Engine & Trans Finley In!
Fantastic!
Can't remember if you've posted them before -- what sort of engine specs did you do?
Wow,Wow,Wow!!!
Questions??? Where did you source the sway bar?? What wheel's and tires?? Steering arm's appear offset. Is that to clear the wheels?? Brakes??
Kurt.
Very pretty! *That* will be fun to drive!
Alan,
That is incredible! Won't be long before you and David are chasing each other down! What alternator did you go with?
Rut
Thank Guy’s !
Drew, engine is a trick out 1380cc with many mods, steel billet crank, billet rods, Fidanza flywheel, ported head with Rimflow valves, vernier timing gear, Titan roller rocker, SPVP3 cam, Romac stainless balancer.
Rick, I’m running a newly built Datsun 5 speed gearbox
Kurt, Sway bar I made, 7/8” tube chrome moly. John Brown 14” x 5.5” with Dunlop Direzza tires. Steering arms are offset with 4 piston billet aluminum Outlaw calipers.
Rut, the alternator is a racing 48amp Denzo alternator.
That is stunning!
Any link to the alternator you used would be helpful :smile:
However, how come I can see in the crank on the last pic?? Hmmmm.
Amazing what money can do, wish i had one.
Ah, Jack you caught me on that one!! But I wonder if you see the other inconspicuous chassis mods. You have to look very close?
One must know question, what is the master cylinder coated with and where can I have it done or get the stuff. Miss Agatha asked.
I see the front cross member between the shock towers has been modified. You now have room for a Datsun engine!:highly_amused:
Kurt
Sorry no Datsun engine for me!! If I could run a British 5sp gear box I would, but just haven't found one that would work easley...
You need to get a transparent aluminum bonnet for that STUNNING engine compartment!! Almost seems a tragedy to hide it under a standard bonnet!! :smile:
Alan,
do you have a part number for the alternator you used? I tried finding it with the info you provided, but nothing definitive.
Thanks, Rut
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
Bob Claffie Spitfire Engine & trans compatability Triumph 1
B For Sale 1956 Austin Healey 100-4 SCCA big bore race car plus parts lot engine trans etc Austin Healey Classifieds 0
DanLewis Two midgets available: '79 is free [no engine, trans], running '77 $1500 [NFI] Spridgets 1
R TR2/3/3A engine / trans installation Triumph 5
Kleykamp TR2/3/3A Engine swap and Separating Trans from Block out of car? Triumph 5
K 1948 Austin Sheerline engine and trans for sale in Winnipeg Manitoba Other British Cars 0
Spriteman65 Engine and Trans for sale Spridgets 4
B TR2/3/3A Pulling engine & trans on TR3B - hoist attach? Triumph 6
K Would a TR4 Engine & Trans fit in a Bedford Van? Other British Cars 2
jollyroger Spitfire GT6 engine in 76 Spitfire, source for trans cover Triumph 6
Gray_Cat MGB MGB OD Trans [and engine] For Sale in NC MG 9
BugeyeNJ58 Garage Clean Out-1100 Engine and 4-speed Trans. Spridgets 5
T How much force necessary to mate engine/trans? Triumph 16
eschneider TR2/3/3A need help - value of TR2/3/4 engine & trans cores Triumph 8
T Installing an engine when trans is in place Triumph 19
B Datsun engine & trans in a Morris Minor? Other British Cars 0
eschneider value - BJ8 frame, engine, trans w/ title? Austin Healey 8
Dadandson First Time Engine/Trans Removal Spridgets 18
NardisCNC How fast can you pull your Midget engine / trans?? Spridgets 17
drooartz Do I use: trans brace, braced engine mounts Spridgets 2
chrpark Your opinion- engine and trans removal as a unit? Spridgets 8
martx-5 Engine and Trans Are In! Triumph 7
aeronca65t 1500 Midget engine/trans/etc Spridgets 0
eschneider value of a BJ7 frame/engine/trans? Austin Healey 2
beachbumbarry XKE - - Toyota engine / trans Jaguar 27
B engine and trans removal MG 6
B engine and trans. weight MG 11
S For Sale FREE - TR3 engine and transmission Triumph Classifieds 0
R TR2/3/3A Engine revs up and down Triumph 7
kodanja TR2/3/3A 1960 TR3A w/TR4 engine, fuel pump replacement Triumph 25
L General Tech Engine id Triumph 9
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
