Engine test run stand
TulsaFred
After I finish the rebuild on my 1275, I'd like to test run it before installing in the car (the bugeye has a perfectly functional 948 installed). That way I can work out the bugs in the 1275 before pulling the 948.
Anyone ever done this? What type of stand/jig/device can be cheaply constructed to to it?
thanks
Fred
My father has one he built. However, there was a guy at LotO that built one using an old hand dolly as a frame.
You really do not need much ... battery, coil, fuel pump, radiator,...
Bayless
Here is a really simple one I got with the free A series motor. Only thing it needs is gauges.
Platinum
Built a good (we thought!) stand with 1" angle iron for a 4.2 Jag mill... rad, gas, electrics, gauges and control... hint: DON'T rev it suddenly! :wink:
Just an FYI.
Mickey Richaud
Just an FYI.
Practicum in physics, eh? :wink:
Platinum
Yup. It darn-near fell over on throttle app... Scary!!!!
Plant <span style="font-style: italic"><span style="font-weight: bold">outriggers</span></span> on ANY stand ya put together! :smile:
58Custom
That is charming! I dig old custom tools like this. Yeah, I would flesh that out with the goods and use it.
JPSmit
I'm sure last year at bronte there was a guy running a 1275 on a stand made from 4x4's
Gerard
I've made a couple using cut off front frame sections. That was I can use the original motor mounts and add the radiator all in stock form. I add extensions to the cut off frame legs and can even attach the transmission. The front casters are mounted outboard of the frame legs, giving plenty of stability. There's plenty of room to add gauges and a fuel pump, even wire up an ignition switch. With the casters and it can be tucked away all together until it's ready to go into the car.
jlaird
Spritenut, test ran his on the floor. No stand. Just enough to see that all was good. Miss Agatha did the same thing. Could always bolt a 2x4 on the motor mounts if it bothers you.
In fact wood will work great for a test stand. Not a lot of engine there.
gbtr6 TR6 Test starter system with engine out? Triumph 16
T Engine test stand Austin Healey 8
J Engine Test Stand Restoration & Tools 7
R Test Starting Engine Triumph 16
Trevor Jessie Nice engine test stand Spridgets 7
bmurphy7369 Compression test on 4.2 XK engine Jaguar 11
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
R TR6 question re: Engine Oil Triumph 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
BoyRacer Austin A90 mystery engine British Motor Corp 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
kodpkd 1961 BT7 engine oil Austin Healey 31
