Triumph 10
Michael Oritt Lube points on BN/BT7 front end Austin Healey 4
K TR2/3/3A Advise on previously botched front end lower fulcrum support bracket. Triumph 5
AUSMHLY BJ8 Front End Squeak Austin Healey 25
AUSMHLY 64 front end too high Austin Healey 14
thibault BJ8 plus 55mph Front end shaking Austin Healey 100
vette Effects of Lowering the Front End Austin Healey 21
G Front end Alignment - Total Toe vs. Individual Toe Austin Healey 3
R Front wheel bearing - end float Austin Healey 40
T For Sale For Sale: Bugeye Front End Spridgets Classified 0
K TR2/3/3A Front end woes... Triumph 18
S Wedge tr8 front end Triumph 0
B TR2/3/3A Front end alignment Triumph 23
Jim_Gruber Bugsy IV Front End Rebuild Spridgets 5
mcmillal TR4/4A Front End Vibration Triumph 9
K TR2/3/3A Front end Question.... Triumph 4
M front end alignment Austin Healey 12
T TR4/4A Front end alignment specs for lowered car Triumph 2
Joe Reed MGB Rattle under front end? MG 8
J MGB Project car done; front end clunk noise while braking MG 4
S TR2/3/3A Front end alignment and tire wear Triumph 9
aeronca65t Minor front end work Spridgets 12
RAC68 Calculating Front Hub End-Play Austin Healey 32
aeronca65t front end maintenance Spridgets 5
bugedd Front end rebuilt help Spridgets 6
BlueMax Front End Completed Spridgets 23
bugedd About to rebuild front end...any tips? Spridgets 5
K TR2/3/3A Using Moss front end alignment gauge? Triumph 6
K TR2/3/3A Front end reassembly: trunnion spindles and wishbone bushes??? Triumph 10
BillyB62 TR2/3/3A TR3 Ball joints & front end Triumph 5
D XJ6 series III front end rattle Jaguar 5
Tr3aguy Front end rebuild questions>? Triumph 6
S Finally got my front end back together Triumph 5
O TR2/3/3A TR3 front End Alignment Triumph 8
RickB Box Spridget fiberglass front end - front mounting Spridgets 5
K TR6 TR6 front end Triumph 2
Burrell22 TR4/4A Tr4 front end help. Triumph 10
B Bugeye front end Spridgets 0
H Should I drop the front end down a little? Austin Healey 25
M Advice on doing a front end rebuild via kit? Spridgets 4
hondo402000 TR6 TR6 front end alignment and wheel balancing Triumph 4
S TR2/3/3A tr3 front end alignment Triumph 9
